Question about Vehicle Parts & Accessories
Where can I buy a 2003 Hyundia Tiburon BCM?
Im sure I can fix it myself if I caould only find the part.
  • dixiejokes
    dixiejokes Dec 01, 2012
    Sorry, It's NOT the BCM I need, but just the DIY part... anyone?
  • Vehicle Part... Master
  • 14,417 Answers
Click here to see.
Posted on Dec 02, 2012
My key is stuck in the ignition switch because it will not turn back to the lock position to remove it 2003 hyundia tiburon
Make sure that you car is completly in the park position, if your car is an automatic. The key will not be able to move out of the ignition if for instance something is blocking the shifter.
Nov 09, 2012 | 2003 Hyundai Tiburon
Hyundai Tiburon: Replacing plastic cover that encases everything.
Call around to your local auto wrecker/salvage yards, and check ebay before you go to a Hyundai dealer.
Apr 19, 2010 | 2003 Hyundai Tiburon
New battery new starter only clicks will not start on a 2003 hyundia tiburon
Sounds like you should see if the engine is frozen by trying to turn over the engine by hand with a torque wrench or gripping the belt.Make absolutely the new battery has a sufficient charge by using beefy jumper cables. make sure all your connectors are really clean and tight.
Mar 30, 2010 | 2003 Hyundai Tiburon
2003 HYUNDAI TIBURON bcm? Radio, clock, parking
More than likely that is your problem. It should be up under the dash on the drivers side somewhere but i could be wrong. here is a crappy pic of it.f308c8b.gif
Jan 20, 2010 | 2003 Hyundai Tiburon
Flasher
Its the BCM. Follow these instructions for a cheaper fix.
DIY: BCM Turn Signal Fix - NewTiburon.com
Oct 15, 2009 | 2003 Hyundai Tiburon
Right turn signal light stays on front and back and will not work. lights stay on when car is not running and is draining battery
this problem is a bad BCM the relay is part of the computer system and your problem is common. replace the BCM and reprogram security and you will be good to go.
Or find someone to replace the relays inside. Harder to do than you think, I change them all the ime, but not easy to find the replacements.
Sep 01, 2009 | 2003 Hyundai Tiburon
2003 Tiburon - My turn signal stays on.
Im sorry but Emissionwiz is wrong i had the same problem and i just took out the BCM board completely and dismantled it. I'll i had to do was desoder the relay switch and sodered in a new one the relay switch cost me 2.50. so now you dont have to replace the BCM. and questions email me at Boatleft11@yahoo.com
Aug 31, 2009 | 2003 Hyundai Tiburon
2003 hyundia tiburon what relay controls turn signals in bcm
a relay. can't replace relay only. Must replace entire BCM
Aug 19, 2009 | 2003 Hyundai Tiburon
http://www.newtiburon.com/forums/showthread.php?t=102241&highlight=bcm
Jun 21, 2009 | 2003 Hyundai Tiburon
Can not find location of fasher unit on a hyundia/tiburon2003 ...need to replace the flasher cant found the installation dont know the spot of the old flasher location...need a response asap..
Very common problem in Tiburons for flashers to stick on. One solution (you can probably find detailed instructions newtiburon.com) is to replace the correct relay on the Body Control Module (bcm mentioned by q_tipj83). This is very hard. Much easier is to go online and find a salvage yard who has a BCM. I got one for $100, as opposed to $500 for a rebuilt one that is hard to find or $1000 at the dealer. they gave me a 90-day guarantee and everything has been fine with it. At the above prices, you could buy severl used BCMs and still come out ahead.
By the way, the BCM is the box to which theh under-dash fuzebox is attached.
May 11, 2009 | 2003 Hyundai Tiburon
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
