Question about EliteGroup P4M800PRO-M478 Motherboard
I don't know how to connect small cables like USB cable and power cable..Please help... In USB:(Vcc+,Vcc-,Ground,e.t.c) In Power(Power SW,e.t.c)
  • 53 Answers
Ib_ba_87,
Since your using P4M800PRO-M478, I recommend you to read the manual to refer about the pinouts for all the connectors for your motherboard.
Just in case you don't have the manual, here the link for you to download.
Don't forget to rate my solution, thanks!!
Posted on Jan 11, 2009
How can i setteled the front panal usb pin connect on the usb panal on motherboard gigabyte845 gvm-rz
There are 2 USB Ports for the Front Panel USB ie F_USB1 / F_USB2 beside the "PWR_LED". You can use either F_USB ports. Just plug in the USB cable pin accordingly in the Configuration below. Be sure the the negative & positve pins are correctly plug in or it might caused damage to you Mainboard. (Pins 9 &10 not used). For further reference you can download the manual @ Link
Pin No.- Configuration
1-Power 2-Power
3-USBDx- 4-USBDy-
5-USBDx+ 6-USBDy+
7-GND 8-GND
9-No pin 10-NC
Hope it helps.
Aug 06, 2011 | Gigabyte 8IG1000MK Motherboard
How do I connect the front usb wires to my fic c51g motherboard header?
How to Install Front USB by Connecting Front USB Ports to a Motherboard?In order to have front mounted USB you must have 3 things.
  1. A case with USB ports in the front of it.
  2. A motherboard that supports front USB (usually)
  3. Appropriate wiring between the USB port and the motherboard
A case can support front USB in two ways: via a pass thru connection, or via a port to header connection. The former, pass thru connection, is compatible with all motherboards that have USB ports. Pass thru front USB Pass thru front USB works by having the ports on the front of the case connect to either a standard USB cable, or a fairly small rounded cable. The cable goes from the front of the case to a special slot cover with either a hole (for the standard USB cable) or a special connector for the rounded cable. If the pass thru USB had a standard cable, then you would simply plug the standard cable into one of your back USB ports. If it had a rounded cable, then you have a secondary attachment with something that looks like an old style SCSI connector. The attachment plugs into both the slot cover, and the back USB ports. The draw back of pass thru front USB is that you lose the ports in the back.
Many 3rd party devices that add front USB to a system use the pass thru system. A good example is this now discontinued Front IO panel
directron_1721_2292726
Front USB via a Port to Header connection In order to hook up a Port to Header connection you have to make sure that the wires from your port will connect to your motherboard's header. To do this you need to know what header you have, and what type of connector you have on the wires. You'll find information on both below.
Almost all motherboards these days have a USB header. Due to size and cost restraints many motherboards only have 2 USB ports on their back panel, but often they can actually support more then 2 USB ports. They will typically support additional ports via the use of a USB header. A USB header is either a single or double row of header pins on the motherboard that can be used to add additional USB ports to a computer via the use of an appropriate set of header connectors, wires, and a USB port. Each pin on the header corresponds to a wire inside a USB cable. These pins must be clearly marked so that you can hook them up to the wiring correctly. There are 2 common layouts for a USB header.
Intel Standard USB header Layout: (used by over 90% of motherboards)
Gigabyte Style USB header Layout: (used most commonly on Gigabyte brand motherboards)
instusb2b
Now that we know the types of headers we have to take a moment to understand the USB wiring. Understanding the wires First off: All USB cables have 5 wires. 4 of these wires are actively used. Here's a reference from the official USB standard.
instusb3
On a front mounted USB port you'll have either the first 4 wires connected to properly colored wires (red for power, white/orange d-, green/yellow d+, black for ground) or all five wires attached to the port (same as the former, but one extra black wire). Now where it gets tricky is how to attach each of those wires to corresponding pins on the motherboard.
