Question about Compaq Presario 700 470024-192 Notebook
My laptop vistro 6700 has vist software inbilt but i need to install xp software when i tried to install it is saying that your hard disk cant found . sata settings was not found in my laptop so what can i do now
  • 741 Answers
Windows Vista will not allow you to install Windows XP software over it. Microsoft has programmed it to not allow anyone to downgrade, basically because there are so many problems with Vista that they would lose money if everyone downgraded. So the only way to load Windows XP is to find you some software that will wipe your hard drive clean. You should be able to do it with the "fdisk" command at the DOS prompt. But beware; this will compeltely delete everything off of your drive. So back up any files that you need. Then you can load Windows XP.
Don't forget to rate this solution with 4 stars before logging out.
Posted on Jan 28, 2009
How do i restore a dell vistro 200 with xp home back to factory after vista and now 7 home is on it ?
Get the original recovery media and install the software.
You must configure the BIOS so that the computer boots from the CD-drive before the hard drive. Then you put the recovery CD in the tray and reboot. Follow instructions.
If you seriously plan on using Windows XP, hurry to install all updates because the support for XP is ending sometime in February 2014.
Dec 13, 2013 | Computers & Internet
When I connect my seagate expansion external hard disk 500gb having p/n:9sf2a2-500 in windows xp(sp2) system, found new hardware wizard pops up and when I click next it says Cannot install this hardware....
either an issue with the hard disk, or with your system. Make sure the hard disk has power on it and if you can, it would help to test it on another computer to confirm if it works. If you have ruled out the possibility that it is the hard disk, next is review if the hard disk has system requirements you need to meet. If the requirements are met by your XP SP2 machine, you may try updating the computer's system software/chipset drivers and a BIOS update may also be necessary.
Aug 29, 2010 | Computers & Internet
I have problem to install window xp in my laptop, which already have window notebook donot support to install xp..please tell is there any way to install xp...
What is your problem specifically? Is it that there is no hard disk detected when you try to install windows xp?
Try using third party software to detect the hard disk on your laptop
Try this link. It will basically give you your hard drive driver while installing windows xp. You will also need an external floppy disk drive if you dont have diskette drive in your laptop.
Jan 24, 2010 | Computers & Internet
Change hard disc problem
Ah this is a nightmare problem.... the only solution I know of to fix this is tiresome to say the least
Reinstall XP
But you need to delete the partition that Windows is on
and then reboot your computer
Go back to install XP and all should work well -- you may need to remake the partition and format it before Windows recognises the disk - but that is simple enough
If you can not boot into the CD - you will need to change your BIOS settings to boot from CD first
When your computer comes on a screen displays
It will tell you which key to press to get to your BIOS setup / settings page
Look for boot options and make sure the CD is first on the list
That will get things working -- a total drag I know but it is the only way I have found of getting this to work
Please vote kindly if this has helped
Oct 08, 2009 | Dell Vostro 1510 Laptop
I try to install XP in my laptop but its say no
this might happen if your HP Hard Disk Drive is SATA ready, i think your using SATA HDD 3.0 version.. usually this design is partition with windows vista... here is a tip use a CD Diskwizard that reformat and repartition your hard disk so that you can install windows xp, trust me its works... Good luck!
Jul 09, 2009 | Computers & Internet
How do I install windows XP on Compaq CQ40 327TU laptop
Try downloading Hiren Boot CD and run you can resize the Harddisk accordingly.
Mar 31, 2009 | Computers & Internet
Hard disk not found on Dell
actually you cant install operating system. first u have to install lower version and then install higher version of os. install original operating system dont use pirated version
Jan 08, 2009 | Computers & Internet
XP on HP Pavilion dv2000
i think you have a sata hard disk go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Got a laptop (ei systems) that i cannot properly start up, and access vital information which i just cant lose (court stuff etc). When computer turns on it say Boot device Hard Disk C / ...
try to boot your laptop from hard disk
reset your laptop & press f2 or del to go in cmos setup by press f2 or del key then afer go in boot manu select there is hard disk in a frist boot divice then save the settings by press f10
try this
may your problem will solves
Mar 23, 2008 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
