Question about LG Washing Machines
Re error Says water leaks and i cannot reset. Is there a safe way to remove lid to inspect hose outlets? It is an LG WD14030FD
  • Scott Burnham Dec 15, 2012
    On the inner lip of the grey suction ring which connects to the glass door, there was a build up of debris which once removed fixed the error
    Top Expert:
  • LG Master
  • 9,472 Answers
Remove the screws on the top panel and remove it.
Posted on Dec 02, 2012
  • 96 Answers
SOURCE: Water Leaking from Lid
Sound like some water or detergent is being directed up instead of down into the tub and eventually leaks out when you open the lid. You need to check, maybe using the Service Program, to see how it fills and how the detergent comes out.
Posted on Mar 07, 2008
onthejob5130
  • 640 Answers
SOURCE: water leak from bottom
defective pump...onthejob
Posted on Jan 17, 2009
  • 239 Answers
SOURCE: On LG waser have an Error LE message. Drained the
bad hall sensor
Posted on Apr 18, 2010
johnjnail
  • 1702 Answers
SOURCE: i have water leaking from
sounds like the water pump, pull the housing and look at the bottom center for a oval shape with two hoses.I bet you find the leak there.......GOOD LUCK
Posted on Nov 15, 2010
richroth
  • 9472 Answers
SOURCE: maytag npetune washer leaks at the pump outlet and drain hose. I see the leak even when the pour some water in the washer
Is it the tub to pump or pump to drain section?
Posted on Oct 29, 2012
FE code
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Oct 13, 2012 | LG Washing Machines
The water is not draining and OE flashes up on the sreen the model is LD1419W2 LG
Hi shockley,
The OE error code you are seeing, means "Outlet Error"
The drain pump is either clogged, or the outlet hose is kinked.
- Inspect the Drainage hose at the back for kinks. - If any, un-kink the hose
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
Jun 12, 2011 | LG Dishwashers
Getting an error code OE in LG inverter direct drive dishwasher and water not draining
Hi Ged Lunny,
The OE error code means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
Kind Regards :-)
Jun 09, 2011 | Dishwashers
Beko wm5120...no power even with new fuse
Instructions
  1. Close the lid or door. Washing machines automatically stop when the lid or door is open. Lift the clothing and move it slightly. If the washing machine is overloaded with towels or heavy garments, it might become unbalanced. The washer won't run until the items are adjusted.
  2. High-efficiency machines might stop running when regular detergent is used or too much high-efficiency laundry soap is poured in. If you suspect that the laundry soap is the problem, cancel the cycle and press the "Spin" or "Drain" cycles. Restart the cycle, but do not add more detergent.
  3. Inspect the water outlets. Turn faucets to the left to ensure that both the hot and cold water hoses are open. Tug on the hoses to make sure they are attached and inspect the hoses for thin spots that might be causing leaks. Make sure the hoses aren't kinked. Detach the hoses and run clean water through them to remove clogs.
  4. Is the washer's cord plugged into a grounded outlet? Never use extension cords to power washing machines. Check the circuit box for blown fuses.
Feb 02, 2011 | Washing Machines
Where is the thermostat on a 2002 sable?
Try this:
3.0L DOHC Engine
  1. Drain the coolant until the level of the coolant is below the level of the thermostat.
  2. Raise the vehicle and support it with jackstands.
  3. Disconnect the lower radiator hose from the water inlet connection.
  4. Unfasten the two water inlet connection retaining bolts and remove the water inlet connection.
  5. Remove the O-ring seal and thermostat from the water inlet connection. Inspect the O-ring for damage and replace as necessary.
To install:
  1. Clean the water inlet connection mating surfaces.
  2. Install the O-ring, thermostat and the water inlet connection. Refer to the accompanying illustration If you can-t remember how the O-ring and thermostat are positioned.
