Question about Garden
Chain saw not working right
Chain saw idles when choke is at half way, dies when the trigger is pulled unless you butterfly it
  • 2,239 Answers
Running too lean, replace the fuel filter in the tank as a start.
Posted on Dec 04, 2012
  • 2692 Answers
SOURCE: poulan chain saw won't stay running
Carburator needs to be removed and cleaned.
Posted on Feb 15, 2009
  • 360 Answers
SOURCE: saw stops when i give it gas.
  • plugged fuel filter
  • cracked/loose fuel line allowing air (instead of fuel) into the carburetor.
  • poorly fitting fuel cap
  • plugged or disconnected/broken pumper line
Posted on Feb 16, 2009
  • 3519 Answers
SOURCE: it starts up, but when trigger is pulled, the
Most saws have a safety or anti kickback brake. Yours might have tripped. There is a guard in front of where your left hand holds the saw. With the saw NOT running, pull the guard HARD towards the back of the saw. It should move a bit ant you may hear a click. The chain should now move. If the chain moves easily when the saw is not running, but doesn't move when you rev the saw up, the clutch is broken.
Posted on Sep 10, 2009
  • 8404 Answers
SOURCE: Chainsaw will start and idle if choke is pulled
Let it warm up first ...
Posted on Oct 05, 2009
Biggdex35
  • 333 Answers
SOURCE: I have a McCulloch MS1636NAV chain saw. The engine
Its either sucking air in throgh a loose connection in the fuel line or the carb is stopped up. Take it apart very easy so you don't rip any gaskets, and clean evertthing with a can of compressed air blow all the tubes out real good. You may have to get a carb kit it that does not work.
But that sounds like what it is, running out of gas when you let more air to it.
Posted on Oct 05, 2010
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Bought a McCulloch M3414 started okay yesterday wont start today maybe I flooded it, pulled cord so many times
1. set on/off switch to on, 2.prime it first, push the bubble about 6x 3. pull the choke all the way out, 4.pull trigger and string simultaneously 5. push in choke halfway try again, pull choke back out and etc. should start after repeating steps 4 and 5 3x or 4x when it does start, pump the gas at half choke then let it idle untill it stops push in choke all the way and it should start. don't forget to check the safety bar in front of the handle usually works with most gas operated tools
Jan 04, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Mar 19, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
The choke on a Poulan Chain Saw that I just bought will not stay out to start it.
There are two types of choke systems, the basic choke has a ball and spring in the carb body which locks the choke either in or out, the other type is connected to the half throttle position, once pulled out it stays out, however if you lift the throttle trigger it will go back in on its own, queation, are you holding the throttle trigger whilst trying to start it, if so this is why it will not stay out, if this is not the case, pull the choke out with a little more force, it may be just not coming out enought to lock.
Feb 28, 2011 | Poulan Pro Chain Saw 46cc 20"
Wont stay running. it idles kinda high. stays running with the choke on. pull the trigger 2 giv it gas it dies.
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. The idle speed screw (turned CCW) will slow the engine down. Hope this helps!
Nov 08, 2010 | Poulan Pro Chain Saw 46cc 20"
How do I start rental model 96.
Place the saw on full choke with the switch on. Pull the rope until it fires. Place the saw on half choke, and pull again, and it will start running. Half choke should release as soon as you hit the trigger.
Mar 23, 2010 | Husqvarna Chain Saw 20" Bar
Do not know how to start my chain saw
First the chain should be tightened properly before starting. When you pick up on the chain midway of the bar it should pull away from the bar about 1/4". The proper mix of oil & gas in the fuel tank & Oil for the chain in the oiler tankk is needed, If so, locate the on/off switch & turn it to "on". Pull the choke lever out. Depress the throttle trigger & engage the latch for the trigger. With the saw held firmly in place, pull the starter rope until the engine hits. Then move the choke to half & pull till it cranks. move the choke lever to the run position.
Aug 19, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Starts and then runs wide open.
SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
May 19, 2009 | Husqvarna Chain Saw 20" Bar
Need carb h/l ajustemts and idle controle ajustment
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
May 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
