Question about Casio AJ1 Personal CD Player
Setting the clock on the Casio AJ1
I am trying to set the clock on the Casio AJ1
I have an older casio pathfinder tough solar that I'm trying to adjust the tidal info on. I have just moved to Malibu CA. from Florida. Can you help?
Press the mode button until you find the "city" setting and then press one of the othe buttons (the one at 4 )'clock?) to step through the list of cities until you find "LAX". Then press he mode button to return to normal timekeeping.
Jun 12, 2011 | Casio Watches
My Casio module #2735 is 12 hours off. when I set it, it is off 12 hours when it reached the 12: o'clock hour.
If your watch it 12 hours out, then it must be set to the wrong city.
If you press the mode button you will come to a setting which is list of city abbreviations, press the 4O'clock button to step through the list until you come to the one on your longitude.
If you can't recognise the correct one look at your instructions (near the end) for a list.
If you haven't got any instructions, you can get them from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Jun 08, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Alarm setting I want to set an alarm to repeat daily as a alarm clock would for a g shock
casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left ...">casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. ...
Mar 10, 2011 | Casio Watches
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
The hands are not setting themselves.
The controlling radio signal for the National Physical Laboratory's clock is transmitted on the MSF 60kHz signal via the transmitter at Rugby, operated by British Telecom International. This should have a range of some 1,500 km or 937.5 miles. All of the British Isles are of course within this radius.
The National Physical Laboratory's role as keeper of the national time standards is to ensure that the UK time-scale agrees with Co-ordinated Universal Time (UTC) to the highest levels of accuracy and to make that time available across the UK. As an example, the MSF (MSF being the three-letter call sign to identify the source of the signal) radio broadcast provides the time signal for, electronic share trading, the clocks at most railway stations and for BT's speaking clock.
Try to find a solution here:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Jul 23, 2009 | Casio Watch Waveceptor
How do i set my casio wave ceptor to the 24hr clock?
You go to the time setting place then then keep changing the time until A.M. and P.M. doesn't show.
Jun 07, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Manual Receive of Atomic Clock time on Casio Watch not working
I have the same problem.  Following the instructions, by pressing A it wants to set the GMT differential. It will not go into manual receive mode.
Jun 05, 2009 | Casio Watches
Setting analog time
go to; http://world.casio.com/wat/download/en/manual/ and enter the module number code on the back of your watch - hopefully will tell you what you need to know. Hope this helps :)
Mar 13, 2007 | Casio AW80-1AV Wrist Watch
Casio AJ1 Personal CD Player Logo
43 people viewed this question
Top Casio Audio Players & Recorders Experts
rhodesworks
Tom Chichester
Are you a Casio Audio Player and Recorder Expert? Answer questions, earn points and help others