  3. Install the water inlet connection assembly retainers and tighten them to 71-106 inch lbs. (8-12 Nm).
  4. Connect the lower radiator hose to the water inlet connection.
  5. Fill the engine with coolant, start the engine and check for leaks.
  6. Stop the engine and top off the coolant recovery reservoir as necessary.
    Fig. Exploded view of the water inlet connection and the thermostat assembly-3.0L DOHC engines
3.0L OHV Engine
  2. Disconnect the upper radiator hose from the water hose connection.
  3. Unfasten the three water inlet connection retaining bolts and remove the water hose connection.
  4. Remove the gasket and thermostat from the water hose connection. Discard the gasket.
To install:
    NOTE The jiggle valve on the thermostat must be in the up position.
  2. Place the thermostat in the water hose connection making sure the thermostat jiggle valve is facing up.
  3. Install the new gasket and place the water hose connection assembly into position.
  4. Install the water hose connection assembly retainers and tighten them to 89-124 inch lbs. (10-14 Nm).
  5. Connect the upper radiator hose to the water hose connection.
  6. Fill the engine with coolant, start the engine and check for leaks.
  7. Stop the engine and top off the coolant recovery reservoir as necessary.
    Fig. Exploded view of the water hose connection and the thermostat assembly-3.0L OHV engines
    Fig. Remove the upper radiator hose from the water outlet
    Fig. Remove the water outlet retaining bolts and . . .
    Fig. . . . remove the outlet from the engine
    Fig. Remove the thermostat from the water outlet
    Fig. Inspect the water outlet connection for cracks or damage
    Fig. Thoroughly clean the mating surfaces of the water outlet and . . .
    Fig. . . . the engine before installing a new gasket
    Fig. The jiggle valve must be in the up (12 o-clock) position after installation into the water outlet
Jan 19, 2011 | 2001 Mercury Sable
I need to replace the thermostat it is sticking
DRAIN COOLANT LEVEL DOWN BELOW THERMOSTAT.PLACE DRAIN PAN UNDER VECHICLE TO CATCH ANTIFREEZE.WHEN DONE PUT ANTIFREEZE SAFE PLACE FROM KIDS AND ANIMALS.WHEN DONE DRAINING SOME ANTIFREEZE.FOLLOW RADIATOR HOSE TO TOP OF INTAKE TO THERMOSTAT HOUSING. LOOSEN HOSE CLAMP REMOVE RADIATOR HOSE FROM THERMOSTAT HOUSING.THEN LOOSEN HOUSING BOLTS.REMOVE THERMOSTAT HOUSING AND THERMOSTAT.CLEAN BOTH THE THERMOSTAT HOUSING SURFACE AND INTAKE SURFACE YOU CAN USE ACETATE OR BRAKE CLEANER AND SCOTCH BRITES ROLL OF CLEAN PAPER TOWEL. AFTER CLEANING HOUSING AND INTAKE SURFACE MAKE SURFACE CLEAN SMOOTH FROM THE DEBRIS WHEN DONE. TAKE THERMOSTAT PUT GASKET SEALER ON BOTH SIDES OF GASKET PUT GASKET TO THERMOSTAT HOUSING MAKE SURE GASKET AND THERMOSTAT HOUSING HOLES ALIGN CORRECTLY.NOW PLACE NEW THERMOSTAT IN PLACE IN THE INTAKE.MAKE SURE THERMOSTAT SPRING END GOES TOWARD ENGINE FACING DOWN.THEN INSTALL THERMOSTAT HOUSING WITH GASKET TO THE INTAKE.TORQUE THERMOSTAT HOUSING BOLTS TO 20 FT LBS.WAIT 1 HOUR BEFORE POURING ANTIFREEZE BACK IN THE COOLANT SYSTEM GIVE THERMOSTAT GASKET SEALER LITTLE TIME TO CURE.SO YOU WONT HAVE COOLANT LEAKS.NOW IF THERMOSTAT HAS THE LARGE O- RING ON IT YOU DONT HAVE A THERMOSTAT HOUSING GASKET THE THERMOSTAT O- RING IS THE SEAL THAT HOLDS COOLANT INSTEAD OF GASKET.WHEN THERMOSTAT AND HOUSING IN PLACE.INSTALL RADIATOR HOSE TO THERMOSTAT HOUSING TIGHTEN HOSE CLAMP.THEN FILL RADIATOR BACK UP WITH THE COOLANT YOU DRAIN OUT.START VECHICLE UP. THEN CHECK FOR LEAKS.
