The tv is not getting all the cable channels - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Model and brand are needed : Some sets will only go first 47 channels in cable band---if auto program misses some try to direct enter with the remote and then save them in the main menu.
Posted on Dec 02, 2012
Digital channels are not working
If your TV is connected to a "cable" box, e.g. you're using cable TV ... then it is the cable TV box that determines what you can get (based on your cable subscription). Yes, I know that some cable TV and satellite TV service providers will only deliver HD digital channels when you pay an additional (monthly) fee for HD digital channels.
If you plug the cable directly into your TV (i.e. not use the cable box), you may be able to do a channel scan on your TV, to pick up the digital channels ... but you will loose the convenience of using the features that your cable box provides .
Mar 03, 2014 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
I have a mga tv 1988' model cs1946R. I only get 11 channels from comcast my cable provider, my other tv (newer) get all channels. How do I programe my old mga to get more channels( I know i won't get as...
Your old tv does not have more than 11 slots to store channel .
Thats why you are not able to get more than 11 channels .
But let me confirm it .
SAM ANDERSON
Sep 18, 2008 | Televison & Video
The tv s autostore will not retune
i think in your TV...... design ..... is such that once channels are autostored it cannot be retuned ..... so you try this ...... it may work ......... disconnect tv antenna cable ( or local tv channels cable ) from your TV & then click autostoring (auto tunning ) ..... definitely it will scans (search for channels ) ..... but since no cable is connected no channels will get stored ...... but previously autostored channels will get removed ...... so now again connect your antenna cable or local tv cable & then click autostore ...... it will scan for channels .... like this you can retune ....... but remember again you may get same quality of picture which you got earlier ..... if you want better quality of picture you have to use signal amplifier (increases cables signal's strength - then picture quality improves ) .....
Nov 05, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
We have an older model tv and can't figure out how to get the channels to above 69
Channels 2 to 69 are over the air - Antenna - channels.
Channels 2 to 125 (some duplication) are Cable channels.
There should be a way to switch your TV to Cable channels.
If it's really old there may be an Antenna/Cable toggle switch on the back of the TV.
Most newer TV's have a way to get a Menu that you can use to switch between Antenna and Cable. Check on your remote control.
If neither of those you'll probably need to buy a new TV.
Jul 20, 2010 | General Electric JASAV22730 Freeview DTV...
My remote no longer works and I can't get the menu to come up so that I can reprogram my channels and get all of my cable channels. Right now I only get basic cable channels, even though I have full...
You will have to disconnect the TV from the AC outlet for a few seconds(10-20) then reconnect the TV and press power. You should get the start up menu after you get a picture. What you have to do is use the vol up/dn , chnl up/dn keys to select the autoprogram setting after chosing from cable or antenna signal. the enter key should be one of the DVD keys either play or stop or some other key, you'll have to experiment a little with it. There is an owners manual available at retrevo.com in case you need it, but I am posting a brief description stated in the manual on how to do this. Chapter Summary: The STARTING SETUP function makes installing your TV/DVD easily...It leads you the Language selection, TV/CABLE selection and auto channel memory automatically...... Make sure that the antenna or cable TV system connection is made... ENTER CANCEL... Starting setup... Press POWER...The starting setup function begins and the Language setup menu appears on the screen...Press or to select your desired language, then press ENTER...... Users also looked at: Press or to select the “AUTO CH MEMORY”, then press...... 5S10101A [E] (P13-23) 23... This TV/DVD is equipped with a channel memory feature which allows channels to skip up or down to the next channel set into memory, skipping over unwanted channels...In addition to normal VHF and UHF channels, this TV/ DVD can receive up to 113 Cable TV channels...When shipped from the factory, this selection is in the CABLE position...... Press or to select “TV” or “CABLE...... Press MENU in the TV mode, then press to select option...... Cable TV chart... Press or to select “ADD” or “DELETE”, whichever function you want to perform...... The chart below is typical of many cable system channel allocations...... Press or to select “TV/CABLE...... Press press... TV/CABLE selection Automatic memory tuning... TV/CABLE AUTO CH MEMORY ADD/ DELETE... or... to select “ADD/DELETE”, then...
May 19, 2010 | Toshiba MD20F51 20 in. TV/DVD Combo
I have a Zenith B25A242 TV. Can't get cable channels
Select cable, then with your remote, go to menu and perform channel scan.
Oct 31, 2009 | Televison & Video
Unable to get cable channels past channel 33.
Your problem is likely not your TV. It's due to the signal being provided by your cable company. I suggest that you contact the cable service provider which you are using and advise them of the problem.
Mar 18, 2017 | Spectra KT2313 Combo
Doesn't get all cable channels
With the menu set to cable signals, the autoprogram should catch all of the cable channels. The Cable Channel option allows you to use either channel 3 or 4 as the "cable" channel. This is when you have an external box that you use to tune in cable rather than the TV directly. The easiest way here is to autoprogram the TV while playing a VCR tape. That will insure that channel 3 is included.
Does the autoprogram fail?
Dan
Aug 20, 2008 | Televison & Video
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
