Ager rcm-260h air con works but outdoor unit fan not kicking in
Therinnaiguy
  • 1420 Answers
SOURCE: Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Posted on Oct 10, 2007
  • 3 Answers
SOURCE: The fan in the outdoor unit does not work while the AC is on.
these motors are famous for the inyernal fuse blowing in the fan motor. check continuity between the red and blac wires. if there is non the fuse is gone. These motors are fairly easy to take apart and change the fuse . hope this helps
Posted on Sep 01, 2008
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
SOURCE: My Blueway air con is not cooling , fan works but is not cooling
More than likely the capacitor is bad internally
Posted on Jan 21, 2009
  • 6 Answers
SOURCE: fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Posted on Feb 16, 2009
Why does the compressor for the air conditioner not go on even though the circulating fan does.
What sort of air con is it? If its a split or ducted with a separate outdoor unit, does the outdoor fan start ?
Mar 18, 2015 | Heating & Cooling
When the air con is on heating it works fine for about 5-10 minutes and then the compressor stops and then the outdoor fan stops and then the indoor unit stops heating.
This could be any number of problems depending on whether this unit is a heat Pump or not. It sounds like it is a heat pump, if so it should have a defrost board or Control of some type. They also usually have a defrost or ice sensor on the outdoor Refrigerant coil. When ice or heavy frost is detected it puts the unit into defrost. This Could be why your unit is cycling off, the sensor could be bad or the board could be Bad. Also be sure your air filters are clean and the indoor and outdoor refrigerant Coils are clean. This may require you to remove the unit and hose it out.
Aug 09, 2011 | LG Art Cool LA121CNP wall/window Air...
Just purchased a home in Sc. had been vacant some time! Aircondotioning unit was' nt hooked into power pane, just did that, provided call for air con via thermostat and extirior unit kicked on nice as...
It probably hasn't been serviced in a while. You need to check the outdoor coil and make sure it isn't stopped up with dirt. Let me give you a good website that will take you through a typical servicing of an outdoor unit. Also make sure you change filters in the indoor unit. If you do all this, and it still doesn't cool, you will need someone to check the refrigerant. Here is the website: www.familyhandyman.com
Hope this helps let me know if I can help you any more. Mark
Jun 27, 2011 | Ruud Heating & Cooling
Is it normal for the outdoor unit on my coleman h/p to make a surging humming noise? the fan does not run during this period, approx. temp. is 28 degrees F. the fan runs 30 seconds befor the unit...
Sounds like your unit is going into defrost mode. When this happens the fan in the outdoor unit shuts off so you get more heat in the outdoor unit to defrost the coils. The heatpump is basically in A/C mode during defrost and the electric heat strips will kick in so you don't feel a cold blast of air in the house.
Jan 03, 2011 | Heating & Cooling
Lennox central air for home not kicking on. Fan on the outside not spinning but motor is making a humming noise. No cold air coming in home. We have circuit breakers they are turn to the on position. ...
Is the indoor fan working? The problem with the outdoor fan sounds like it could be your capacitor. Turn off the power to the outdoor unit and make sure the fan turns freely using a screwdriver or something that will reach the blades. If it turns freely then it is probably the capacitor. Let me know what you find.
Aug 25, 2010 | Goodman CLT36AER36 Air Conditioner
Have just installed a Fujitsu Asta 24lC air con heat pump problem
Hi Shannon,
I would pursue your fight with Fujitsu, normally their units are reliable:(
It could be a really simple problem or a really complex one ranging from many componenets. A air conditioner has many more components that people may think. Keep fighting to get the unit repaired will it is still under warranty, after that Fujitsu wont want to know you. It could also be a wiring and refrigerant fault. Call Fujitsu out again.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Outside fan does not kick on just buzzes
The buzzing noise sounds like the contactor is energizing and if it is then you need to check to see if you have power 230 volts to the outdoor unit, if not, check the fuses or breaker, if you do have power then you may have a broken or burnt wire inside the outdoor unit.
Apr 28, 2009 | Heating & Cooling
Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Apr 15, 2009 | Fujitsu 18R1 Air Conditioner
Fujitsu split level
Check for errors like blinking indoor light if present. Reset the error by disconnecting power supply from the unit for 10 sec. and "on" the unit. If the error persist, some parts of the unit may be defective and need to replace. Like room air thermistor, coil thermistor in the indoor side or the relay board. Some safety device in the outdoor may give in, some outdoor parts may be defective. You need a qualified technician for the this problem.
May 17, 2008 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
