Question about Kenmore 19110 Computerized Sewing Machine
Recieving a L6 code when trying to sew a button hole
The machine is brand new and this is the first time I have used this machine. It give 3 quick beeps and the L6 code displaying in the window. It always stops in the exact same place. It completes the first straight line accross and then approximately 6 stitches down the first side before the it stops, beeps and shows the code. I have played with the tension, and everything I can think of ....nothing works. Any ideas?
You need to pull down the buttonhole guide which is the BLACK tab toward the back. I had this problem too, because I was pulling down the white tab in the front.
Posted on Feb 11, 2009
Why is my White 1866 dropping stitches not picking up the bobbin thread when I am doing zigzag stitches?
Be sure you are using a brand new needle that is compatible with the thread and fabric you are sewing. Otherwise, your machine is most likely a bit out of time. Search for sewing machine timing or take it for service.
Feb 25, 2017 | Sewing Machines
I have a brand new singer stitch sew quick machine, apparently the machine works, when i use a cloth to try stitching it does not make any stitches
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Apr 03, 2014 | Singer Stitch Sew Quick Sewing Machine
My sisters singers brand new Athena sewing machine she just started jusing about 5 or 6 times just stopped picking up the bobbin thread and sewing thread in the material. It is just leaving holes in
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Jan 14, 2014 | Brother CS-8150 Computerized Sewing...
Singer sewing machine will not pick up bobbin thread, and when sewing it just makes holes in material without the thread staying in.
The needle is damaged, in backwards or not fully up in the machine, or the bobbin is misthreaded.
Try a new size 12/80 needle, flat back of the needle to the back of the machine, rethread top and bottom from scratch, and see if that makes a difference.
Jan 11, 2014 | Singer Sewing Machines
What does the code bL or 6L mean when I am trying to sew a button hole?
bl means you need to pull down the buttonhole lever on the left hand side of the needlebar
Jan 14, 2013 | Janome Magnolia 7330 Sewing Machine
Machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Apr 16, 2009 | Sewing Machines
Button holes
Slightly reduce upper thread tension. Good Luck
Mar 29, 2009 | Singer 1120 Mechanical Sewing Machine
Button Hole Beeping on 7462
Yes frustrating issue this one. I discovered that you need to pull down the retractable button hole guide found behind the needle threader (not visible when you are sitting at the machine).
Hope this helps, happy sewing!!!
Sep 06, 2008 | Singer 7462 Mechanical Sewing Machine
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Kenmore 19110 Computerized Sewing Machine Logo
186 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
