Question about Pioneer Audio Players & Recorders
Pioneer receiver speaker b Left
I have a Pioneer vsx-821-k. The left side of speaker won't B won't produce any sound. We've tested all the speakers and wires and clearly, the plug in does not work. Please advise.
  • Tracey WHitten Dec 05, 2012
    Yes, that's correct. Any suggestions on fixing it?
    Problem Solver:
  • 19 Answers
The output transister is probally blowin for the left side,
Posted on Dec 03, 2012
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
SOURCE: Pioneer SX-750 Old School Need Help
Check the speaker wire. Sometimes it can just be loose in the terminals and cause distortion. I have had the problem before.
Cheers!
DellMan94
Posted on Jan 12, 2009
  • 30 Answers
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Posted on Apr 02, 2009
SOURCE: pioneer vsx-305 need wiring diagram for this
I have problem with connecting subwoofer to receiver.
Posted on Jan 28, 2010
Pioneer VSX-D307 has no sound from right front speaker.
Did you connect a known good speaker to the amplifier's right front output connections? Make sure you also have known good wires for the front right as well. Make sure balance control is set to the middle and not just to the left.
Aug 22, 2016 | Pioneer VSX-D307 Receiver
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
Pioneer vsx 821 k
Check in the setup menu to see if the volume limiter has been set by mistake
May 27, 2013 | Audio Players & Recorders
Owner's manual for Pioneer Model: VSX-821-K|
Hi Arthur,
Download the manual here
Hope this helps.Thanks!
Please rate this answer.
Dec 09, 2011 | Audio Players & Recorders
Pioneer VSX-818V receiver. less than 3 years old. Getting no sound out of speakers all of a sudden. Signal to TV is ok just no sound. What component drives the sound out to the speakers? The sound stopped,...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 27, 2011 | Pioneer VSX-818V-K Receiver
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
Receiver issues- VSX-816 K
the speaker is not broken, its the receiver, cuz i have this model, and now it just flashes a blue light on the power button and it wont turn on. I had the same problem as you before it did wat is doing now. i ran the speakers on my vsx-3900s, and they didnt mess up at all, they only did it on the vsx-816
Apr 06, 2010 | Pioneer VSX-816-K/S Receiver
Pioneer VSX-5300; sound cutting out
try open each speaker test may be speaker or wire short....if all ok check pcb solder side....
Dec 31, 2009 | Audio Players & Recorders
66 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
