Question about McCulloch Garden
Mac M1000 PARTS
I'M LOOKING FOR THE PART THAT' CONNECTS THE WATER HOSE TO THE WASHER ON A MAC M1000.
dontbother10
  • 2220 Answers
SOURCE: I'm looking for free downloadable owners manual
Beg for manuals thread
http://www.arboristsite.com/showthread.php?t=72322
If needed it is free to join.
Posted on Sep 20, 2009
  • 40 Answers
SOURCE: hotspot shield connects on my mac but doesnot allow access
go to banyone.com and type url in box and its done
Posted on Oct 30, 2009
  • 1738 Answers
SOURCE: looking for driver for gr-dvm96u jvc for mac
Click on this link and click on the first option.
http://www.helpdrivers.com/ingles/listado/panellis.asp?marca=JVC&perif=Camaras2
Posted on Nov 29, 2009
  • 178 Answers
SOURCE: looking for parts manual for
http://www.mccullochpower.com/node7877.aspx
Try this link, they will need the actual model number of the chainsaw. Let me know if that helps.
Posted on Nov 21, 2010
mc1bean
  • 3053 Answers
SOURCE: water leak where the gun
Simple fix, just disconnect house end from washer, buy a new rubber washer o ring, like what is used for garden hoses. Put back on make sure it is tight. If still leaks, then need to replace connection end fitting on preside washer, can get those at almost any hardware store, use plumbers tape on threads when putting new fitting on machine, then connect house and back to those honey do list :)
Posted on Jun 08, 2011
I took my whirlpool washer a part I found a sock stuck where the water hose in an out. But now I for got where the smaller hose connects to
I don't know what you are looking at, but there is a small usually clear hose that connects to the water level switch. It is located high in the unit and has a two wire harness
May 14, 2016 | Whirlpool Washing Machines
Kenmore won't fill with water
Make sure your water valves are turned on. Check for blockages in the rubber hose and especially where the water enters the washer. Sometimes the chack valve of a washer can collase and restrict the flow of water entering the washer. It is usually located just beyond where the hose connects to the washer. Metal screens can clog and stop water flow. Check and replace as necessary.
The electronics of the washer may also not be advancing to the point where it allows water to enter, The main dial may be faulty. Check and verify all washer settings also
Aug 04, 2012 | Kenmore 4.5 cu. ft. High-Efficiency...
Where to buy used mac notebook parts
ebay can be a good place. powerbookmedic.com is a pretty good place too. they have new and used parts (used parts aren't always available, however on a laptop this old, i would assume they have some) and also have videos and PDF files on step by step disassembly. I have found it to be a pretty good resource for apple repair. hope this helps:)
Jun 26, 2012 | Apple PowerBook G4 Mac Notebook
Danby washing macine is leaking
Hi There,
I have just spoken to a technician here at Danby and he suggested to replace the washer in the hose.
If that doesn't work, please feel free to contact our customer service department at 1-800-26-DANBY (1-800-263-2629)
Jun 19, 2012 | Danby DWM99W Top Load Washer
Macbook plastic casing broken
For any apple repair. The absolute best place to get repair parts is Apple itself. Everything you get will fit perfectly in accordance to the model, and make. Don't try other places because through my experience it's never the right one u are looking for.
Apr 03, 2012 | Apple MacBook Mac Notebook
Washer wont wash-no water comes in washer
Your water valve inside the washer is either stuck, no water going to hose or the washing isn't sending voltage to open the valve. Start first by removing the hose. If water starts spraying all over the place turn off the hose and check for a blockage when it connects. Sediment may have clogged the screens there. More than likely a new water valve should take care of the problem. Sometimes sediment can pass through the screen and accumulate causing it not to open causing it to stick when voltage is applied as well.
Jan 16, 2012 | LG WM-2277HW Front Load Washer
Where can I download a driver for HITACHI CP X 260 for mac?
i didn't know mac needed drivers for projectors.... windows just connects right away
I thought mac did the same thing
I didn't find drivers for any Hitachi projectors
you might wanna get the conversion thingy for the mac input tho, if you don't already have it
and if you do you might wanna get another one, cuz some don't work correctly which might be the case
Aug 08, 2011 | Hitachi CP-X260 LCD Projector
Show diagram of fuel lines to carb for mac 3200
There is nothing available to the general public that provides what you ask! If service manuals exist they may not have the detail you seek!
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple. On the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I’ve found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operator’s Manuals: are much more difficult. I’ve dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it!
I cannot find an IPL for a 3200. Some fuel components, part numbers and a little detail can be found below:
An IPL (Chinese Mac, exploded parts list) can be fond here:
https://www.dixiesales.com/ipl/327/Chainsaws_32cc-35cc.pdf
You may also find the following helpful:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Typical fuel system:
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Nov 20, 2009 | Garden
Need to remove & replace primer bulb on mcculloch mac 3516
There are 4 different IPLs for this saw. Fuel detail are on multiple illustrations.
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
A helpful video, a few of my suggestions, and a schematic follow:
HTH
Lou
Nov 15, 2009 | McCulloch Garden
Garden Logo
67 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
