Question about Linksys Computers & Internet
How do you add additional router? - Linksys Computers & Internet
  • 78 Answers
It depends , if u want that router in the same network which ur getting previous one the..
1. open the router2 page .disable the dhcp server. change the lan ip according to the first router.example if getting 192.168.1.2 the change ip to 192.168.1.10 of the router2 n save settings.
2. connect ethernet cable from lan port of the router1 to lan port of the router2.
3. power cycle the network.
And if you want to make to different network....
1. open the router2 page ,change the lan ip to 192.168.8.1.save settings.
2. connect ethernet cable from lan port of the router1 to wan port of the router2.
make sure that whatever the settings u want to do on the router make ur pc hard wired first.
Posted on Dec 23, 2012
How to start and connect my belkin basic150
Assuming the modem is on and running.
  • Plug in the Ethernet cable from the WAN/Uplink port on the router to the Ethernet port on the modem
  • Power on the router.
  • Your done.
Additionally you can add wireless security and a password so unauthorized people can use your network for free.
The router by be preconfigured for this already.
Jan 13, 2013 | Computers & Internet
I need more ethernet ports on my router so I can connect another computer but I do not want to buy a new router. Can I put an expansion piece into my motorola 3347-02-1022 router? One that will add one or...
1. you can add a multi-port switch to one of the port on the router. this will give you additional ports. Beware of too many it will take up bandwidth depending on you broadband speed.
Sep 09, 2011 | Computers & Internet
How do i add aditional routers to gain access to the network from a detached shop using wireless
Connect your addition routers to NetGear WGR614 Wireless Router port ,Use NetGear WGR614 Wireless Router as a switch ....
Check if it works
Thanks
Snadeep
Mar 08, 2011 | NetGear WGR614 Wireless Router
Wireless-G WRT54G Router: how to add a ipod...
Just select the name of the router in ipod settings and enter the wireless key if one is configured. If your router has enabled MAC blacklisting or whitelisting you need additional steps, please comment if you need more advise.
May 16, 2010 | Linksys Wireless-G WRT54G Router
Linksys Hub
Yes you can.You should have no problem doing that.
Jan 25, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Need to add additional computers. How?
try this connect all computers then unplug router power cord for 15 seconds then plug it back in the router should now read all computers and be connected this works on all brinks and links key routers. I hope this helps you let me no.
Aug 03, 2009 | Linksys Wireless-G Broadband Router
How do I port forward my router (netgear dual range -N- wireless)
You log into your netgear and under firewall you add the port exception to the list.
If you need additional help tell me the model of your netgear router.
Regards
Dec 18, 2008 | NetGear RangeMax Dual-Band Wireless-N...
Net gear router won't install properly and will not let me use the internet
You may want to try:
  • If both your router and modem have DHCP features enabled, disable the one in the modem;
  • manually set the Internet/WAN IP add of the router to follow the IP add of the modem;
  • manually set the default gateway of the Internet/WAN side of the router to use the IP add of the modem;
  • set the PCs connected to the router to automatically obtain IP adds.
  • verify that the PCs uses as their default gateway the IP add of the router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 12, 2008 | NetGear RangeMax WPN824 Router
Belkin wireless router
Your Belkin router is normally configured to get a dynamic IP Add from your Internet provider unless otherwise configured. Most ISP's network where clients/subscribers connect (through DSL) has a DHCP server that hands out this IP adds. If your router keeps on changing its WAN IP add, it may presumably be because:
1. Your router keeps on rebooting or powering on/off and everytime it turns on, it is given a new IP add;
2. Your ISP's DHCP server keeps on renewing its lease on the IP add given to your router.
Corrective measures would entail:
a. Do a full hard reset of your router and go through the installation setup again. Of course this would revert all settings/configuration to factory default; and/or
b. Contact your ISP and explain your concern.
In some cases, the router's MAC address has an issue that the ISP's DHCP is keeping a hard time recognizing it. this can be corrected with a firmware update.
Hope this be of help/idea. Pls post back how things tunrs up or should you need additional information.
Good luck and kin regards.
Feb 03, 2008 | Belkin (F5D7230-4) Router (587009)
Router
Do you have your wireless on in the computer. I need more info, you should be able to go into your network setting and enable your wireless there, or in the control panel also under wireless networks, Try that and if it don't work give some more info plz. Thanks
Dec 24, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
