Question about Echo Garden
Need to replace starter pawl on Echo pb403T blower
I just bought the replacement recoil assembly for Echo PB403T. I double checked the part and part number(P021009450) and it IS correct, however although the recoil looks the same, the pawl that came with the new assembly is different than the one on the machine, so i need to switch out the pawl also. The pawl screws on to the shaft, but its seems theres no way to lock down the shaft to unscrew the old pawl, unless i lock the piston, which seems like alot of work to just switch out a recoil assembly. Any ideas how to remove the starter pawl. ?
2 Suggested Answers
bbreton
  • 437 Answers
SOURCE: echo pb413h blower removing starter pawl assembly
I looked on ECHO website for serial#0200-02999. the part number is 17720206210. you don't need a pneumatic tool to remove it but it is nice to have. I would not use the high setting. But you should be able to use just a socket to take the old one off and put a new one on.
Good Day.
Posted on Oct 16, 2009
The recoil starter on my stihl br420 backpack blower doesn't engage.
Replace the entire starter assembly on both sides...
May 02, 2017 | Cars & Trucks
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
Spark plug gap for echo pb403t backpack blower
.028 but between .025 ~ .030 is ok
NGK BPM8Y
Apr 26, 2015 | Echo Garden
Fuel mixture for echo PB403T
50:1 and use either the Red Armor or the Echo synthetic ( psst, they;re the same thing and a very good product )
Aug 27, 2014 | Garden
Pawls don't catch on rancher 455
The starter pawls are held on with small springs. If the springs are broken or installed incorrectly, this can happen. I would suggest replacing the springs and maybe the pawls. Check the recoil assembly to make sure the issue is not with the recoil assembly.
Feb 08, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Where do you find the serial number of a echo PB403T
Model and serial number are underneath the recoil starter, on the engine block. Tip the blow on it's non-engine side and look right above the tank from underneath the blower.
Nov 04, 2013 | Echo Pb-403T Leaf Blowers
Cord is locked, or maybe its the motor. Its an Echo PB260L Backpack
This is easy enough to check. There are 4 screws that secure the recoil starter to the engine. Remove these 4 screws and remove the starter assembly. Pull on the rope and see if the starter is operating properly. If not, go to your local Echo dealer and get a new one...they are about $30. Also try to turn the starter cup by hand to see if the engine is locked up. If the engine is locked up, remove the spark plug and try to turn the starter cup again. If it is still locked up, then the repairs would cost more than a new blower.
Dec 20, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
Echo pb413h blower removing starter pawl assembly and installing new one.
Good Day.
Oct 16, 2009 | Echo Garden
Garden Logo
110 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
