Frigidaire Affinity ATF7000E Front Load Washer Logo
Anonymous Posted on Dec 01, 2012
Replace bushing on door hinge - Frigidaire Affinity ATF7000E Front Load Washer
  • Official Brand Answer 4,342 Answers
  • Posted on Dec 04, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467888
Points
5907
Hello Ibar2000 - I understand that you would like instructions on how to replace bushing on door hinge, however may you please provide me the model number so I can assist you better in pinpointing you the information.
How to remove front door hinges from car 2001 daihatsu yrv
https://raybuck.com/replace-chevy-gm-truck-door-hinge-pins-bushings/
Remove the door spring, old hinge pins and bushings:
1.Remove the retainer clip on the top of the top hinge pin with a screwdriver and pliers. Start to wiggle it loose with the tip of the screwdriver and then grab it and work it loose with the pliers.
2.Remove the door spring behind the hinge - between the hinge and the door itself - by locating the end of the spring and inserting the screwdriver between it and the hinge. Pry, using the door as leverage, until the spring pops out.
3.Spray penetrating oil on the top and bottom of the pins, at the bushings, to make it easier to hammer the pin out.
4.Place your long extension on the top of the pin and carefully hammer down to dislodge the pin, taking care not to hit your windshield or another part of your vehicle.
Now, it's time to grab your assistant!
5.Remove the retainer clip on the bottom of the bottom hinge pin with a screwdriver and pliers. Start to wiggle it loose with the tip of the screwdriver and then grab it and work it loose with the pliers.
6.Place your jack to hold up the end of the door to support the weight when the bottom pin comes out. Have your assistant hold the door so that it stays on the jack and doesn't fall. Pro tip: You can use a 2 x 4 piece of wood to better distribute the door's weight.
7.Spray penetrating oil on the top and bottom of the pin, at the bushings, to make it easier to hammer the pin out.
8.Carefully hammer up from the bottom to dislodge the pin, making sure your helper is holding the door firmly on the jack to support the weight. You may need to have your assistant gently wiggle the door if the pin is binding on the hinge. You can also grip the top of the pin with pliers once you start to work it loose and tap on your pliers with the hammer to fully dislodge and remove the pin. Pro tip: You can use a rag to protect the paint on your door by covering the area with it before hammering upward on the pin.
9.Use your flathead screwdriver to pry the old bushings out.
Now replace the old hinge pins and bushings and put the door back together:
10.Insert the new bushings, taking care to respect the different sizes and where they are located on each hinge. Pro tip: For the top hinge, the larger bushing goes in the bottom part of the hinge while the smaller bushing goes in the top part of the hinge. For the bottom hinge, the larger bushing goes in the top part of the hinge while the smaller bushing goes in the bottom part of the hinge. In both cases, the head of the hinge bolt goes at the larger of the two bushings.
11.Gently hammer the four bushings into place. Remember that the bushings go in the vehicle part of the hinge, not the door part.
12.With the weight of your door still on the jack, work with your assistant to align the hinges and start to slide the hinge pins into place through the bushings - bottom first, then top. Use a hammer to gently tap at first, then hammer more firmly at the end to fully engage the pins in the new bushings.
13.Place your new retainer clips over the bushings and use your small socket or a small hollow piece of tube to hammer the retainer rings in place, ensuring they are fully seated to keep the pins from coming out.
Reinstalling the door spring with or without a GM door spring tool:
14.If you have the specific GM door spring tool (spring compressor) for replacing the door springs, follow the instructions included with the tool.ORIf you DON'T have the GM spring tool, you can compress the spring in a vice and use plastic zip-ties to keep it compressed while you install it.
Pro tip: Install your three zip-ties loosely before you compress the spring and tighten them once you have the spring in the vice.
Carefully hold the spring by the side, not the ends, in case the zip-ties break. Make sure you wear eye protection as you push the compressed spring into place.Carefully cut two of the zip-ties. It can help to close the door slightly as you do this and also rotate the compressed spring to access the second zip-tie. It is difficult to cut the third zip-tie, but it will quickly break on its own as you open and close the door, popping the spring into place.
