I figured it would be better to show then try to explain through text. I have checked the fan it's clean the ram should be good I tried taking one out and booting it up so far it's all a no go. Any he
Hook a connector from your labtop to tv there are hook ups on the newer tvs that use the same hookup to your older style moniters .i believe your display adapter is not working right or the videocard went bad .hooking the labtop up to the tv will allow you to tell if it comes on the tv .you must first push input on tv or source input on tv and find pc or maybe it well say comp .then reboot computer a couple of times to allow it to reconize tv .also you can use hdmi cord if computer has output for it and try it that way it also works .your computer is turning on but no video output is showing on the laptop screen this will help solve the problem also might be bad power pack well know with dell
Posted on Dec 02, 2012
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Its not ram its your dc board or motherboard, replace dc board first if that fails then replace motherboard.
3 Suggested Answers
zohail
  • 1223 Answers
SOURCE: boots up .. on logon goes into shutdown ... safe mode no better
pls restore ur OS like this see if it helps pls le tme know if i can help more b4 rating me and Rate me FIXYA if solved
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
Posted on Mar 19, 2009
cgpatron990
  • 66 Answers
SOURCE: no video, no boot. continually cycles trying to boot
Well, if you've already checked all the necessary hardware and they all check out, it seems the only problem is the motherboard.
Actually, the more recent DV#### models from HP have had hardware defects, and they have offered to repair these computers if they show any symptoms of defect.
The chipset product line coming from ASUS was faulty, and have caused hardware failures such as this.
Call customer support for HP and have them schedule a repair for your laptop. They should repair it free of charge, whether the warranty expires or not.
Hope that helps.
Posted on Jan 14, 2010
Computer hangs after startup
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer at least two hour a day.
Hope these tips will help.
Dec 17, 2013 | EliteGroup K7VMM Motherboard
CONTINUOUS BEEP WHEN I BOOT UP MY PB IMAXD3413
Issues with Ram modules not inserted properly, or not suited to the board, but more likely a failing CPU fan which is not turning as the computer is booted, check fan connections and use a multimeter set to 12 volts to see if there is a feed coming from the two outer fan pins on the motherboard (or try a other fan)
Jul 27, 2011 | Packard Bell (181368) Motherboard
I used a vacume to clean my computer now when i press the power on the fan spins non-stop wile a steady beep every five seconds without showing anything on my monitor
This means the machine is not making it past the POST or power on self test. This is bad. This means it could be your RAM, your processor, your video card, or something isn't properly seated or connected. Please take your computer to a professional tech who is A+ certified (try to avoid the generic best buy type fix it shops for something like this). Please never try to vacuum your computer. If it needs cleaning please, please use compressed air and blow out any dust/debris in a controlled manner. Thank you and I'm sorry I don't have better news for you.
Jan 04, 2011 | ASUS Computers & Internet
The laptop takes along time to boot then after booting then after booting it shows blue screen then hangs.
The problem may be with your RAM just get them checked whether they are properly working or not.......
www.hiddendragons.tk
Oct 07, 2010 | Computers & Internet
System freezes up
Check whether you motherboard heat sink is working properly or not. If u find more dust on the heat sink and the processor unit remove it with a brush and then check the RAM slot, If you have the RAM working properly then the problem is solved. If the RAM is making the trouble to hang try to replace it with another RAM with the same frequency. This will work out.
Nov 07, 2009 | ECS KN1 SLI Lite (V1.0A) Motherboard
System just shuts off randomly
It will do this when it senses that the fan is not working properly or that maybe a setting fo the fan is incorrect
First off. If you changedanything using any motherboard utility then change it back or reset defaults.
Second. Open the computer case and check that the fan and poer supply are not full of gunk after you have unplugged the computer.
if so then get a can of compressed air meant for cleaning computers and take it outside to blow all the gunk out whilst wearing glasses.
Dont poke the nozzle inside anything.
When you have done that check that the cooling fan for the cpu is secure to the cpu itself (dont remove unles it is loose)
Also check that the fan spins freely.
If it doesnt or feels loose then replace the cooler
Check your manual for the exact instructions but you should remove the cooler completely
DO NOT REMOVE THE CPU
Now with nothing more than isopropynol and cotton bud sticks or another alcohol based cleaner remove the old thermal grease / sticker from the top of the CPU (make sure it is clean)
At this point it is up to you but you could consider a newer better cooler
You could take your old cooler to a good computer shop show them it and just ask for a better one
If you are using your original cooler then here we go
Do the same with the underside of the cooler.
While the cooler is off it may be worth giving it a good 8low job
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business.
Another consideration is that many cases have places in them for extra fans and usually extra connections on the motherboard too.
They are quick and easy to fit.
Quite often I will fit TWO in what is called a push/pull configuration. One pulls cool air in while the other pushes hot air out
Apr 03, 2009 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Dell dimension 4700 computer keeps shutting down at start up
That's pointing to the memory. Try re-seating the RAM.
Mar 19, 2009 | Dell Dimension 4700 PC Desktop
So i was trying to change out the ram for a better on. while doing that i decided that i was going to clean out the insides, mainly cause its never been done. also while doing this, i took out the...
Make sure the cpu is seated properly. It should only go in one way. Also make sure you have applied a good thermal paste between the cpu & heatsink. Check and reseat RAM. Then try rebooting. Hope this helps.
Dec 25, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
IBM T40 screen not working!!!! Please Help Me!!!!
check the display on external monitor, through the vga port of your laptop if the display is there then its the problem of your screen, some times this happen due to non working of the cable that gives display to the screen , its better check it by some technician
Nov 03, 2008 | IBM ThinkPad T40 2373 Notebook
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
