Question about Sony KLV-S19A10 19 in. HDTV-Ready LCD Television
Klv 37s400a red light flashes 6 times - Sony KLV-S19A10 19 in. HDTV-Ready LCD Television
SOURCE: TV won't turn on and red light flashes 6 times.
my sony 40 inch lcd tv flashes 4 times and wont turn on? Any ideas?
Posted on Aug 09, 2008
  • 89 Answers
SOURCE: Sony KLV-S32A10 32 when i turn on picture come then goes off
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV.
I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
Posted on Jun 19, 2009
walesarumi
  • 6993 Answers
SOURCE: Sony KLV-L32MRX1, Bought Dec 2004,
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 07, 2011
Testimonial: "Great answer, Sounds like it should work, Will get onto it straight away, Many Thanks, Ian."
Kensolutions
  • 455 Answers
SOURCE: hELLO MY kdf-e55a20 tV IS
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The Lamp light blinks when the Lamp requires replacement.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the power light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
This indicates that there is some kind of audio problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jun 11, 2011
EXPERT-TECH
  • 27 Answers
SOURCE: KLV-32S400A
Either you have a bad inverter board, bad flourescent lamp inside of panel, bad power supply, or bad panel. Working warranty for Sony I have seen it all. keep me posted : Expert-tech /Sam
Posted on Mar 27, 2012
TV dead. How can i fix this without replacing the whole board?
You can try the troubleshooting section of the manual here: http://www.manualslib.com/manual/440142/Sony-Klv-32s400a-32-Lcd-Tv.html?page=36#manual
Feb 04, 2016 | Sony KLV-37S400A 37 inch Multi-System HDTV...
What can cause the sony bravia to switch on then off immediately.
6 flahes indicates a panel error possibly the backlight controller
Jan 31, 2014 | Sony BRAVIA KLV-40BX400 MULTISYSTEM LCD TV...
NO VIDEO IS COMING BUT CHANNEL IS GETTING CHANGED AND SOUND IS AVAILABLE
Please check for the Back Light first. re fix the Inverter board connector. Panel may also be defective.
Nov 11, 2013 | Sony KLV-37S400A 37 inch Multi-System HDTV...
Sony KLV-46S200A LCD TV doesn't turn on, it remains blank with the red standby lighthouse blinking 4 times.
According to the service manual page 6. four flashes is "Backlight Trouble" so if its the light it self or Backlight Inverter Board i cannot tell you.
Service manual can be downloadet here.
http://elektrotanya.com/sony_klv-26s200a_klv-32s200a_klv-40s200a_klv-46s200a_chassis_wax2.pdf/download.html
Feb 03, 2013 | Televison & Video
Color green purple
Check the strip wire connection between LCD pane and T'Con board for any loose contact.
Dec 18, 2012 | Sony KLV-37S400A 37 inch Multi-System HDTV...
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) six (6) times then there is a two seconds break followed by another six flashes...
6 times blink shows problem with back light inverter board.
TV requires back light inverter board replacement. If you have electronics repair experience and want to repair TV by yourself, let me know to guide you part purchase.
Apr 13, 2009 | Sony KV-35S42 35" TV
SONY 3LCD 60 INCH WONT TURN ON
Get a real job. You can only wish you were smart enough to earn your own mony and help other people. I cant believe I feel for this. Shame on me
Jun 19, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony KLV-S19A10 19 in. HDTV-Ready LCD Television Logo
87 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
