Question about Maytag Kitchen Ranges
I have a maytag flat top stove that heats completely unevenly. It's really hard to find a simmer temperature, and one in particular is super hot until you put it all the way on low. Any help would
Cool and Radiant Electric Range. It's about ten years old.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 02, 2012
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
ranger25
  • 72 Answers
SOURCE: my electric glass top stove won't heat up?
They have a thermal overload resistor in the burner itself and they have a propensity to burn out, or it could be the infinite switch. You will have to check resistance across the leads that correspond to each pinout. You can find this out by backtracing the wire to each terminal on the block. Replacement of either part is the only option, there are no safe alternatives to repair them. Hope this helps. BTW, you can go here for parts.
www.appliancepartsdepot.com
Posted on Jan 28, 2008
SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Posted on Feb 19, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
My Maytag stove. I know it's normal to feel heat from the vent on the stove top when the oven is on. But the temp of the heat escaping is sooo much hotter than it used to be. Do I need a fix ? Model...
The heat from your vent should be a little lower than what the oven is set at. So I doubt if you have a problem but you might want to take some temperature measurements to see.
Sep 07, 2011 | Ovens
The top of my maytag gas range get SUPER hot
The repair man probably checked to make sure the various parts were working i.e. the burners light and burn properly. The fact that it seems to be dependent on whether or not there are pots over the burners makes me think that somehow they are set too low with respect to the top of the range. If that were the case, the heat would not be able to flow up and out but would rather build under and transfer into the range top. Keep in mind however that ranges in general be they gas or electric put off a lot of heat and metal loves to conduct heat, so the top will definitely heat up. But if this is beyond normal heat, I would look for something that is allowing the heat to transfer to the top when you have pots there.
Dec 16, 2009 | Maytag MER5775Q Electric Kitchen Range
Low Flame is too high to simmer
there should be a regulator between the stove and the main gas line .unscrew lock nut turn valve clockwise to turn gas down. turn down too far , will turn gas off.
Jul 30, 2009 | Kitchen Ranges
Simmer is too hot
one way is the orfice that goes inside the burner.some have a little screwin the knob shaft to ajust.if no screw its the orficc.theres a tech sheet that will give you more detail about that on that stove.bottem drawer area or back.also so ranges have orfices on them in the back also.God bless,tom
Jan 01, 2009 | GE 36 in. Profile JGP962 Gas Cooktop
CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Nov 10, 2008 | Kitchen Ranges
We have a Whirlpool electric ceramic stove top. All of a sudden we are unable to regulate the heat i.e. it stays hot all the time and therefore cannot simmer anything.
Its hard to suggest anything since you did not give us the model number of your range and which of your unit is defective
regards
Sep 10, 2008 | Whirlpool Kitchen Ranges
Gas range top burners too hot
Feb 05, 2008 | Kitchen Ranges
Heat too hot on LO simmer burner
take the knob off, and take a very small flat screw driver, and inside the valve, turn it to the left, go slow, and you'll see that it goes down, there ya go
Jan 13, 2008 | Maytag MGC5430 Gas Cooktop
Kitchen Ranges Logo
50 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