The wires are "tailed" (attached to a header connector) using any one of a number of different types of connectors. Below you'll find a list of the common ones.
Common USB case header connectors 4 joined pins + 1 extra ground.
usbheader
Compatibility: Compatible with both header arrangements because of the extra ground. May not work with some odd arrangements To hook up carefully match each pin. For the Intel hookup you'll have the extra ground wire not attached to anything. For the Gigabyte hookup you'll have the extra ground hooked to ground pin on the motherboard, and the standard ground jumper will be over the missing pin on the header.
All pins separated
instusb6
Compatibility: Compatible with every header. If all the pins are separated the only real issue is lining up the pins with the appropriate places on your header. It should be compatible with all headers. Just make sure you read the writing on each individual connector. Please check the troubleshooting info at the end of the article for important information on this configuration
Power and Ground separate, d-, d+ joined Lian-Li style
Compatibility: Compatible with all common headers. This sort of arrangement is common to almost all Lian-Li cases. Make sure that you get the wires connected to your header in the proper order. If you find that the port does not function the most common cause is accidental reverse of the d-,d+. Try switching it.
All pins joined Intel style easy connector
usbinst4
making the Connection Once you know what type of header you have, and what type of connector you have on the wiring, you need to connect the two of them. In order to do this, you must first figure out what pin goes with what part of the connector. To do this, you should first consult your motherboard manual. Below you'll find an excerpt from a fairly recent motherboard manual for the Asus A7M266 motherboard. It's typical of a motherboard manual for a board using the Intel standard USB header.
instusb5
The first thing you'll probably notice is that the wiring from your case and the names of the pins might not quite match up name wise. This is a common problem. Motherboard makers and case makers really haven't decided on what to call each pin. Here's a rough list of names.
Power may be called: P, VCC, USB Power, Power, and PUSB. On wiring it's always red. Ground may be called: G, GND, Ground, and GUSB. D- may be called: USB-, USBP-, D-, or just -. D+ may be called: USB+, USBP+, D+, or just +.
To complicate things a bit more you'll probably notice that there's a number before each one. Take a look at the picture above from the USB hookup diagram for the A7M266.
You'll see that Asus decided to number the middle pins. On the first row (starting with pin 1, and marked with a 1) you'll find that they list D- as USBP2-, and D+ as USBP2+. The number 2 tells you a few things. First off: It's the 3rd USB port on the motherboard (they started numbering at 0), second it tells you that that D- and D+ must be used for the same port. Case manufacturers are just as likely to number their ports differently.
Take a look once again at the 4-pin joined picture: usbheader
Notice that you're D-'s have either a 1 or a 2 on them. These also tell you that they are part of the same USB port. (Remember, 1 port has 4 required wires). The numbering on the connector and the numbering on the header doesn't have to match.
To connect everything grab the following connectors: a same number D pair, (D-, D+), 1 power, and one ground. If your power and ground are numbered make sure all 4 are the same number.
Tip: Most cases that use all separated pins will bundle these together for you to make it easier.
Now, take your Power, D-, D+, and Ground and line the connector up with the appropriate 4 header pins on your motherboard. The header pins will be in a row under the Intel style, and in the Gigabyte style it will either be a row of 1 pin, a gap, and then 3 pins, or 3 pins, a gap, and then 1 pin. Press the connector down over the header pin and make sure it's firmly attached. Once you have done this go back and grab another set of connector wires (Power, D-, D+, Ground), and hook up your second front USB port. If your case has more then 2 front USB ports, and your motherboard has more then one front USB headers, then repeat the above as necessary.
Example: If you were hooking up the front USB on a A7M266, on a case with the pictured 4-pin joined connector type then: VCC lines up with USB Power, USBP2- lines up with USB1-, USBP2+ lines up with USB1+, and GND lines up with GND. For port 2, VCC lines up with USB Power, USBP3- lines up with USB2-, USBP3+ lines up with USB2+, and GND lines up with GND.
