Question about Samsung Silver 13.3" Ultrabook NP530U3B-A01US Laptop PC with Intel
Can't get the headphone sound working from the laptop
When i plug the earphone/headphone the sound just still come out in the speaker. Do i need to download some driver or something??
  • Samsung Master
  • 27,725 Answers
The Laptop has 3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Hope this helps.
Posted on Dec 01, 2012
When I plug my earphones into the headphone jack, the sound still comes through the laptop speakers, not the earphones
Forgive if this is too simplistic, but 2 suggestions before digging into the laptop: Confirm that you are plugging into the headphone jack and not the mic jack. Second, try a different set of earphones - sometimes buds with a mic capability like for a cell phone don't respond the same as pure headset.
Nov 15, 2014 | Samsung 550P5c 15.6 Inch Laptop - Black...
No sound without headphones? lg dp173g dvd
Open the Control Panel , select Sounds, choose the speakers, Apply. Unplug the headphones and reboot.
May 12, 2013 | Computers & Internet
I'm not getting any sound out of the speakers. I have sound through my headphones but cann't get anything out of any speakers.
If you can hear the sound from the headphone(earphone jack), the fault is between the headphone itself or the speakers. Check the continuity of the speakers(voice coil) using the multimeter to determine if it is faulty or not.
If you've confirmed that the speakers are not the issue here, you may spray an electrical contact cleaner to the earphone jack of your unit while pulling and inserting the headset plug to clean the contact from dirt build-up inside. You may also replace the earphone jack with new one to back the unit in normal operation.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 18, 2011 | Teac AG-V8060 Receiver
I have a Panasonic Sa-HT930 surround sound system. Plugging in headphones does not turn off the speakers, yet I can still hear sound through the headphones. How do I get the speakers to turn off??
The switch of the main speaker does not engage when you plug inn your earphone it's suppose to turn off the main speaker.you need to clean the contact of the switch of the jack.Open the cover of reciever and go to the earphone jack spray it with a contact cleaner then try again.if the same thing happen replace the jack with a new one.
May 28, 2011 | Televison & Video
My earphones won't work when I plug them into the laptop. When I unplug them, the computer speaker plays sound just fine. And when I tested my earphones on my mp3 player, they worked also. I used them with...
Hi.
Check if sound from laptop speaker is working.
If sound from laptop speaker is not working, go to control panel, check first the audio properties, and ensure that the sound is not muted.
On Vista you have to double click on the playback device to get properties.
audio properties can also be explored starting the mixer by clicking the audio icon located near to the clock.In the example below the audio is muted:
In control panel also check if there is an installed audio device going to device manager.
If the audio adapter is not present , or if the audio adapter has a yellow mark on top, then you will need to reinstall the audio adapter drivers. The drivers are available online, on the laptop manufacturer's website.
On HP, Acer and several other brand models there is also a bag that can affect the use of headphones only.
In that case when you plug in the headphones, you get no sound, or the sound is still reproducedd through the laptop speakers.
The trick to fix this bug is restarting the laptop with the headphones plugged in twice, then removing headphones and restarting again.
If all the above does not work there may be an hardware fault, like a broken contact in the audio jack soldering joints.
Regards.
Apr 14, 2010 | Computers & Internet
Headphone problem
you need to install the earphone driver
Sep 06, 2009 | Compaq Presario 700 470024-192 Notebook
No sound from ear phones of Fujitsu S-series laptop
First ensure that the headphones are working, by testing them on a divverent devices.
Ensure that computer has sound from speakers, if computer has not sound at all , then you need to reinstall audio drivers.
Then restart the computer with earphone plugged in, this solves a bios control related problem.
If still no luck, than you may have a broken solder joint on the Jack socket, in that case the repair must be done by a technician.
Jan 07, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Laptop speakers working, ear phones not working
Check when you plug in the headphone the laptop speakers get off or not also see the audio configuration under control panel sound that you choose digital sound or its having channels system like 5.1 or 7.1 channels you have to configure it to headphone
Jun 29, 2008 | HP Pavilion dv6000z Notebook
Sound problem with Aspire 5570
I had the same problem with my Acer 5570 and I just fixed it. What I did is to go to Control Panel > Sounds And Audio Devices >Hardware >On Devices click on Reatek High Definition Audio >Click Properties > On Devise Usage choose the option Do not use this devise (disable) > click OK >then plug in your headphones, click on Realtek High Definition Audio properties again and click on Enable Devise **with the headphones plugged in**. It worked for me.
Sep 03, 2007 | Acer Aspire 5100-5480 Notebook
Samsung Silver 13.3" Ultrabook NP530U3B-A01US Laptop PC with Intel Logo
301 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
