Question about Toshiba Computers & Internet
Toshiba laptop with windows vista disconnecting from internet every few minutes. dial up service. no phone or any other devices connected. modem/ wires fine. i have reset settings many times. it is n
Constantly losing DSL connection. Nothing else connected..no phone no TV no other computer. Only my laptop. Running with windows vista. Problem getting worse.
  • Toshiba Master
  • 7,627 Answers
If the modem and line in are OK, change cables and clean Phone line jack connections with alcohol. Look for oxidation on pins or bent, damaged pins.
Posted on Dec 02, 2012
  • saucysusan8
    saucysusan8 Dec 02, 2012
    The cable is new. Same problem with old cable. It is a driver problem but I can't seem to download the software needed to fix it.
5 Suggested Answers
SOURCE: Toshiba Satellite M105 - will not connect to the Internet...
nightshifter
That's where it's headed.
I thought I overlook something.
Thanks
Posted on Mar 13, 2008
clickman
  • 93 Answers
SOURCE: Having Limited Connectivity On My Vista Laptop When I Use Dial Up Connection
It may be the speed of your connection....dial up...
Try connecting somewhere else and see what you get...
If that does not work, check your dial up settings....
Posted on Jul 20, 2008
  • 7 Answers
SOURCE: have a Toshiba Satellite L505D-S5983 Laptop with
80 - 100 ft without walls..try changing the place of the router...
Posted on Sep 23, 2010
Testimonial: "Thank-you. I will try that."
mpcheeseman1
  • 1400 Answers
SOURCE: Lenovo G550 running Windows 7 won't connect to
Hello
Wow youve done almost everything here.How about the firewall? is it blocking any connections?
Next,Go to control panel,network and sharing center.Look and see if the pc or laptop in question is on the same network,meaning home or public.
Set all your machines to the same network.Either home or public.I do know this has been a win 7 problem.
Posted on Mar 11, 2011
I have constant trouble with my toshiba laptop using windows vista constantly losing the dial up internet connection.
If your telephone line may have disturbances from any electronic devices at any point then this could happen. Try moving other devices especially speakers, mobile phones and TV near the modem. Does your laptop wifi enabled one? Do you use telephone in that line? If so use a line filter with two out. could you give your laptop model no.? There is not enough details to pinpoint the problem
Dec 01, 2012 | Toshiba Computers & Internet
I am using windows XP in my Toshiba laptop sattellie Series. I am unable to make any new connection to connect to Internet.
That is because the L300 does not support XP.
If you reinstall Vista, all will be well again.
XP is no longer supported even by Microsoft as it is over 10 years old and now obsolete.
Hope that helps.
Jan 23, 2011 | Toshiba Satellite Pro L300 Notebook
TRENDnet TFM-560U dialup modem disconnects after 15-20 minutes?
Make sure you don't have you modem properties in control panel set to auto time out or you mail set to disconnect after download.
Dec 16, 2009 | Trendware 56K USB Fax Modem High Speed...
Using HTC Touch 2 as modem for laptop
First of all you need to install the Microsoft ActiveSync (for windows XP) or WIndows Mobile Device Center (for Windows Vista) After that open the Internet Sharing, select USB and click on Connect. Now connect your USB cable to the Laptop, it shall install the drivers automatically, wait for a few minutes and after that you can use the Internet on the laptop via your phone.
Download ActiveSync:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-download.mspx
Download Windows Mobile Device Center:
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx
Please rate.
Oct 29, 2009 | HTC Touch P3450 Smartphone
I have a Toshiba Satellite A305-s6916,modem is not connecting
Get a external modem and try that, But first try and connect network.Start- Control panel , delete current Network and make new one. If its Vista it will repair itself. just follow the bouncing prompt
Jul 30, 2009 | Toshiba Satellite X205-SLI1 Notebook
Modem
Found this after some deep looking from blackberry itself: Good Luck
A BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
Summary of Tasks To set up a tethered modem, complete the following tasks:
  1. Install BlackBerry Desktop Software 4.1 or later (one time only).
  2. Set up the Internet access point name (APN) (one time only).
  3. Configure dial-up networking (one time only).
  4. Connect to the Internet using dial-up networking.
Task 1
Install BlackBerry Desktop Software 4.1 or later on your computer.
When you install BlackBerry Desktop Software, the drivers that allow the BlackBerry smartphone to communicate through the Universal Serial Bus (USB) port and virtual communications port are installed. The standard modem, which is used by dial-up networking, is also installed.