Nov 03, 2010 | 1992 Buick LeSabre
Which way does the themosat gasket go on a 1997 chevy s10 2.2
Thermostat If It's an O-ring it will go on either way and seal the thermostatic gasket. Removal & Installation 2.2L Engine To Remove:
  1. Drain the cooling system to a level below thermostat
  2. Remove or disconnect the following:
    • Radiator inlet hose clamp and hose
    • Thermostat and O-ring seal
To Install:
  1. Clean and inspect all parts for wear or damage
  2. Clean mating surfaces
  3. Install or connect the following:
    • Thermostat and the O-ring seal
    • Water outlet housing and bolts
      1. Torque to: 89 lb. in. (10 Nm)
    • Upper radiator inlet hose and clamp
  4. Fill with coolant
  5. Inspect for leaks
Jul 29, 2010 | 1997 Chevrolet S-10 Pickup
Want to know how to change a thermostat on my 2004
It Depends on which engine you have, this is how it goes for both. I use a little RTV with a new ring as well.
THERMOSTAT REPLACEMENT (4.2L ENGINE)
Removal Procedure
1. Remove the necessary coolant from the radiator.
2. Remove the generator.
3. Loosen the outlet hose clamp at the thermostat housing. Remove the outlet hose from the thermostat housing.
4. Remove the thermostat housing bolts.
5. Remove the thermostat housing from the engine block.
6. Clean all of the surfaces of the thermostat housing.
7. Clean the sealing surface of the engine block.
Installation Procedure
1. Install the thermostat housing to the engine block.
2. Install the thermostat housing bolts.
Tighten: Tighten the bolts to 10 N.m (89 lb in).
3. Lubricate the inner diameter of the radiator hose with engine coolant.
4. Install the outlet hose to the thermostat housing. Secure the hose with the clamp.
5. Install the generator.
6. Fill the cooling system with specified coolant and concentration. Follow the correct cooling systen bleed procedure for your engine.
7. Inspect all sealing surfaces for leaks after starting the engine.
THERMOSTAT REPLACEMENT (5.3L ENGINE)
1. Drain Radiator and remove the radiator outlet hose.
2. Remove the water pump inlet bolts.
3. Remove the water pump inlet and thermostat from the water pump.
IMPORTANT: The thermostat is not serviceable separately. The water pump inlet and thermostat must be replaced as an assembly.
1. Install the thermostat and thermostat housing to the water pump.
2. Install the thermostat housing bolts.15 N.m
3. Install the radiator outlet hose.
4. Fill the cooling system with specified coolant and concentration. Follow the correct cooling systen bleed procedure for your engine.
5. Inspect all sealing surfaces for leaks after starting the engine.
Mar 17, 2010 | 2004 GMC Envoy
2002 grand prix motor 3.8 just want to know where
Exploded view of the thermostat arrangement—3.8L engines
Oct 31, 2009 | 2002 Pontiac Grand Prix
LG 6810ST Dishwasher- OE Error Code
SInce the drain hose is not plugged or kinked, the next step if to remove the filter that is beneath the lower rack done in the sump area. Remove approximately 10 phillips screws.
Inspect for debris in the mesh filter and underneath it, especially the drain outlet.
Reassemble and retest with a quick cycle.
If problems persist, suspect a failing pump motor. Schedule professional repair is recommended.
Mar 29, 2009 | LG LDF6810ST Stainless Steel Built-in...
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
