My Davey xp 350 household pump keeps cycling every few seconds. There doesnt seem to be any leaks. What could be the problem?
The pump is connected to just one outlet and was working just fine but then started to cycle, cutting in and out every few seconds.
jsrock516
  • 5911 Answers
SOURCE: leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Posted on Jun 20, 2008
  • 4 Answers
SOURCE: monitor keeps going blank at start up
This looks to be a power supply fault - the inverters for the backlights are built into the power supply (Delta Electronics, model no. ADP-40AF).
Posted on Dec 11, 2007
  • 142 Answers
SOURCE: maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Posted on Mar 10, 2008
SOURCE: OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Posted on Jul 11, 2008
  • 236 Answers
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
Davey pump loosing pressure from rain water tank to house but seems to be fine through the day but loosing pressure at night?
replace the pressure control switch as the problem indicates the non-return valve is leaking back and not holding pressure
Dec 10, 2016 | Plumbing
Davey presssure pump when switched on b4 tap is opened the pump does run stop run stop run stop between each cycle small squirt of water escapes from pressure tank at the clamped junction
fix the leak as the pump build pressure switches off , the leak looses pressure pump switches on and so on
fix the leak and the pump will build pressure and switch off until the tap is used
Nov 19, 2016 | Plumbing
How do I get my spa to heat up? please provide me instrctions
turn up heat if it doesnt go check temp if it seems odd replace temp sensor ohm it out if 78 ohms at 70 degrees its ok then check heater element fuses and element
Oct 03, 2014 | Pool & Spa
Davey HP45-05 with Rainbank will not turn off?
Hi Sam,
Combined Electrical in Fyshwick ACT here. Has your problem been resolved?
We have found that a leaking cistern which can only be a few litres a minute can cause this problem.
Aug 14, 2012 | Plumbing
My Hayward pump is pulsating rather than keeping a
make sure all intake unions are tight you have a air leak or top pump seal is bad
Jun 09, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Water Pump (Davey XP500H)keeps switching on all through the night
put a timer on it so it won't run all night.
Jan 06, 2010 | Dishwashers
99 ford expedition, abs light stays on, front brakes seem to be dragging
When was the last time you changed the front brake pads?
Try this:
Keep the brake pedal pressed down and start the car, after it idles for about 10 second let go of the pedal. If the light comes on just as you leave the pedal - try pumping it a few times, turn the car off and pump the pedal some more until it becomes real hard.
Then, keeping your foot to the pedal, start the car.
Idle for about 10 seconds, let go of the pedal and press it again rel fast.
If the light doesnt come on again - it means you have a leak of some sort or that the main brake pump should be replaced.
Good luck.
Jul 11, 2009 | 1999 Ford Expedition
Maytag gas oven cycles every 20 seconds
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
Jan 18, 2009 | Maytag CWG3100A Gas Single Oven
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
