Question about Coleman Evcon Furnace Control Circuit Board 77990-320p
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
  • 1 more comment
  • Anne H Dec 01, 2012
    When I turn the wall unit to AC the blower works when the AC kicks on, when it is turned to Heat you can hear the coils getting hot but the blower will not kick on? Could this be a Relay Problem? The fan is free and turns WELL.
    Any suggestions are great! Thanks
    Also this is an Electric Unit
    Master:
  • 571 Answers
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Posted on Dec 10, 2013
5 Suggested Answers
  • 306 Answers
SOURCE: Coleman Evcon no fan when in heating mode
Sounds like your flame proving device is not proving the flame. It is located on the last burner looks like a piece of thick wire sitting right beside the last burner. To Save you about 50 bucks service call take some steel wool and very gently clean the carbon that has built up on the surface of the device. Should only take 4 or 5 strokes.
Main blower will delay when in heating mode as to allow the heat chamber to build up enough heat to trigger the fan switch.
Posted on Nov 30, 2008
  • 146 Answers
SOURCE: My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
Posted on May 28, 2010
  • 114 Answers
SOURCE: we have a coleman evcon
Explain the problem further as I do not understand the problem(s)
Posted on Aug 03, 2011
SOURCE: coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Posted on Aug 06, 2011
Coleman electric furnace
You don't say whether you replaced the blower but that could be the next thing to check
Jul 23, 2013 | Heating & Cooling
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
Coleman evcon blower not working properly
Jun 22, 2009 | Coleman Heating & Cooling
Coleman evcon furnace
is the air filter clean afc could be dirty
Dec 22, 2008 | Coleman Propane Forced Air Heater...
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Coleman Evcon Furnace Control Circuit Board 77990-320p Logo
216 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
