My toshiba satellite l505d-s5986 has black screen and won't boot but fan is working
MY TOSHIBA SATELLITE L505D-S5986 HAS A BLACK SCREEN AND WON'T BOOT BUT THE LIGHT FOR THE HARD DRIVE IS ON AND THE FAN IS RUNNING, WHAT COULD BE THE PROBLEM?
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Dec 02, 2012
cory_l_gage
SOURCE: toshiba satellite l505d
unplug laptop and remove battery. Take out both memory sticks and locate on the motherboard under sticks two points marked with ***. Replace one memory stick, plug ac adapter back up and while jumping the two points at the *** (use paperclip, flathead screwdriver or other metal object to connect the points) power up computer. This, if done properly, will reset bios, removing password.
Posted on Jun 14, 2012
big_al_1982
  • 95 Answers
SOURCE: toshiba satellite L505D GS6000 mouse freezing
reinstall the driver for the mouse touchpad
Posted on Feb 23, 2010
  • 3 Answers
SOURCE: Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Posted on Aug 16, 2008
  • 452 Answers
SOURCE: how to replace lcd screen for toshiba satellite
This guid will give you an idea on how to replace the LCD screen on your laptop.
http://bootmylaptop.com/how-to-replace-lcd-panel/
Posted on Dec 18, 2010
  • 1606 Answers
SOURCE: Toshiba satellite l505d-s5007 Toshiba satellite
I don't think that's available on laptops; I've never seen it on Toshiba models. There is usually a small battery to save BIOS info and keep the clock going when the main battery is out. It's either under the keyboard or near the memory or wireless card compartment. Remove the main battery and leave the adapter unplugged. Open the compartments and look for a a connector with just a red and black wire connected to it - if you see it going to a coin cell, that's the one you want. Unplug it and wait ten seconds. Plug it in and put everything back together. If you got the right connector, your computer will probably go straight to BIOS and ask you to set the time and date.
Posted on May 02, 2011
HOW DO I RESET MY TOSHIBA SATELLITES BIOS PASSWORD AFTER I FORGOT IT?
take out the internal cmos battery for a while. or there are jumpers close to it or by memory u can short. failing that but up from cd if poss and use cmos reset software
Jan 02, 2016 | Toshiba Satellite L505D-S5983,...
Speakers keep going on n off
Try the latest audio driver...then do an audio diagnostic by going to run then type dxdiag. Hope this helps
Mar 10, 2015 | Toshiba Satellite L505D-S5983,...
Toshiba Satellite L505D-S5983 Sorry if this is choppy but I kept getting use only legal characters and I can't seem to figure out what it is referring to I looked into the reflow process but when I...
The GPU in every laptop is soldered in place, if you have a lot of experience with reflowing then you can try to pull the GPU and replace it but a lot of the time it's actually more cost effective to get a replacement MB and sell the one that's having issues. Because the GPU may not be the only part that has gone out or it maybe another part that has gone out and is keeping the GPU from powering or outputting signals
Oct 29, 2013 | Toshiba Satellite L505D-S5983,...
There is a popup message frequently stating taht "Windows detected a hard disk problem. backup your files immediately to prevent information loss, and then contact the computer manufacturer to determine if...
Click on "Start". Click on "Computer" Right click on "C" drive. Click on "Properties at bottom of menu. Click on "Tools" Click on 1st of 3 options available, check both boxes to scan complete hard disc, this will run a 5 stage correction program upon reboot.
Dec 18, 2012 | Toshiba Satellite L505D-S5983,...
Black screen even on ext monitor
External monitor confirmation means that you're not getting anything out. If there truly are not words coming up, telling you what's up, then you're probably looking at a bad logic board. It could be bad video, but if nothing, not even a fan, is spinning up, then you're not getting power across the system. Check all your power connections and inputs, but I'm leaning towards a bad system board.
Nov 17, 2012 | Toshiba Satellite L505D-S5983,...
How can I adjust the microphone?
The microphone can be manipulated with the sound software. Right mouse click on the loudspeaker symbol and select recording devices.
Oct 31, 2012 | Toshiba Satellite L505D-S5983,...
How do you remove keys from a laptop?
you need to use something to pry them up, do so slowly and easily.
Oct 09, 2012 | Toshiba Satellite L505D-S5983,...
My battery won't charge
There's not much that can be done except return the adapter for replacement. But first, are you sure your car's cigarette lighter works ?
Mar 28, 2011 | Toshiba Satellite L505D-S5983,...
Computers & Internet Logo
1,579 people viewed this question
David Payne
David Payne
