Question about Electrolux Ovens
Es100/105 schematic would like the schematic to the es100/105 to see if i can adapt this to run a 110 elemant to use ion a home made smoker. want to adapt the relays to work on 120v rather than 240v if i see the schematic for this control i want to see if i can jump neutral over for the other side of the 240
  • bruce_damen
    bruce_damen Dec 02, 2012
    i removed the orange wire which was feeding the one side of the 120V for both the broiler and oven elemnets and atttached it to the common and it works!!1
My baumatic oven elemant burned out and blew mains fuse,so replaced both and their seems to be no power at all getting to oven
Some units have their own fuse. Usually near where the power supply goes into the oven. Check your Meyer box for tripped RCD or circuit breaker too.
Nov 22, 2014 | Baumatic Ovens
My grill uses the same elemant as my grill but grill wont work , but oven will
when you use your grill the oven door must be open if if does not heat then the door switch is faulty
Apr 21, 2012 | Ovens
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Element ''melting''
paul,as the saying goes the dont make them like they used to,im sorry to tell you your elemant is on its way out dont be surpised if by the time this answer gets to you it is burnt out .sorry i could not give you better news.adrian ps.the elemant is melting please get it replaced.
Nov 03, 2008 | Fisher and Paykel OS302SS, Stainless Steel...
Bake do not work
check to see if heating elemant is open with power off
Oct 22, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Apr 20, 2008 | AEG B2100-4 Electric Single Oven
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Ovens Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
