Question about Venturer Pvs6100w Pvs6271
My portable dvd player will not read the discs. it keeps saying no disc. the door is shut all the way and the disc spins. Plus, the disc is brand new.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
The lazer is shot in it,It is not reading the info off the disc anymore, Verry costly to have it repaired,
Posted on Dec 03, 2012
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
After loading a disc it says "no disc"
Clean the lens with a soft cotton cloth but be careful not to touch it with bare hands. Make sure the lens is not soiled with dust.
Note: if it says 'NO DISC" immediately after closing the tray, check capstan motor if spins smoothly. It is the one spinning the disc. Open the unit's casing to have a view of the disc when playing. If it doesn't spin, replace capstan motor.
Aug 25, 2009 | Durabrand DUR7 Portable DVD Player
Won't pickup the dvd everytime
there are a few possibilties
1 make sure the disc is clean
2 your lens may need cleaning
3 some dvd players don't read burn copies of disc's some just read +R discs some just read -R disc
Jan 29, 2009 | Memorex MVDP1077 Portable DVD Player
Dratted Coby TF-DVD7100 Portable DVD player not working!
Its defective. Coby doesn't repair the units. The lense is off balance which is causing the laser to not read the dvd/cd.
Apr 17, 2008 | Coby TF-DVD7100 Portable DVD Player
Polaroid pdm-0732 wont read dvd
I just solved my issue. My 2 year old son set the AV switch on the side of the player to 'in'. I switched it to 'out' and now it works fine.
Nov 25, 2007 | Polaroid PDM-0732 Portable DVD Player
Dvd player just stop working all of a sudden
I have a studio and sometimes certain disc will play on one device and not on another..If you have already played the disc on the device I would try the clean the head. They sell cleaning kits..The DVD player only recognizes it can't play it..they could have it say (Clean disc) but they want you to buy another one..And it could mean its broke...Who knows...Just do all you can do...And a lot of boot leg disc want work...Not saying you buy them...Just saying to help anyone reading this...Hope this helps
May 08, 2017 | Coby TF-DVD7100 Portable DVD Player
Bad Disc
First determine where the problem lies. This can be done by analyzing what is happening. Is the disc spinning. Is it spinning erratically? If the disc is not spinning, the spin motor is probably defective. But sometimes you can be fooled, if the laser does not detect information of the disc, it will not issue a start spin motor command. If you can get the unit to work with the door open by defeating the switches,(Do not under any circumstances look directly into the laser)If you see the laser then the spin motor is bad, In either case the unit is is probably cheaper to replace than to repair. Scrivitron
Jun 20, 2007 | Polaroid PDM-1058 Portable DVD Player
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Venturer Pvs6100w Pvs6271 Logo
103 people viewed this question
Top Venturer Car Audio & Video Experts
Hjalmer Lamminen
Hjalmer Lamminen
seankane89
Level 1 Expert
Are you a Venturer Car Audio and Video Expert? Answer questions, earn points and help others
