Question about Samsung BN59-00599A Remote Control
Whats the program you have to put on the tv to start
    Top Expert:
  • Samsung Master
  • 42,945 Answers
You have a Samsung remote control and you want to use it with a (?) TV. Is it a Samsung TV?
Posted on Dec 02, 2012
What is the code for I can no what channel im on and for my letters and numbers to show on my 7"wide screen lcd tv with atsc tuner tv
      Select and highlight INPUT CONFIGURATION and press ENTER. Using the left/right arrow buttons, select Antenna or Cable as desired, then select DONE. Press the CH RTN button to go back to the TERRESTRIAL menu. Select START SCAN to begin the Channel Program.Aug 7, 2013
      How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
      forums.toshiba.com/t5/Televisions...To-TV...Program-Channel.../345660
    Feedback
    LG LED TV won't show program information or channel name ...
Jan 13, 2016 | Televison & Video
How to see video
That question is a bit vague! If you mean watch a DVD video on your computer, you just put it into your DVD player and it should start.
If you mean watch a catchup TV program just Google the channel and program you want to watch. When you start, it should start running straight away, or give you instructions what to do
If you need something else, come back and ask!
Apr 03, 2015 | Computers & Internet
How do I program a ge remote control for a Sanyo tv
Have You done on the Sanyo site to pull down your TV model's manual so You can find out what codes to use to program the remote control? Or go under Google and put in your TV model in the search block and include manual or codes for programming a ge remote and see if this doesn't work. I've done this and have had great success.
Oct 05, 2014 | Televison & Video
Just says no program information AV1 and no signal. Tried removing red, yellow, white wires and turning it on and off again. This problem occured after I hooked up my camera to the TV. What is the...
After a month or more of seeing "No program information" on my 32" LG TV and not being able to solve it I recalled that I'd unplugged the TV around the time the problem started.
When you first set up the TV you have to go into the settings and tell it what TIME ZONE you are in. Apparently when the TV is unplugged it erases the time zone information.
I went into the settings a few minutes ago and told the TV that I was in the Eastern Time Zone. Voila!, the TVGOS (i.e. the program information) immediately started working again.
If you're getting "No Program information" check your TV's setup settings.
Hope this helps!
Jan 09, 2011 | LG 42LC2D 42 in. LCD HDTV
My digibox diVision VDC 4700 PVR works in all other ways but refuses to record a tv-program. It starts recording, but then it says that have to check the connection and drops recording. I don't get it...
first confirm your set have option for recording if yes then simple use tv monitor out on back side of tv set.In put your recorder and record.
Oct 17, 2010 | Televison & Video
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
SONY TV KV-XR29M61 GOT WET IN THE RAIN,WHEN TURNED ON, ALL THE CHANNELS AND PROGRAMS STARTS TO CHANGE AFTER A WHILE. WHAT COULD BE THE PROBLEM.
Don't leave the tv in rain!!!!!!!!!!!!!!!!!!!!!!!! Leave it off let it dry out and try it again in a day and don't put it in the rain.
Apr 24, 2009 | Sony Televison & Video
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Daewoo tv/vcr combo ccodes
Hi here are some codes I have 0278 0624 If they dont work try programing the VCR
first then the TV. To program the VCR put a tape in and put it on play after you put
the code in hit the power button the vcr should stop playing. If that works then program the TV.
Some TV/VCR combo's require two codes. Good Luck
Mar 02, 2008 | Daewoo DVQ9H1FC 9 in. TV/VCR Combo
Programming Remote
turn your tv on then hold the tv button down until all the little buttons on top begin to blink one at a time. it's about a 10 count. then the tv light will remain on while the light is on put in the code and the light will blink after the code is entered. if it is the right code your tv will turn off.
Sep 23, 2007 | Motorola DRC450 Remote Control
Samsung BN59-00599A Remote Control Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
