Question about Refrigerators
HI, I have a Kelvinator C380P fridge which is freezing everything. Is it likely to be the thermostat or another possibility?
It has recently been moved but worked fine beforehand.
SOURCE: I have a kenmore mini-fridge
they do that when they are on the way to the big kitchen in the sky. sorry, but mini fridges do not typically last very long.
Posted on Jun 14, 2008
ngfam1
  • 639 Answers
SOURCE: Hotpoint FFA90N fridge freezing everything
Peace Friend,
ngfam1 At your service!
Ready?
it sounds like the thermostat and it is not easy to do if you have never done this before, it's better left to a professional!
What type fridge,model and age?
If not only a trained tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 04, 2008
huuum
  • 750 Answers
SOURCE: Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
WeListen2You
  • 538 Answers
SOURCE: Hotpoint Fridge freezing the food.
thermostat is buried behind the walls of that unit, are you ready to run this one..takes quite a bit of time..but
will get the item, if you can supply the actual serial number from inside or back of that unit..
Posted on Oct 26, 2008
  • 2920 Answers
SOURCE: fridge quit cooling after i moved it
did you tilt it when you moved it and then when u got it in place plug it in? if so youve got compressor problems, anytime you tilt a fridge you have to let it set for several hours to allow the oil to get back to the compressor or you ruin the compressor
Posted on Jan 01, 2009
I have a kelvinator impression series 300 and bought it second hand. The fridge component is freezing all our food and there is icicles on the back wall of the fridge. I have tried changing the thermostat...
I have the same fridge.only a week a go my wife bumped the temp control in the freezer. It ended up freezing up so much. The fan that blows the cold air down to the fridge, couldn't . If you take everything out of the freezer. There are little plastic round caps covering the screws in the back panel. Remove the caps ta
Jan 27, 2014 | Refrigerators
Kelvinator c302f-r fridge is freezing everthing
sounds like thermostat if its non frost free model,otherwise it is temp sensor.need model number to clarify.
Apr 25, 2012 | Kelvinator Refrigerators
My Kelvinator KCI 26 BFF fridge conpartment has started to freeze things
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jun 08, 2011 | Microwave Ovens
I have a two door kelvinator it freezes the food aside
Ok, your thermostat is buggered, the fridge wont turn off becaust it hasnt been told from the thermostat, easy DIY but be aware DISCONNECT the power first and unplug from the wall and do not kink the thermo tube when replacing. Buy the same thermostat and take a pic of where the wires go before removing the old one. Hope that helps, if you need help, call me on 08 9523 0552 Russ and I can help further.
DONT FORGET TO VOTE, I JUST HELPED YOU FOR FREE
Mar 02, 2011 | Kelvinator Freezers
Fridge Too Cold
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jul 31, 2010 | Frigidaire 16.5 Cu. Ft. Top-Mount...
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
I have a Kelvinator Cyclic 501 Impression Series fridge. Model C501V-R. no matter what setting it is on everything is freezing - the door seals are in excellent condition.
I used a,Hair Dryer on mine that fixed it, had too do it twice though have not had a problem since, (it froze the entire Thermostat over), had my Fridge for over 30 years only ever replaced the seals recently, no other problems ever
Jun 11, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
