Question about Whirlpool duet Washing Machines
My whirlpool duiet dryer sounds like it is rubbing on one side
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 02, 2012
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
MY Whirlpool Cabrio Gas dryer is making a chirping sound that comes and goes WGD6600vw1?
Likely you have a part inside the machine where metal is rubbing metal. Someone must take the machine all apart and look for where paint has rubbed off, or shiny metal is showing where the problem is. Be blessed.
Sep 24, 2013 | Maytag SDG3606A Gas Dryer
Whirlpool gas dryer won't spin and there is a deep humming sound with an electrical odor
Sounds like the drive belt has broken and is rubbing against the motor pulley, which causes the smell.
You can order a new one online, or from Sears. Replacement is a matter of gaining access to the inside of the dryer, remove the old belt, and figuring out how to get the new belt around the drum and motor pulley.
Dec 11, 2009 | Whirlpool Dryers
There is a rubbing/knocking sound whenthe drum
The sound is most likely from one of the wheels the drum rotates on ( usually the lower one ). The bearings wear and sometimes break and completely fall out from center of wheel. I replaced one on mine at a cost of $5.00 from a local repair shop. Just provide brand and model number when calling to see if they have the part in stock. You should be able to access this wheel by removing lower front panel and reaching. Please note I only had to remove the ring pin ( not the bolt ) to remove the wheel. It will be really tight when putting in new one but with a little force you should be able to manage. Before starting you will definitely want to unplug the dryer and still don't touch the electrical wiring or components. Hope this helps as it saved me money.
Nov 14, 2009 | Whirlpool Dryers
Whirlpool Dryer making a rubbing or jingle noise when running
there are wheels under the drum to support it take the front panel off and check those
Jun 24, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer will not start, replaced the electronic control board,still nothing. When we plug the dryer in the control board gets hot.
Sounds like you have a dead short to ground. Check the power cable & look for any rubbed through insulation & make sure the ground is still attached to it's post.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Mar 22, 2009 | LG DLE3777 Electric Dryer
My dryer is makin a bangin noise
there may be a sock or something that got in the out skirts of the dryer lip in side the dryer door either that or the main bearing is gone and you need a new dryer. hope this helped
Jan 05, 2009 | Whirlpool LER4634J Electric Dryer
Dryer makes a thumping sound like it is out of balance.
if it is less then 6 months old you need to call whirlpool and they will send a tech out
Dec 31, 2008 | Whirlpool GEW9250 Electric Dryer
Old whirlpool mini dryer
Those are front tub supports that keep the tub from scraping.Unless you start hearing a rubbing or scraping sound your dryer is ok.Just keep a ear open for awhile for any scraping sound.If you need help in the future with anything ,Im more than happy to help you.
May 24, 2008 | Dryers
Washing Machines Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
