FixYa.com
Tags:
Toshiba e740 Pocket PC
Constant shutdown and loss of data (by 2 users)
posted by IdiotBoy211 on Jun 07, 2007
When it's in the cradle or pluged into the power suply it will run fine but when i take it out it stays on for a few seconds then turns off. Some times it will come back on and just sit on the boot screen and then i can't turn it off. The battery if fine as it registers as full when it is put back in the cradle and will stay on for ages on the boot screen.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jan 06, 2008
Purchased mine on Ebay.Never worked.Bought new battery.Boots up then dies.Worthless.
Solution #1
posted on Feb 23, 2008
Not Rated (0)
simurday
Rank:Master Master
Rating: 83%, 8 votes
Is it the one with integrated wifi - try removing the wifi card & restart then charge & use for a while & put the card back & test -
I had the same issue with one
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PDAs problems?
will not power up
I was getting a "replace... Answer This...
Not Powering on
Hi! I had e740 for at about 5... Answer This...
tosheba e740
can't get wi-fi Answer This...
backup battery for the Toshiba...
Hello, I need to replace the... Answer This...
dim screen for Toshiba e740
how do you fix this problem of... Answer This...
Repair Service
Find PDA Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