May 21, 2010 | Computers & Internet
I have a PLE01 mother board and i need to plug in the hdd,ldd and ect plugs and i don't know how they go as i do not have the manual and cannot read the small print can u help
Today's motherboard are easy to setup because mostly are now color coded like those connection ports.All you have to do is place the cables according to their color coded ports. Connectors are easy to identified because they are also labeled with name. Like the picture below.
Connections ports on the motherboard are also labeled similar to the connector cables above or have a similar abbreviated names like PSW for Power SW.
I hope this could help you..
Please don't forget to rate. Thanks..
Mar 24, 2010 | Intel Motherboard
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Case wire two mother board
Here is your front Audio guide:
http://www.fixya.com/uploads/images/3C3CD07.jpg
Here is your USB guide:
http://www.marnscda.com/Guide/USBPinMB.jpg
And here is your front Panel guide:
http://www.elhvb.com/mboards/intel/pinout-OEM-Intel-2x9pin.jpg
Let me know how that works out. The front panel guide is rotated 180 degrees however.
May 02, 2009 | Foxconn 661FX7MF-S Motherboard
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Internal connections
ok for the front cable lights etc. Usually the HDD is place in the left corner. You should see the letters HDD somewhere if it's in a different position. Usually the Power LED light go in front of it away from you. All the lettering on the cables should all face you. The power switch is the most important that has to be placed only in the alloted position. If this is plugged in wrongly then nothing will work. At least with the other 2 we mentioned earlier they only have lights working on the front of your case. They're just cosmetic really.and the reset switch will have it's own position too. With the USB ports There should be only 9 pins. One row with five and the other with four. The one with no pin should be to your right. There should be two cables with VCC1 VCC2 D-1 D+1 D-2 D+2 and ground . Usually the colouring for the VCC is red. They go from left to right. VCC then the negative then the positive and then the earth or ground. There should be a spare pin left and the other shouldn't have a pin at all so 8 pins are covered. Lets hope this all works for you. Note some of the lettering i used may differ from what lettering you see on you motherboard.
Jan 25, 2008 | Compaq Presario 7594 PC Desktop
Can't connect front panel Power SW cable
On your board in the corner at bottom, you find pins for front panel Power Switch Cable, over there in small characters PWR SW is written, you can put your Power SW Wire there
Jan 02, 2008 | Intel D845HV (735858149143) Motherboard
Power switch
You could try searching for the manual for the motherboard, I have the same problem every time I disconnect a motherboard.
Sometimes it is printed on the motherboard in dead small writing which wire goes where.
Also usually motherboard manufacturers follow the "unofficial" standard io connectors.
+PLED -PLED +PSW -PSW NC NC NC NC
+HDD -HDD -RST +RST +SPK NC NC -SPK
Key:
PLED = Power LED/Message LED
HDD = Hard Drive LED
RST = Reset Switch
PSW = Power Switch
SPK = Speaker
NC = Not connected (sometimes not even there)
Note quite often the Reset switch is the reverse of everything else! (i.e. on most if the + is on the right the + is on the left for the Reset
The USB ones usually always follow the following standard
VCC -DATA +DATA GND NC (USB1)
VCC -DATA +DATA GND NC (USB2)
And usually one of the NC pins is no pin as some USB cables have that pin blanked out to ensure you connect them the right way. Note also with USB you start with the VCC then you go straight to negative data, then positive, then ground (again the - and + data bits, like the reset are in reverse of normal reading - the are right to left, not left to right!)
Finally if your not sure which cable is + and which is - the - ones are normally either black or white (most of them are white, except the speaker ones which are black - I presume that goes back to the colour scheme of red and black for positive and negative in audio equipment) and the + ones are normally some colour.
Dec 11, 2007 | Abit nForce2 NF7-S2 Motherboard
EliteGroup P4M800PRO-M478 Motherboard Logo
137 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
