Question about Dryers
My Electrolux dryer is not drying my clothes what can I do
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Dec 02, 2012
  • 91 Answers
SOURCE: new dryer, not drying clothes, vents cleaned, old dryer worked ok
repl/ thermistor and coils,,, remember these machines have moisture sensors,,,,,,,
Posted on Jan 04, 2009
Richie_asg1
  • 1036 Answers
SOURCE: No heat when drying clothes. Where is the fuses on a dryer
There are two thermal fuses, but if the fuse has gone - there will be another fault Replacing them without sorting the fault will only lead to them going again.
Fuses will blow if -
  1. The fan motor stops working
  2. The vents are blocked
  3. The heating element overheats
  4. There is an electrical fault
These need checking first.
The fuses are usually clipped into a metal frame over the heater coil - which is on the top of the drum.
Disconnect the machine and remove the top cover to see them.
Look for a picture of replacements online so you know what to look for.
Posted on Jan 10, 2009
david04928
  • 102 Answers
SOURCE: whirlpool ultimate care II dryer: dry clothes sensor
Make sure that the vents are cleaned to include outside. Where it hook on to the dryer make sure that the housing is cleaned also. That should take care of the problem. Thankyou and if you need more help let us know.
Posted on Mar 16, 2009
SOURCE: Dryer is not drying clothes dry
My Maytag Neptune isn't drying my clothes
Posted on Oct 14, 2009
  • 171 Answers
SOURCE: my dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Posted on Jul 29, 2010
DRYER NOT DRYING CLOTHES ALL THE WAY FILTER IS CLEAN AND CLEANED OUT THE LINT TRAP AND COVER. NO CODE GIVEN. HAVE TO RUN TWO CYCLES.
Clean the exhaust duct. The ENTIRE duct, from where it attaches to the dryer to where it exits the house... Failure to dry clothing when you have heat is an air-flow issue
Jun 05, 2016 | Electrolux EIED55H Dryer
I was drying my clothes and the steam feature would not turn off. How do I turn off the steam feature ?
Hi friend, thanks for your post!
I understand that the steam feature on your Electrolux dryer is not turning off. I would recommend a reset and you can do that by disconnecting power to your dryer for ten minutes. I hope this helps. -Matt
Sep 21, 2014 | Electrolux Dryers
Electrolux gas dryer snagging clothes
Good Morning Friend,
I understand your Electrolux gas dryer, model# EIGD55HIW, is snagging and tearing your clothes. There is a possibility that the temperature is too high and you are overdrying your clothes. Make sure to dry your clothes on the correct temperatures and correct times. The other possibility is, the finish inside of your dryer has been scratched or chipped. This can cause a snagging or tearing of clothes. To prevent further scratching and chipping of the drum finish, make sure to always remove any foreign objects from pockets before laundering, as well as make sure zippers and fasteners are not hitting the inside of the drum. Hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Electrolux EIGD55HIW Gas Front Load Dryer...
WILL NOT DRY
sounds like temp limiting switch
Aug 07, 2012 | Electrolux EIED55HIW Electric Front Load...
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Jul 20, 2010 | Electrolux Washing Machines
Ihave a top of the line front load dryer with steam(electrolux). It "burns" or melts the clothes leaving a hard black substance on them. If I turn the heat to low I must run it 2-3X to dry the clothes. the...
Do not waste any more time with the repairs, they will not resolve the design flaw issue. We have also had the vent replaced 4 times and have burned thousands in clothing /bedding. We are pursuing a class action lawsuit against Electrolux. If you are interested in more information please email me at: alicat_95650@yahoo.com
May 20, 2010 | Electrolux Dryers
On autodry clothes do not fully dry
Try it with the exhaust pipe disconnected for a load, if that makes a difference, you need to have your vent pipe cleaned. Check in your exhaust pipe in the machine, too.
May 05, 2009 | Electrolux Frigidaire Affinity AGQ8700F...
Dryers Logo
153 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