Note: If upgrading your BlackBerry Desktop Software from version 4.0 to 4.1, the required virtual communications port and standard modem might be removed during the upgrade process. If this is the case, re-install the BlackBerry Desktop Software 4.1 or later and choose the Repair option to re-install these components.
Task 2
Set up an Internet APN.
  1. Click Start > Settings > Control Panel.
  2. Double-click Phone and Modem Options.
  3. In the Phone and Modem Options window, click the Modems tab.
  4. Select Standard Modem and click Properties.
  5. Click Change Settings.
  6. In the Standard Modem Properties window, click the Advanced tab.
  7. In the Extra initialization commands field, type the following: +cgdcont=1,"IP","<your Internet APN>"
    Note: The following is applicable for T-Mobile® customers only:
    The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
    Note: If you do not know your Internet APN, or if you do not have an Internet APN, contact your service provider.
  8. Click OK.
  9. In the Phone and Modem Options window, click OK.
Task 3
To configure dial-up networking, complete the procedure that is appropriate to the operating system you are using:
Windows Vista
  1. Click Start.
  2. Select Connect To.
  3. Click Setup a connection or network.
  4. Click Setup a dialup connection.
  5. In the Dial-up phone number field type *99#.
  6. Type the user name and password provided by your service provider.
  7. In the Connection Name field type BlackBerry.
  8. Click Dialing Rules.
  9. Make sure the profile created in Task 2 has been selected, and then click OK.
  10. Select Connect to establish an internet.
Note: For instructions on connecting a computer to the Internet using a BlackBerry smartphone with CDMA as a tethered modem, see KB04664.
Windows XP operating system
  1. Click Start > Settings > Network Connections.
  2. Double-click New Connection Wizard. The New Connection Wizard opens.
  3. Click Next.
  4. Select the Connect to the Internet option. Click Next.
  5. Select Set up my connection manually. Click Next.
  6. Select Connect using a dial-up modem. Click Next.
  7. If the Select a Device screen appears, select the Modem - Standard Modem check box. Click Next.
  8. In the ISP Name field, type a name for your connection. Click Next.
  9. In the Phone number field, type *99#. Click Next.
  10. Indicate which users will have access to the connection. Click Next.
  11. Type the user name and password provided by your service provider. Click Next.
  12. Click Finish.
  13. In the Connect window, click Properties.
  14. In the Properties window, verify that Modem - Standard Modem appears beneath the Connect using heading, and then click Configure.
  15. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK. In the Properties window, click OK.
Windows 2000 operating system
  2. Double-click Network and Dial-up Connections. Note: The following is applicable for T-Mobile customers only:
    Under the networking tab in the properties window for the dial-up connection, clear the Enable LCP Extensions check box, as well as all check boxes beneath the PPP Settings window.
  3. Double-click Make New Connection. The Network Connection Wizard opens.
  4. Click Next.
  5. Choose Dial-up to private network. Click Next.
  6. In the Phone number field, type *99#. Click Next.
  7. Indicate which users will have access to the connection. Click Next.
  8. Type a name for your connection. Click Finish.
  9. In the Connect window, click Properties.
  10. In the Properties window, verify that Modem - Standard Modem is selected, then click Configure.
  11. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK.
  12. In the Properties window, click OK.
Task 4
Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Connect the BlackBerry smartphone to the computer.
  2. Open BlackBerry Desktop Manager.
  3. Click Start > Settings > Network Connections > <name of your new connection>.
  4. Type the user name and password provided by your service provider.
  5. Click Dial.
Apr 07, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Cannot connect to internet
Check the hardware using the device manager to see if there is an issue with the drivers. You can hold the windows key and press pause break and device manager should show up. Look for any ! ? or other marks on the list.
Mar 25, 2017 | Toshiba Satellite A135-S4407 PC Notebook
Lack of dial tone with modem on Toshiba Satellite Pro L20
just go to the modem properties and you will see a option there called wait for dail tone if u see tick mark there please remove the tick mark your problem might get solved. if this doenst work then check up ur cable and the modem
Feb 14, 2009 | Toshiba Computers & Internet
Dial up Modem
Dial up modems have 2 phone line connections side by side in the back of a desktop, one is for the wall, other is for your telephone. Laptops have just one phone line connector. Look closely at the little symbols by the connection holes. If you don't have one, Modems (internal or externally mounted), are on eBay, buy a 56K with drivers on disk for your operating system. A few modems can be installed using Windows default drivers (drivers are software operating programs that tell your computer how to regulate and operate a device).
Sep 03, 2008 | Fujitsu Siemens AMILO Pro V1000 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
