Dell D610 doesn't start at all
Dell D610 - Indicator lights shows there is power going to the laptop - But when I go to turn it on all the lights go on for about 5 seconds and then they all shut off - Even the light that indicates whether or not there is power going to the laptops battery or not. Does any one know how to fix this? I just got this yesterday from a computer shop. The fan is clean, the ram is good I saw the guy put it in out of a plastic casing. So any ideas would be great..
  • Roger Mercer Dec 02, 2012
    Well, It's working now - It wouldn't turn on but after being unplugged for about 16 hours it started up this morning as if nothing was wrong..
  • Roger Mercer Dec 03, 2012
    Scratch what I said - It will start after it's been off for about a day - And then when it's on and it shuts down it will stay off till like the next afternoon or something like that..
    Problem Solver:
  • 16 Answers
I'd go back to the store and make them start it. Anyway there should rather be in guaranty periiod. Ar'nt it?
Posted on Dec 01, 2012
proton77
  • 1183 Answers
SOURCE: E1705 Wont power on, indicator lights blink for few seconds
Kinldy folloow the steps given , in the following link to pin point the exact cause of failure. I suspect the motherboard has gone bad and it would require a replacement.
http://tinyurl.com/65uofc
Do let me know if you need furthur help
Thanks
Proton
Posted on Jun 29, 2008
SOURCE: My compaq presario v6000 laptop does not power at
Your problem sounds like the same thing I had. My solution was to do a power drain, and this came from HP support. You should disconnect power, and remove your battery, then hold down the power button on your computer for about two minutes. This will drain all residual power. After that you can plug in power and it should start, if the problem is the same as mine was. Then replace your battery and charge.
Hope it works for you.
Posted on May 03, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
  • 479 Answers
SOURCE: 1150 dell inspiron. Laptop won't power up. If
This seems an issue with inverter board need to checked by an expert.
thanks
Posted on Jul 27, 2009
SOURCE: I have a light flashing from green to orange on my laptop
no worries its just reading.. datas..
hot is just normal..
Posted on Sep 25, 2009
Have dell d610 battery light flashes 4 times red then one green, can't unplug
I would take note of the message you are getting and buy a new battery. I believe the red flashing lights mean that one or more of the cells in the battery are dying, and it's best not to turn off alarm lights like these. Did the battery hold charge for a longer period than one hour before you started to see the flashing light warning?
Apr 22, 2013 | Dell Latitude D610 Notebook
Hi I have a dell d610 and whenever I power it up it gives me the following message: '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN - X TO RETURN THE SYSTEM TO NORMAL...
Follow the instructions on screen in order to return to normal mode. Safest thing I would advice yo do is, back up all your important data from the hard drive onto an external hard drive and reset your notebook. this will remove the error message from your notebook. If you are able to, you should take your notebook to a qualified IT technician. I hope this helps you.
Sep 08, 2011 | Dell Latitude D610 Notebook
Will your assistance cost me anything? I turn the laptop on, the DELL word shows on the screen, and then the screen goes BLANK (cursor line shows at the upper left hand side of the screen). There is an...
This is a freebie
The system is not booting to the hard drive, the #9 indicator is an indication that the number lock is enabled.
Try holding the Fn key while powering on the system, see if diagnostics run (The works on newer Dells, not sure about the D610) If you don't have that function, if you have the resource cd, try and boot to it and run diagnostics.
Generally, the issue you describe is a problem with the hard drive, if it passes diagnostics, then see if you can repair the windows install booting to the XP Cd
Jul 08, 2011 | Dell Latitude D610 Notebook
I need a driver/SW for DELL D610 sleep mode, Pls. send me download version and installation instructions
Hi
Sleep mode don't need drivers,
It's pre-configurations are pre-installed in the Control Panel > Power Options
Go there, try to adjust and test the options for sleep mode ( when to sleep: close screen, press power button ,, ) and after how much time ..
Please,tell us your results
Good Luck
May 19, 2011 | Dell Latitude D610 Notebook
When I try to turn on my Dell D610 Laptop it immediately shuts off.
Hi
Try to remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON, see what happens
Please tell us your results
Good Luck
May 14, 2011 | Dell Latitude D610 Laptop Computer -...
Toshiba Satellite laptop will not boot. Shows power from outlet and battery but no indicator light is present for the last two in the five light sequence.
Its an old trick that got my Dell laptop working
Unplug the laptop remove the battery press the power button,...nothing will happen, wait a few seconds put battery back in laptop plug it in hold upside down press power button until it boots
If that doesn't work it could be a bad/loose/dead bios battery What is the model of the laptop?
May 11, 2011 | Toshiba Computers & Internet
I have d610 battery indicator flashes orange and green alternately i used ac adaptor to have power , once i plug out it turns off. i try a new battery do same thing? pls help
It may be that the power brick your using is damaged. You may just need a new power cord. Sometimes power cords can be damaged quite easily.
Mar 01, 2011 | Dell Latitude D610 Notebook
Dell d610 wont turn on ac adapter light is green
There is a small IC that Dell solders into their power supply as well as their batteries. When this parts fails you will have the type of problem you are having now. If you do a search on the web you will find a large number o sites that discuss this. Unfortunately there is no fix other than replacing your power supply. I had to do the same thing myself for the Dell laptop I use.
Nov 02, 2009 | Dell Latitude D610 Notebook
My Dell Laptop D610 wont turn on. It was on, I
Turn off laptop, Remove the battery and the power cable and press the power button for about 30 seconds.
Check for light on AC adapter.
Try with battery alone. Try with AC adapter alone.
Try with a different adapter of the same kind.
else the issue could be with the main board for which I would request you to contact the manufacturer.
Sep 11, 2009 | Dell Latitude D610 Notebook
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Computers & Internet Logo
David Payne
David Payne
