Question about Ranger Radio Communications
My galaxy dx 55 hp is getting hot at right rear on am modulation causing modulation distortion
Geting hot after about 5 minutes modulation on am
    Genius:
  • Ranger Master
  • 1,795 Answers
Does it do his on the other bands also? Check your heat sinks in the area to see if they are also hot.the hottest one is probably going to be the culprit .Now find out what is on the sink and back step from there until you find out why that sink is getting hot.
Posted on Feb 23, 2015
ButtFuzz
  • 463 Answers
SOURCE: it powers up....no modulation ...output power..or
Sounds like the PLL may be toast. Either that, or someone has **** with the wrong potentiometers or tuning slugs in the radio, causing to to no longer resonate on the correct freqs.
Posted on Mar 02, 2009
  • 773 Answers
SOURCE: refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Posted on May 03, 2009
SOURCE: i want to get the most performance out of my
I don't see how you could get more swing than the M-80 modulator. That thing kicks ***!
Posted on Jan 15, 2011
anymhz
  • 500 Answers
SOURCE: galaxy dx 66v off frequency
gal 66 check the 10kHz switch. or you may have a bad cap, or crystal,.. the 33hp2 check the am regulator transistor... is bad or shorted.
Posted on Jan 24, 2011
  • 6771 Answers
SOURCE: after 5 minutes of tx power go down
You may have a bad RF Transistor which is tied to the CB chassis, since it takes several minutes to break down, it is a thermal issue "tough to nail down" probably easier just to change the part.
Posted on Mar 09, 2012
Overheating when keying mike to talk
This is almost ALWAYS caused by a poor antenna connection forcing the radio to dissipate the heat generated when transmitting.
Look for an open connection from your PL-259 plug where it connects to your radio or a dead short to ground in your antenna cable.
Hope this helps
-Steve
Mar 01, 2015 | Galaxy Radios DX-33HP2 Mobile Amateur...
How big of a fuse should my dx 55 hp have
If your rig runs the rated wattage of 12 watts PEP on ssb then a 4 amp fuse is plenty. If you run 4 watts 2 amps. They sell the fuses in Radio Shack 5 for $2.
Feb 14, 2014 | Galaxy Radios DX55HP 10 Meter Radio
Tx rx
the problem you now have is probably going to cost you more money to fix than the radio is worth. Could be a quick simple fix or you could be at it for hours trying to fix it. you will need a scope, frequency counter,watt meter, modulation meter, signal generator, volt meter,distortion meter,and a service manual from
www.cbtricks.com
Jun 18, 2013 | Galaxy Radios DX-33HML 40-Channels Base CB...
Galaxy dx 959not getting out far
MAKE SURE ALL CONTROLS ARE SET RIGHT MODULATION FULLY TO RIGHT CLOCKWISE, R-F GAIN FULLY RIGHT CLOCKWISE. TRY TO GET YOUR MATCH A LITTLE BETTER
Feb 23, 2013 | Galaxy Radios DX 959 SSB CB Radio
take it to a tech , if you have to ask then you are not able to work on it . It is definatly an internal problem.
Dec 01, 2012 | Ranger Radio Communications
Mirage 88.. RX okay TX distorted
try the original mic . If its still distorted then it,s a radio problem.
Mar 14, 2012 | Galaxy Radios DX- 88HL Base CB Radio
Color distortion in an Akai ( Cheaper model Rear Projection tv) I
Ur convergence is dead.Try Tv repair World.com.
Buy a whole convergence board replaced it.
Jan 01, 2010 | Akai PT4799HD Rear Projection Television
It powers up....no modulation ...output power..or receive....just static...galaxy dx 949...
Mar 02, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Radio Communications Logo
70 people viewed this question
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
