Question about Fujitsu Stylistic ST4110 Tablet PC
Fujitsu siemens St4110 touch problem
The touch screen is not working with the pen
Fujitsu Siemens T5010 penabled upgrading to dual touch
Help, is this how you upgrage a pen only to a multitouch? I need the part numbers to do this..
Nov 28, 2012 | Fujitsu Siemens LifeBook T5010 Tablet PC
Fujitsu Siemens Stylistic ST4120 Tablet PC pen not working with screen
I just fixed this problem on the 4120 for a friend, What I did was first to install the drivers from the Fujitsu site so XP was displaying all drivers as installed in Device manager.
Then I ran windows update to patch it up to date and then I downloaded the drivers from the wacom site.
http://www.wacom.com/en/support/drivers
Then choose tablet pc from the first drop down and then os (xp in my case) from the second drop down.
Reboot
Pen working!
Sep 01, 2012 | Fujitsu Siemens Stylistic ST4120 Tablet PC
I have windows xp,sp3 on a Siemens Fujitsu Lifebook T4010D. First of all, the tablet and the pen didn't work after installing the OS, also with all drivers installed. A few days ago, when xp was...
All of these drivers must be loaded;
LifeBook T4010D Driver Name Version Size (bytes) Audio V 6.14.1.3916 1,926,959 ACPI Device Driver V.1.21 9,437ACPI_Ext Device Driver (For model with Integrated Bluetooth) V.1.0 8,365 Bluetooth Device Driver (For model with Integrated Bluetooth) V.3.01.03F 15,615,696 Chipset V.4.30.1006 2,374,963 Fujitsu HotKey Utility V.2.30 1,119,189 Fujitsu Button Driver V.1.1.0126.2004 273,237 Fujitsu Button Utility V.1.0.0825.2004 976,478 Intellisonic V.2.0.1 4,077,455 LAN V.7.84.0.0 154,167 Modem V.2.1.41 883,675 MultiMedia Bay V.1.0.7.4 4,964,535 Radio Control (For model with Integrated Bluetooth) V.1.0 853,561 Smart Card Slot V.2.7.3.2 3,110,839 Security Panel Application V.1.2 3,653,534 TouchPad Mouse V.5.4.402.9 1,928,173 Touch Panel Driver V.1.03 22,505 TPM (For Model with Integrated Trusted Platform Module) V.1.7 17,542,125 Video V.6.14.10.3741 7,234,518 Wireless LAN Atheros (For 802.11a/b/g) V.3.1.2.21 3,980,525 Wireless LAN Atheros (For 802.11b) V.3.1.2.13
Jun 13, 2017 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
My Fujitsu Siemens Lifebook t4220 is working fine overall. However my pen which was working fine will not function at all. Please advise on what I should do to ge it working again. Padraic.
Sounds like the pen packed up, they do that but normally become intermittent first. Without a source of another pen to determine the nature of the fault, may I suggest a modest solution.
A pen that will function and also be an acceptable fit in the slot is available on eBay, - See - # 140504970431. A good price, and an exceptional supplier. At least it will confirm a pen or a screen problem.
Should you have an original (or copy), of the System Restore disk, I would appreciate you getting in contact, mine got trashed. Paul W.
Jan 05, 2011 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Fujitsu Siemens Black Screen problem
Hold the power button in for a few seconds, until it powers off. When it reboots, change your power settings. Don't shut the monitor off after any time span, it isn't necessary.
Aug 08, 2009 | Fujitsu Siemens LifeBook T1010 Tablet PC
Connecting to data projector
CONNECTING VIA VGA CABLE,RIGHT CLICK ON THE DESKTOP SELECT DISPLAY,
CONNECTING EXTERNAL DISPLAY,
MIRROR ON ALL DISPLAYS
WALLA AND BOB'S YOUR UNCLE
HOPE THAT SOLVES THE PROBLEM.
Jul 03, 2009 | Fujitsu Stylistic ST4110 Tablet PC
Pen problem
to connect yo,r pen in usb port and anotner one solution is to uninstal your usb drivers in yo,r devicemanager and restart your system then connect your pen
May 08, 2008 | Fujitsu Siemens LifeBook T3010 Tablet PC
Problem with the pen
I don't recall if that uses a "special" pen or not. You can try re-installing the pen driver.
Here's a link to the driver support site:
http://support.fujitsupc.com/CS/Portal/supportsearch.do
Just choose "notebook pc" under "select product"
Then "T Series" under "select series"
Then "T4010D" under "select model"
You want the "pen driver / service" driver.
Good luck.
Jan 10, 2008 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Unable to connect to data projector
Hi. The Projector is recognized in Windows Enviroment as another Monitor. So right click on the Desktop = > Settings => Settings Tab => You'll find two monitors. Change to Number 2 then click ok. Now your Data from VGA Card will be redirected to your Projector Enjoy.
Feb 11, 2007 | Fujitsu Stylistic ST4110 Tablet PC
Fujitsu Stylistic ST4110 Tablet PC Logo
103 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Michael Vincent Cruz
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
