Question about HP F4480 All-In-One Printer
I have installed a new color cartridge but it still shows the cartridge is low.
I have installed new cartridges. It still shows the color cartridge to be low. It was difficult to install the color cartridge.Now that it is in-the ink is still low. I have followed all the instructions. What do I do?
  • 4 Answers
Enable the extended services (hp printers toolbox)
OR:
Re-install device services- (go to control panel/printers and faxes and view all avail options/preferneces...)
You may have to use your HP printers Install.disk to enable/reinstall all/extra features.
Posted on Dec 01, 2012
eagle338
  • 4889 Answers
SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Posted on Oct 27, 2007
SOURCE: HP psc 1350 HP 57 print cartridge
Same problem with me.
So:
I openede the whole box ( 4 screws ) in the corners. Then I presed the tiny belt on the left side to its socket, cleaned the contacts of the cartridges (56,57) with water and made them dry.
Then I reched the position of the small door which is ment to be opened once you wnat to replace the cartridge.
After this the printer works again.
Posted on Jun 25, 2008
SOURCE: low ink message
just ignore the message and print
if it doesn't print try to dip the lower part of cartridge in warm water, not hot, for five mins and dry it with tissue and try to print
Posted on Mar 06, 2009
professor_sc
  • 180 Answers
SOURCE: ink cartridge problem! The following ink cartridges appear to be missing or damaged.
Solution :
1. clean the ink cartridge contacts both in the printer and the cartridge with a lint free cloth or a cotton swab. and try inserting the ink cartridges again. if it wont work proceed to step 2.
2. unplug the power cord at the back of the printer
3. press and hold # and 3 keys at the same time and plug the power cord back in. Do not release the two keys. wait until the printer would say "partial nvram reset" or anything that says "reset". if this still would not resolve the problem
4. do the same process as 2 & 3 but instead of # and 3 try # and 6. instead of saying "partial nvram reset" it should say "semi-full nvram reset". and if it would not work better go to an onsite technician. but if your printer if brand new return it to the retailer and exchange it. but before you do that try calling HP technician they would instruct you to the things i have given you. Just tell them what you have had done and asked them to replace the ink cartridges. This are the informations the agent would ask you about the ink cartridge
part number and also the expiration date.
try to ask for a replacement first if it would not resolve it. then go to a technician. I could not assure you that a technician could fix it because i have troubleshoot this kind of problems and there are alot of printer parts that needs to be fixed. Usually i suggest my clients to buy a new printer instead
Posted on Mar 07, 2009
  • 672 Answers
SOURCE: just installed refilled color and black ink
I found these instruction at out-of-warranty.com They seem like a possible solution.
Steps:
  1. Press Cancel and Power, at the same time.
  2. Then, the Unit will ask for a Key Combo, press blue, green, gray buttons (in order) for this.
  3. “Support Menu” should appear.
  4. Go to Resets menu and use the semi-full reset.
I hope this is helpful. Good luck.
Posted on Sep 05, 2009
Installed new ink cartridges mx 300, compatible B&W 40, color 41, printer status still says low ink, printing as if it is low ink. properly installed, tape removed, what i miss? can I check something...
Do you know what?. As a matter of fact,it is not compatible cartridges you buy. It is refurbished cartridges that repackaged with other brand as if this is their product. I say it is original cartridges that once empty and repackaged. So that's why when you install the cartridge the ink level stays low. You can make it sure by comparing it with new original cartridge. Find original cartridge,may be you can borrow from someone,which ink level still full and install on your printer. I am a hundred percent sure ink level will show properly :).
Feb 19, 2011 | Canon MX300 Office All-In-One Printer
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Installed new ink cartridges, computer shows low ink- not working
I would unplug printer and they turn back on and see, if not ininstall and reinstall cartridges and see.
May 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
http://www.retrevo.com/d/ds/progress?doc=9adbcf37695f2981dab6cde6d0fdb2d1
Replacing the ink cartridges B
Your machine is equipped with an ink dot counter. The ink dot counter automatically
monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
a Open the ink cartridge cover. If one or more ink cartridges are empty,
for example Black, the LCD shows Ink Empty Black and Replace Ink.
b Pull the lock release lever down and take out the ink cartridge for the color
shown on the LCD.
C Open the new ink cartridge bag for the color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1). Each color has its own correct position.
Insert the ink cartridge in the direction of the arrow on the label.
f Lift each lock release lever and push it until it clicks, and then close the ink
cartridge cover.
G If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example, Did You Change Blck?) For each
new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge you installed is not a brand new one, be
sure to press 2 (No). If you wait until the LCD shows
Note
If the LCD shows No Cartridge after
you install the ink cartridges, check that
the ink cartridges are installed properly.
Pls rate met. Thanks and Good Luck.....
Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Unable to reset printer after installing new ink cartridges
I want to known you have replaced the cartridges or refill the cartridges.
Feb 23, 2008 | Office Equipment & Supplies
Color problem
Chances are your othe cartridges were low...
When you install a new cartridge your printer does a head cleaning, and it uses alot of ink...
If the others were low, your printouts will show magenta as its the only color left...
Feb 10, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP F4480 All-In-One Printer Logo
Ben Johnson
