Question about KitchenAid KGST307 Gas Kitchen Range
Do not know how to remove the oven ignitor does not ignite
Pretty sure the problem is the ignitor. Unscrewed the two screws holding the part in place - now what do I do about the wires that appear to go through the back wall of the oven
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
Here is the igniter if you need to order it and on the same page is a video to walk you thru the replacement process.
Posted on Dec 02, 2012
Testimonial: "Good info from this expert. We were able to determine the problem and the fix. The range is a slide in, difficult to pull the unit out from the wall and get to the plug in for the ignitor - ultimately we hired a repair person who cut out the old ignitor spliced in the new one - we could have done that too but were focused on the 'correct' repair. "
Gas oven not getting hot - glow bar works but no gas to burner
This happens when an oven igniter (glow bar) is bad. The igniter must draw enough amps to turn on the gas to ignite the flame. If you have a square shaped igniter use this part#5303935066 If your have a round shaped igniter use part#wb2x9154. These igniter will pretty much work universally for most gas ranges or ovens.
  1. Remove the racks
  2. Unplug unit
  3. Take out the screw holding the bottom pan
  4. Remove screws holding manifold where igniter is attached
  5. Remove manifold cut wires about 2in link from igniter and clean leads.
  6. Unscrew and remove igniter
  7. Replace Igniter with new one and fasten onto manifold
  8. Clean wires and screw on ceramic nuts to wires
  9. Tuck wires back and Reinstall all components
Test your new igniter. You might notice it taking a little longer to light up but that is okay.
Please let me know if this was helpful by rating me a 4.
Thanks so much have a great weekend.
Dec 12, 2010 | Frigidaire Gallery 30" Self-Cleaning...
GE XL44 gas oven
well..that's a gas issue, not an ignitor issue..did you check for the pilot to be active? or is this pilot less?
Apr 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My Maytag Gemini cooktop and top oven work. The bottom oven will not heat up past 100 degrees. What is the problem?
Replacing the ignitor is not difficult or dangerous. To get at it, you will first take out the racks. Then undo the box-like cover inside the bottom of the oven; the screws face front. Underneath that is a wing-shaped cover, held in place with wingnuts. Remove it.
The pipe that the gas comes out of heads straight back; the ignitor is just to the left. You'll be able to see the wires going out the back of the oven. Remove the plates that hold the tube/ignitor combination.
Once the pipe is free, then get your head out of the oven and pull out the oven so you can see, and get at, the back. On the lower left is a cover, about 12 x 15 or so, held in place by four screws. Remove it.
At this point you can see where the ignitor connects to the orange wires (at least mine are orange) with a plastic connection. Undo that connection.
Viola! You have removed the ignitor! Now, before you forget, make a diagram of everything you did. Put the screws in separate plastic baggies, with paper number tabs that correspond to your drawing. This will greatly help in putting everything back together.
Dec 12, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a GE Gave oven. THe top burnes work and the broiler works but when I set the oven to BAKE, nothing happens. THe digital display says it is pre-heating, but it doesnt get hot??
you have a bad ignitor,take out the racks and remove the floor of the oven,you'll see the round ignitor with two 1/4 inch screws holding it on,you can remove the burner tube that the ignitor is connected to with the ignitor on it or you can remove the screws,cut the wires close to the old ignitor and remove it,screw on the new ignitor,leave around6 or 8 inches of wire on the new ignitor,cut back the old wires so you can wire nut the wires together,start the oven and the ignitor should ignite the flame in like 20 to 40 seconds.it doesn't matter what wires you connect,you don't have to worry about if the left wire coming out of the ignitor connects to the same wire the old one connected to,just as long as the wire nuts are tight on the 2 connecting wires you'll be fine.the part number is WB13K21 and the ignitor is around 80 bucks.you can kill the power to the oven but no power is going to the ignitor if the bake isn't on so as long as you don't touch anything else you'll be fine,let me know how you make out
Nov 15, 2010 | GE 30 In Freestanding Gas Range ...