I have a 04 chevy blazer the diver side top door hinge bushing is bad and I replace it last fall with hinge replacement kit I found at autozone.
Hi I have a 1998 chevy s10. the same parts fit I replaced the same bushing and had the same thing happen to me. What you have to do is put the next size bushing in because the hole that the bushing fit in will get larger over time good luck .From Andrew Toney
1helpful
Car door is sagging
Take a good look at the door hinges. Often, there will be replaceable bronze bushing inserts in the hinges, and the hinge pins are also prone to wear, especially if the recommended lubrication is not done.
If the bushings and/or pins are not replaceable and the wear is in the hinges, the hinges willl need to be replaced.
Other possible causes are loose hinge mounting fasteners, failure of the door or "A" pillar (for front doors) at the hinge mounting location(s) due to rust or physical damage, and (of course) collision damage to the door or door frame.
1helpful
How do I replace the long screw that holds the door up on the door hinges,on a '97 gmc Sonoma?
I have done a 100 of these.
The hardest part is going to be to reinstall the spring on the lower hinge arm. this is not a screw but rather a pin.
There are two hinges that hold the door to body.
when the upper and lower pins are removed the door will come away from body, it is important that before you remove the pins you take a look at the hinges.
Pay close att. to the way the hinges sit inside each other and the way the pins go in. see if they go from top to bottom or from bottom to top. also note where the copper bushings sit in hinges. each hinge has one pin and two copper bushings top go into hinge.
Over time the pins and bushings wear out ,making door hard to open and close. When the pins and bushings get so bad that the bushing is worn out and then the pins are now wearing into the hinge hole itself then this get tricky. if hinge hole is egg shaped the new bushings will not last. the door will hang again in a few weeks. this is where is get costly, the hinges now need replacing. i have gotten good at welding the holes and filing them back to shape but this takes skill or hole will be wrong and bushing will not fit or line up.
Here is a youtube video to help you.
Take note. put jack stands under door with cloth to avoid scratching door.this is to hold door when pins are removed. have somone help you, they will hold door on stands. the wires will still run through door, pull door away from body a little to allow room to work.remove the spring, it will fall out as you remove pins, remove old bushings, clean hinge area and holes,next install new bushings, apply lube to holes for pins and on bushings, slide door back on frame hinges and install pins, next slide lock washers on pins to hold pins. last is the spring. you will need a spring tool, you may rent one at auto parts store. hope this helps good day.
Passenger door is offset, thus pushing the front fender in when the door is opened. What do I need to replace? The door hinge? I'm trying to troubleshoot and help my son fix all the issues with his car.
The problem is ur DOOR HiNGE BUSHiNG! Test ur DOOR if it moves by lifting up, if it moves look at how the hinge plays, the BOLTS might only be loose and needs tightening! Replacing the HiNGE BUSHiNG, pull out the PiN, that holds the hinge from the door to the body panel. Look at the center hole, notice a copper/brass bushing, take it off and replace w/ new one! U need 4 pcs. for each door! Hope that might help u out! Taah!
3helpful
2answers
Driver side door does not close. Latch broken and door sits down below catch on body of car.
may need new hinges on door and body of vehicle, if so it is about 600 -700 to replace , may be able to get new bushing and pins , without replacing hinges
4helpful
Adjust door alignment on dodge truck
The door pin bushings are worn out,replacement of the pin and bushings will align the door back up.Some people to get by will loosen the hinge bolts,and put washers behind the hinge between the door and the hinge on the bottom hinge to lift the door up.
3helpful
2answers
1996 lincoln door hinge adjust
Which door is it ? If it is a front door, then it may be the hinge pin bushing that needs replacing. These can be bought at any auto parts store. Get the pin and bushing set because the hinge pin will need to be ground off to remove it. Press the new bushings in with pliers and insert the new pin from the top
2answers
6helpful
2001 Blazer door hinge pins and bushing replacement
you need a special spring compressing tool to remove and reinstall the hinge spring and then its a matter of removing the door installing the new bushing and rehang the door with new pins ive tried doing this while leaving the door on the car trust me its just harder that way good luck and please rate -jeff
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
