I have a Valor Fireplace model #936TTN. I took the glass front off to clean it, and now the flames ignite until the glass is replaced. Then the flame is extinguished. Seems like there is no air flow but all the vents etc are clear. Any suggestions would be greatly appreciated.
  • 72 Answers
I know you said the vents are clear, but what you are describing is a lack of oxygen to allow combustion. Either the fresh air is blocked, or the exhaust is blocked (or both). You must re-check the venting to look for blockage. Specifically, take a flashlight and look inside the termination cap for a nest etc. It could also be ice-buildup depending on your situation/weather. If it's ice, you can run the unit with the glass off until the heat melts the blockage.
Posted on Dec 02, 2012
Therinnaiguy
  • 1420 Answers
SOURCE: No Heat-Inducer motor doesn't start ?..humming noise only..warm..
Bad inducer motor most likely. Check the leads and plug. If it just homms, it is stuck. Check to see if the drain hoses are free of moisture. Can you get to the shaft to spin it to see if it is free?
Posted on Dec 08, 2008
detox101
SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Posted on Jan 14, 2009
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
  • 2463 Answers
SOURCE: Martin gas heater with logs flames hot but hard to see.
Hi do you the make and model
Posted on Feb 12, 2010
  • 2463 Answers
SOURCE: I have a monessen vent-free
take a tube blow out pilot jet when off or use can of air should work
Posted on Nov 12, 2010
How do I override a nonfunctioning remote for my Valor gas fireplace?
shut off the gas valve, and then call a qualified technician
Apr 20, 2014 | ACE Heating & Cooling
My Valor fireplace won't turn off with the remote
Easy turn the gas cylinder close then its off,Or you could have a faulty control valve or thermo couple .Thermo couple is the small device looks like a probe to detect heat this is normally directly in the small pilot flame.The pilot flame if not burning will not open the control valve for the other burners to come on.If the other burners come on but do not go of when turned off. then need to check control valve.
Jan 06, 2014 | Televison & Video
Gas ignites with lever ignition but when lever is released gas cuts out
I can't tell what kind of appliance you're talking about.... but, here's what I know.. This "lever" you're talking of kind of stumps me, but try, after the gas lights, to hold the lever in the position you had when you lit the flame. Hold it on for about a minute... then release it... and see if the flame will remain going. If you can't keep the flame going "no matter what", you probably need to clean or replace the flame sensor.
Nov 14, 2013 | Valor Toys
Heatman, please help: Bake burner cuts out
Try cleaning the pilot nozzel with compressed air. I had the same problem with my fireplace.
Dec 09, 2012 | Ovens
Flame does not flicke in my electric fireplace
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Nov 28, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Bought valor homeflame super off a friend gas fitter won't fit until he gets istruction maual
google valor you should be able to get manual off there site you will need model number
May 02, 2010 | Heating & Cooling
HEF33 flame not turning over, power OK and heater working, all lights on. Flame speed at stop and will not move.
i have pyromaster hef33. flames on my stop moveing also. i took off front glass and logs. then i got a long metal tool and.then i tap the moter that moves the rod that makes the flames move.and also i move the rod back and forth alittle bit. i did put just bit 3in one oil on both ends of the rod. so far its doing better now . this may help some one or it not. i thank the moter or rod was sticking
Jan 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Dryer runs ,heats up flame goes off after 30 secs won't relight
Seems to be a problem with the bas valves....you shouldve seen them in front of ignitor...will show similar signs of ignitor. part#306106 AND 306105. come off easily with a few screws and just slide over valve assembly.
Jun 08, 2009 | Whirlpool LER4634J Electric Dryer
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