I have a Maytag Oven Model CRG9800BAE Will not ignite gas when turned on.
are you saying that when you set it to bake the oven doesn't heat or are you talking about the top burners?if it's the oven you have a bad ignitor, the oven flame should lite in under 40 seconds to a minute,if it doesn't it's the ignitor,part number 12400035 and it's around 80 bucks.unplug it or kill the braker,take out the racks,remove the bottom panel or oven floor,take off the wing nut and remove the metal cover and you'll see the burner tube and the ignitor,,with a wet paper towel wet the screw threds on the two screws with water so they don't strip out and then remove the two screws holding the ignitor on,trust me it works.if you have to, unplug the ignitor or if it's not the original ignitor cut the two wires at the end of the old ignitor and connect the new ignitor with the ceramic wire caps and remove the burner tube if it's hard to get at the ignitor screws.put it back together and the ignitor should lite the flame in less than a minute.let me know how you make out
Aug 22, 2010 | Ovens
My kenmore oven needs a new ignioven tor. How do i remove the old one? Model No. 9117147810
Hello SHpall,
To get at the ignitor, you need to remove the shroud around it and that will allow you to get at the screws that hold it in place, etc.
First, make sure the power is turned off to your wall oven, at the breaker panel. Then you can remove the racks and get to the ignitor shroud at the back of the oven. Once you've got the shroud (cover) removed, you should be able to remove the screws that hold the ignitor in place and then carefully pull it and the wires out, so you can disconnect them from the oven's wiring harness.
Some models do not have connections at the back of the ignitor and you will have to remove the oven to gain access to it from the backside.
The bes thing to do is first check from the inside, as that's obviously the easiest to do without having to take the oven out of the installation location.
Reinstall the new replacement ignitor and reverse the above steps and you should be fine.
I hope you find this Very Helpful and best regards!
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=9117147810&productCategoryId=0124200&brandId=0582&brandDescription=KENMORE&modelName=KENMORE-30-INCH-GAS-RANGE&diagramPageId=00003&componentDescription=BURNER%20SECTION&documentId=00003533&blt=06
Dec 24, 2009 | Kenmore Ovens
How do i remove the bake burner and igniter from a kenmore gas range oven?
Hi, You will need to remove the bottom panle inside the oven to get to the ignitor. There are screws that hold the burner to the frame of the oven. The ignitor has 2 screws holding it to the burner assembly. I hope this helps you.
Please let me know if I can assist you further.
Vic
Jul 11, 2009 | Ovens
Ignitor
hi thanks for the question remove that screw remove the burner assy now remove the screws that hold the igniter .replace parts thanks the appliance doc
Jun 11, 2008 | GE JGRP17 Gas Single Oven
Installing WB2x9154
For women from a woman's point of view: Most if not all the screws were hex head 1/4. Have appropriate tools. A socket set will work. I like my little cordless screw driver. You will also need wire strippers and two wire nuts, they say ceramic wire nuts and electrical tape. It is also a good idea to have a someone else there for safety sake. I tipped the stove back.
Take everything our of the oven. Take big screws out at the back bottom of oven. Lift bottom of oven and push toward the back of oven. (There is a lip at the front that oven floor slides unde). Be careful as there are sharp edges all over the place once this oven bottom is off. Next unscrew the screw at the front middle of oven that holds the long burner in place. Next pull the stove drawer out and set aside. Pull stove out just enought to put large juice cans under the front legs. Way at the back you will see where the burner comes down to the gas line. There are two screws holding it to the back of the stove, remove them. Next find the two wires that come from the igniter. Unplug them. Lift out the burner. Unscrew the two screws that hold the igniter on to the burner. Carefully put the new ignitor on the burner. If the new ends do not match the old ones or if they are shorter, cut the old ones off near the old ignitor. Cut the ends off the new ignitor as far from the ignitor as you can. Clean the ends off so that about a half inch of wire is bare. Put the old ends on the new wire so that you can plug them in. Hold the two like wires so that both bare wires are parallel and screw on the wire nut. Lay it parallel to one wire and wrap electrical tape around it so that it will not pull loose. Plug in the way it was originally. Put everything back together opposite of the way you took it apart.
Jan 24, 2007 | GE Profile Spectra JGBP79 Gas Kitchen...
GE XL44 gas oven
Starfish, remove the oven racks, in back there will be two chrome screws, remove them. Lift the lower oven panel out by pulling up from the rear. Remove the screws holding the flame spreader and remove the flame spreader. Now you will see the burner and igniter attached to it. There are 2 quarter inch hex screws holding the ignitor on. GE likes to put them on an angle where you cant get at them. If you have trouble you can remove the bottom drawer and remove the screws securing the burner to the back wall. There should be one in the front too. The burner will now lift up and you can get at the screws. The new ignitor should come with ceramic wire nuts. Just cut the old igniter, strip the ends of the wires going to it and wire nut the new one on. Reverse the rest of the steps. Here's a little trouble shooting schem. Catriver...post back.
Jan 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KGST307 Gas Kitchen Range Logo
362 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
