Question about Philips bSure XG2 Brilliance Multimedia Projector
Lamp light i have 545 hours of lamp life used but my lamp light is on...is this normal?
    President:
  • 3,130 Answers
That light is there to tell you that the lamp is close to the end of its useful life. It simple monitors the amount of current that the lamp is drawing, so if the lamp stops drawing a preset amount of current, the lamp light will come on, indicating to you to order a new lamp so you have one when this lamp finaly burns out. Good Luck
Posted on Jun 07, 2007
Image goes black and then returns shortly after
Many sets that use lamps do this right before the lamp fails--average life is 2000 hours or 2 years of normal use--if no blinking lights suspect the lamp first.
May 29, 2012 | Televison & Video
Lense hours
Hello muhammad
Projector's lamp life is said to be, not with the lens life. Lens is made up of glass. But lamp will go weak. the life of lame will depend on how much time the projectior have used. Normal life of Panasonic projector bulb spans between [1800 to 2000] continous use. It means, if we take the low life span of the bulb as 1800 Hours [1800/24=75 Continous days]. If we use it for 4 hours a day, the bulb may last for [1800/4=450 days ie 1 Year and 85 days] OK.
Dec 12, 2011 | Panasonic Videoprojector PT-LM1E...
The red lights on the control pannel indicate that there is a problem with ventilation (the fan or whatever is called). Can I fix it? The PJD5112 lamp turns on just for seconds and then of and red signal...
The projector switches off itself due to following problems. Make sure that lamp is not used for more than its life expectancy as mentioned by the manufacturer.The projector gets over heated due to two problems. 1) The dust filters are clogged. Clean the filters. 2) The lamp life is almost over or used lamp is in use. Normally each lamp is used about 2000 to 3000 hours depending upon the manufacturer. In such case replace with new lamp. There are many fans to control the temperature inside. Some are blower fans. Some are exhaust fans. You will have to open the projector & check which one of them is not functioning. Replace the one which is not functioning. It is also likely that there may be some failure of components.
Aug 07, 2011 | ViewSonic PJD5112 Projector
The projector is over heating and a red flashing light follows..
Aug 04, 2011 | InFocus ScreenPlay 4805 Multimedia...
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the...
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Mar 07, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
It turns on but there is no light. Has the lamp burned? The lamp has not been used for over 2,000 hours...
If it has done over 1000 hours it has done well.
If the projector is ceiling mounted, the air is very hot up there and the lamp life will be greatly reduced. Is the lamp life indicator flashing?
Hope that helps.
Dec 11, 2010 | Mitsubishi HC1500 DLP Projector
I turned on my tv and after about 30seconds is sounded like a light bulb blew and the tv went out. whenif is on now if has a crackling in the back intermitently and when you look in the back grill you can...
The tv projection lamp has not been change in this tv the last 1/1/2 or 2 years and been on an watches 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 05, 2010 | Samsung HCM5525W 55" Rear Projection...
Have a Mitsubishi Medallion HD 1080 Model WS-48413 which won't turn on. When I push the power button on the remote or on the tv itself, a green light comes on for a moment and a clicking sound is heard to...
~ Check the lamp hours ~ Normally it is 200-400 hours lamp life ~ BASIC USAGE: 8 hours/day ~ Reseat the lamp~ Consider replacing the lamp or it could be an Internal Problem
Jul 06, 2010 | Mitsubishi WS-65413 65" Rear Projection...
Tv comes on for about two minutes then shuts down. The lights stay lit.
Any LED light indicators on the screen panel said "LAMP"stay lit or blinking?The projection lamp life is over,require a new lamp,if "LAMP" LED light lite or blinking?The projection lamp in the tv now,been in use for at leat 2 years and tv on about 4 to 5 hours a day?The Lamp life span is over,require a new lamp.
Jun 11, 2010 | Samsung SP 56 K 3 HV 56" Projection...
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Aug 10, 2008 | JVC HD-61Z456 Television
Philips bSure XG2 Brilliance Multimedia Projector Logo
412 people viewed this question
Top Philips Office Equipment & Supplies Experts
Damen Wong
Damen Wong
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
