Flat Screen Insignia TV picture too big? How to adjust picture size?
  • 736 Answers
When the picture is too large there are three possible solutions at least.
Starting with the simplest two: There are buttons on the remote controls (cable/satellite and television) that control the picture size. On the cable remote it is usually on the bottom, and it says hd zoom. Press it and it will size the picture down for you. On the television or satellite remote it might say view mode, picture mode, format or aspect.
Now, the more difficult solution if the above doesn't work: The settings might not be right in the cable box/set top box. If the television is a 720p television, make sure the cable box/set top box is set for 720p and not 1080i even though they're the same (yes, yes I know). Also make sure you are not connecting a cable/set top box to the coaxial rf input when you have the capability to connect to a component or hdmi cable. I hope this helps.
Posted on Dec 01, 2012
rulds2008
  • 3866 Answers
SOURCE: how to make a flt screen in to full screen picture
On your remote there should be a ZOOM button that will strech the screen to full screen it may not be a desirable look but most formats today for HD tv is widescreen format also in your menu system you can change this as well. thanks for using fixya please click the accept button.
Posted on Aug 18, 2009
  • 15 Answers
SOURCE: Picture Is Too Big for Screen
Sounds like your cable box is zoomed in, I run into this a lot when running service calls. On most cable provider's remotes there is an 'aspect' button next to or around the '0'. Try that and see if it helps you out at all :)
Posted on Feb 24, 2010
SOURCE: Picture is too big for screen
Go into the setup menu of the TV, and you'll find a category called DISPLAY or ZOOM. That's where you can change the aspect ratio so that it fits on the screen. You'll probably get a gray band on the top and bottom of the screen due to the re-sizing.
Posted on Dec 20, 2008
SOURCE: Insignia flat screen
I have the same problem with my insignia.
The screen was all "pixel-ated" .
Sometimes the picture would be clear and then it would go all fuzzy.
One day in frustration I kinda smacked it. Guess what? ... the picture cleared up.
Since then about once a week I kinda have to smack the right or left side jst to the left or right of the screen.
Good luck.
Posted on Mar 24, 2008
DRebel
  • 19 Answers
SOURCE: TV picture doesn't fit in screen no matter what the setting
Ok, so I think I have your solution :)
You're actually my first when it comes to this site, so hopefully this fixes your problem!
Step 1 - Turn off the cable box, but leave the TV on
Step 2 - On the front of the 8300HD, press the "guide" button and the "info" button at the same time
Step 3 - Choose "HD" for High Definition, or "SD" for standard definition. (Sounds like you're HD?)
Step 4 - Choose the aspect ratio 16:9
Step 5 - Choose "progressive scan" if it asks you.
Now press the "power" button on the box, does that fix it?
Posted on Apr 03, 2009
Aspect ratio is incorrect, not proper screen size
Check its user manual for details about adjusting the aspect ratio or contact the dealer.
Apr 17, 2013 | Insignia Televison & Video
Picture to big for screen
check the screen aspect. The picture has different setting that you can use. You might have your tv on a strech screen.
Feb 24, 2012 | LG 42LD520 42 in. HD-Ready LCD TV
I just purchased my Dad the 32" Insignia 720 for Christmas. He just called and said he can't format it for widescreen. He has Dish Network, any suggestions?
Hello! If he's not getting a clear picture or a full picture he may need an HD receiver. If it's just not a full picture go through the tv menus and adjust the picture size you can call insignia as well their number is: 8774674289
Daniel Busa
DISH Network Customer Service
Jan 04, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Insignia 32" 720p Flat-Panel LCD HDTV - High-Gloss Black Picture is too big for screen ,cut off all around, top, bottom and sides. Can't read things on screen, heads cut off etc. I've gone through...
try checking the menu setting on your Dish Network, there may be a television format in that menu set up, if it is only when a dvd player is playing, then check the format on that, so on so forth... that is one place to start, check if it is local (TV) or if it is from attached component ( Dish dvr/ dvd etc). also refer to your owner's manual.. if all else fails, call customer service @ insignia
Oct 17, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Insignia 32" NS 32 q09
Since you don't mention how you're receiving the signal, I'm assuming you use a cable box or computer. Adjust the output settings (e.g. 720p, 1080p) on the box and then adjust your TV settings. If it's a computer, you'll need to adjust the video card settings to a compatible aspect ratio (e.g. 1366x768) for the desktop to display properly on the TV. Details can be found in the owner's manual.
Jan 04, 2010 | Insignia 37" LCD Flat-Panel HDTV
On my Insignia LCDTV26 I have almost 3" of black screen on the right and left side of the picture.
This is normal if you're watching a 4:3 (full screen) broadcast or movie on your widescreen (16:9) TV. You can adjust the screen aspect by going into the Settings Main Menu and selecting System, then Aspect Ratio. I hope this helps!
Jul 22, 2009 | Insignia LCDTV26 26 in. Television
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
Televison & Video Logo
2,170 people viewed this question
Top Televison & Video Experts
Electro Med Services...
