Question about Utilitech 1-HP Lawn Pump UTP10P1
I have a UTP10P1 sprinkler pump and when I installed it, one of the wires was stripped against the edge and I didn't see it. As a result, it shorted and tripped the breaker. Fixed the wire issue
2 Suggested Answers
boysor2933
  • 293 Answers
SOURCE: I have a Utilitech 3/4 HP jet shallow well pump #0003134. On start up, it hums a long! time before turning, sometimes tripping the 15 AMP breaker. Anything I can do?
Try replacing first the capacitor. If it will not solve your problem, check the integrity of the motor winding insulation by doing a line to body resistance measurement. If it is okay, replace the motor bearings.
Posted on Nov 06, 2012
How to wire it from 110v to 220v...
Most pumps have the eiting diagam on the outer motor housing. What brand is the pump? Some motors have a jumper that is moved over to 220v or 110v post and the red/black(220) or white/black(110) stay on the regular screw terminals. Ground stays on the same terminal usually a green screw
Jul 21, 2013 | Utilitech 1-HP Lawn Pump UTP10P1
Not enough flow and pressure to run sprinkler system
pressure in centrifugal pumps depends on the number of impellers in the pump housing, the clearance of the impellers to the housing and the power of the motor to drive the impeller/s
volume flow is also important as a pump without a high output will not produce pressure
check the jet size at the foot valve that is used to help lift water to the pump
It is a jet pump and will have a smaller line back to the foot valve for that purpose
next wil jet pumps if there is too much flow to the outlet , the pressure required to help lift the water to the pump is reduced and the volume is also reduced
you indicate 4 sprinkler heads per zone but how many zones are operating at one time
check the expected delivered volume for the new pump against delivered volume of the old pump as a starter to find the reason for the poor performance of the new pump
check also the rpms of each pump as that also has a bearing on volume produced
Mar 26, 2017 | Flotec Pump FP4032-10MK
Do I need the wands for sprinkler to work?
Yes, That is how it gets propelled down the hose.
Mar 30, 2013 | Nelson Sprinkler: Traveling Tractor
How to install t8805p101c
T8805p101 is 120Volt timer with 14-day skipper wheel that is made for sprinkler systems or pumps up to 1/2Hp.
Copy following links for wiring diagram, manual, and general instructions for setting and repairing T8805p101.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html#T8805
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
Jul 23, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
I have a intrermatic r8816p101c that some one removed need to put new one back dont know how i have 2 red wires coming from pump and to red wires coming of the wall witch has a on and off switch how do i...
You have Intermatic 240Volt sprinkler timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8816p101c%20-%20english.ashx
Timer relay has 4 wiring terminals: from left to right 1 2 3 4
Red wires from switch connect to terminals 1 and 3
Red wires to pump connect to terminals 2 and 4
Since circuit is 240Volt, red wires from switch can be connected in either order. Same with pump.
Rain sensor terminals don't have any wires, unless you but separate rain sensor.
Parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Aug 10, 2011 | Intermatic Hardware & Accessories
Nelson Sprinkler Rain Train Traveling Sprinkler will only go backwards , i have the arms going in the right direction...please help
If it's going backwards, and assuming you didn't take it apart and put it together wrong, then the arms aren't going in the right direction. Looking down from the top, my unit should be moving clockwise if it's set up correctly. In any case, switch it so the water pushes the arms in the other direction. the transmission is pretty straightforward - if it's going in the wrong direction then the arms are spinning in the wrong direction.
Aug 02, 2011 | Nelson Sprinkler: Traveling Tractor
What does the "auxillary heat"
Auxiliary Heat is used to turn the electric heat strips ON, If the heat pump is not working. Or if the heat pump can't bring the space temperature up to Set Temperature it will display Aux Heat ON....... Assuming you have a Heat Pump System with Auxiliary Electric Heat as Back up...... If the tech didn't install a jumper wire from AUX to W on the subase which is in back of the Display on the Thermostat.....you won't get Auxiliary Heat if the Thermostat is set for Auxiliary Heat. Other wise the thermostat will turn the heat pump on first and then the electric heat (Aux Heat) if it needs it to satisfy the set temperature....... Hope this helps
Apr 21, 2011 | Honeywell Electronic Programmable...
Where can I get gears for my Nelson tractor... one of the gears is stripped.
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Aug 12, 2010 | Nelson Sprinkler: Traveling Tractor
Utilitech 1-HP Lawn Pump UTP10P1 Logo
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
