Question about Microsoft Windows Vista Ultimate Edition
I have problem in loding system32 fills when starting pc
I have problem when i start pc,i get error of fill named as:-c:\windows\system32\config\win.exe
i need a solution plizzz help me
and if anny one has a solution plizzz sand me link
  • santosh_m208 Jan 11, 2009
    NO YAAR ITS NOT WORKING
    Sergeant:
  • 191 Answers
Ok gp tp start menu then run type"msconfig"
then enter then go to startup then cleik on disable all then aply and ok then restrt the computer.
then check.
Posted on Jan 11, 2009
My laptop hp compaq is not able to start it is showing fatal error as mentioned in the picture i tried to reeboot restore the computer launched startup repair command prompt is not Opening too pls help...
start computer. you see compaq sembol and prees esc key you see startup repair and prees f11 key.you can see windows is loding fills and microsoft corporaation and now you can see blue windows read and click next next next .
try this .
May 31, 2013 | Computers & Internet
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Jun 25, 2011 | General Electric WCVH6800J Front Load...
It won't load windows! windows won't start because the following file is missing or corrupt. windows\system32\config\system.
try starting in safe mode by pressing f8 key on system boot ,
looks like you may have hdd problem, if you get message 0disks filling the screen hdd needs replacing
Feb 22, 2011 | Aspire Acer AS5315-2856 Laptop
How to repair if the windows is not genuine
hello there start your windows in safe mode (restart your comp. then keep pressing f8 or f5 ) then log on by administrator then go to windows folder hen system32 folder then find these
\WINDOWS\system32\WgaLogon.dll
\WINDOWS\system32\WgaTray.exe
\WINDOWS\system32\LegitCheckControl.dll
select these files together then rename them ( any name you like ) then start your windows in normal mode then delete those files that you renamed.
Dec 11, 2010 | Computer Associates CA Arcserve Bkup R11.5...
I have an eMachine T3410. When it boots, a screen
your missing the biosinfo.inf. try reinstalling the system but backup everything you need first.
Jun 09, 2009 | E-Machines eMonster 600 PC Desktop
Lode needed dlls for kernel
Use the ERD disk and repair the installation. Choose to replace all files, and then replace only the Hal.dll and Ntoskrnl.exe files.
If you can start another installation of Windows NT on the same computer, you can expand the correct Hal.dll and Ntoskrnl.exe files from the Windows NT CD-ROM. To do so, follow these steps:
  1. Boot to the working version of Windows NT.
  2. Start a command prompt.
  3. Change to the CD-ROM drive.
  4. Change to the appropriate folder on the CD-ROM (for example, I386 for Intel-based computers).
  5. Type expand hal.dl_ <systemroot>\system32 where <systemroot> is the path of the non-functioning Windows NT folder.
  6. Type expand ntoskrnl.ex_ <systemroot>\system32.
  7. Restart the computer into the other Windows NT installation.
Mar 27, 2009 | Microsoft Windows XP Professional
Ieframe
use this link to download ieframe.dll fill. extract the winrar and copy the file in your system32 folder.
c/windows/system32. the problem will be solved.
http://www.dll-files.com/dllindex/dll-files.shtml?ieframe
Oct 02, 2008 | Microsoft Internet Explorer 7
Desktop Error Message
Probably this is a spyware, use a good anti spyware or do the following:
Run Process Explorer (right click on task bar>task manager>Processes) and Kill the Following Processes:
wscript.exe
dxdlg.exe (kill this one first)
Run Autoruns and under logon tab, remove
C:\WINDOWS\system32\wscript.exe C:\WINDOWS\system32\boot.vbs
Search for entries named wproxp and remove it
Remove the following files from your PC:
C:\WINDOWS\system32\dxdlg.exe
wproxp.exe (Most probably in your system32 or windows folder)
Jul 06, 2008 | Computers & Internet
Safe mode....unsafe.
Your PC is stuck in safe mode startup
I would suggest using the Windows Disk, if you have one, go through normal windows installation. At the point of installation just after pressing F8 it will detect windows exists and offer you a repair option press R to repair
Apr 03, 2008 | Compaq Presario V5005us Notebook
Microsoft Windows Vista Ultimate Edition Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
