Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Primea ring hot milk
Hello, the milk is only warm on the machine the coffee is hot , how can i up the temp on the milk, thank you
  • Anonymous Mar 20, 2009
    the milk is only warm, I can hold my finger under the dispensing milk, while the coffe is hot, How can I up the temp of the milk?
  • 2,039 Answers
If you go in the menu there a temperature setting for that machine pierre
Posted on Jan 11, 2009
Milk frothing is very poor. I have had the machine for 7months and at the moment the frothing has stopped and milk is warm not hot. I have tried to adjust the frothing with the white wheel bu it doesnt...
Hi. Have you removed the white wheel and tried to clean it? Check the O-rings on the frothing part for damages.
Sometimes cleaning it hasnt helped at all, The solution for it that might sound crazy =) that fixed it for me at that time was to block the 2 holes with you fingers(be carefull its hot) where the milk comes out from when you make coffee, you get a little backpressure in the milk circuit when doing it. Try 2 or more times. It helpt me.
Oct 18, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Milk is not dispensing hot enough from saeco Primea Cappuccino Touch Plus coffee maker?? any ideas
I have the same problem, my wife complain me everyday, now we use our coiffe machine 90$ from sears it`s still better then this 3200$....
Apr 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Coffee and milk is luke warm when i make something
If you set proper menu position to "high temp", then i think one of the the boiler heater coils must be broken.
Apr 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Remember that the milk temp should be around 60-70c. Milk will start to boil around 80c.
You´re welcome and good luck!
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Milk temperature setting
Hot Milk:
steam pressure time 6
puls width 1
puls period 15
Milk Foam:
puls width 1
puls period 15
Hope this will help you.
/Mirran
Aug 28, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Primea ring - milk not hot
Hello!!
Okay! Looks like many of you out there has the same problem, whit the milk temerature (not me i never had).
But there is a service menu on primea touch plus series.
Im from Sweden but i will try my best to explain how to enter the menu. First of all !!MUST!! write down off parameters before changing any thing!!!! It is possible to set the grinder to grin more coffie for each cup. I think the factory setting is 85 Aroma impulse. It is possible to change that for you type of coffie beans that you use, i will diff from bean to bean.
Okay, to enter the menus you have to turn you machines off.
Now turn it on !!!!!EXACTLY!!!!! when the display lights up press your display in the following order ALWAYS IN THE CORNERS (you will not see any icons were you have to touch on you display) RIGHT LOWER CORNER, LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER.
To enter the second service menu, do as i explained before but use this "CODE" instead. LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER, RIGHT LOWER CORNER. This is it! Hope i could help you! Remeber to write down before doing any changes! DO NOT ERASE ANY FAULT CODES YOU SERVICE CENTER WILL FIND THAT INFORMATION VERY IMPORTANT!!!!!
Dont say that it didnt work, it will it´s a huge matter of timing!!!! IT WILL WORK!!!!
Let me know some results please!!
Mar 04, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
262 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
