Question about Refrigerators
Purpose of on and off switch inside Refigerator. Should it be off or on?
The switch in question is located in side the Refigerator by the light.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 02, 2012
2 Suggested Answers
  • 3 Answers
SOURCE: how do I replace the refigerator light switch on a
There are two light switches in this unit. The frist thing you need to do is unplug the unit. then you need to kind of pry the switches out on an angle. Don't do anything until you get the new switches. Look at the switches and compare them to your switches. you will beable to see which way the switches come out.
Posted on Oct 28, 2010
Where is the sensor eye and sensor light on garage opener
The only 2 sensors are located inside on each side of the garage door. Their purpose is to sense if there is a movement while the garage closes so it can interrupt the garage closing. That's in case you close the garage and someone walks in/out. Also some sensors also act as a "light switch". What I mean is that when the garage is open for a while, and you walk in the garage passing those sensors, it will turn the light on which is located on the motor.
Aug 01, 2014 | Building Materials
How do I replace the refigerator light switch on a Maytag side by side MCD2257HEC?
Oct 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
My Kenmore side by side refrigerator does not cool what do i to fix the problem
See if the fan is running inside. If not replace the evaporator fan. Check the lint/dust buildup under the ref. Clean if necessary. Also see if you ca find the defrost timer on it. (should be in the refrigerator side.)
Try to turn the little dial on it with a screwdriver and see if it comes out of the defrost cycle. if it does, it is a bad timer.
Is the coil freezing up in the freezer compartment? This could be caused by a bad timer or the defrost heater/terminator is bad..This will also cause the refigerator side not to cool.
Also, check and make sure the light turns off in the fridge side when the door is closed.Check by depressing the switch located somewhere close to where the door touches it.
if the compressor is running and not freezing, you may have a refrigerant leak. If not, then if the defrost timer is working, the door switch is good and fan runs, you may have a bad compressor.
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator and freezer not getting cold
Clean out the coils on the bottom, make sure the fan motr is turning below and remove the relay from the compressor. A lot of these relays are failing lately. If the relay sounds like a slt shaker inside it is toat. if it makes no sound at all it is bad. You should beable to feel the sliding start switch inside.
Jun 14, 2009 | Frigidaire FRS26R4A Side by Side...
Interior level indicator and interior lights not working on Whirlpool GD5RHAXNB00 Refrigerator.
The failed part on my unit was 2252189, the electric control board. This board is located on the left side of the refrigerator in the back next to the compressor. Its inside a plastic box on the side. That number has changed to a number WHIW10135090 and cost $84 from www.apdepot.com
A previous post listed a part number 2303805 as being the problem. That part number was the replacement number for the control board that is located in the control box inside the refrigerator. That part is NO LONGER AVAILABLE. It has been replaced by part 2255233 which is the entire control box. cost for that part is $161.00 from AP Depot. I purchased this part first and it was found to NOT be the problem.
I would suggest that anyone who has this problem start with the less expensive part 2252189 and them see if you need to spend more.
My unit worked fine with exception the the refigerator side interior lights and the digital display. Compressor and temperatures were fine. Just an FYI on my problem specifics.
Oct 25, 2008 | Whirlpool GS5SHAXN Side by Side...
Refigerator and Freezer not cooling
You might try cleaning all the dust if any from the back or access to the bottom front.
Feb 14, 2008 | KitchenAid Superba KSCS23IN Side by Side...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
