Question about Hotpoint First Edition WMA20 Front Load Washer
Dial won't move automatically
The dial is staying in whatever cycle I put it on and won't move unless I do it manually. Also it won't spin fully.Any help would be appreciated.
  • Hotpoint Master
  • 3,463 Answers
The dial is not a timer that moves through the prog, it is a selector switch, which selects the programme you require, and therefore does not move round
You need to check the filter re the spin prob.
Remove rear panel, remove large black hose from bottom of tub, remove filter, and clean.
Refit filter and hose.
Test for leaks
Plz rate my solution.
Thanks
Posted on Jan 11, 2009
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
The Spin Cycle does not work
Suspect that the Timer module is faulty as it does not move automatically to the SPIN mode.
You need to try with another program cycle to confirm or otherwise replacement is the only option. check on cost and options..
Jan 16, 2013 | Washing Machines
Washer when set turns on and fills and agitates. But will not move to next cycle automatically. I can manually move the dial to rinse / spin and it works properly. But again won't move to final spin...
From the way you discribe it, sounds like you have a bad timer.If you decide to fix it yourself be sure to mark the wires before removing the timer.
Apr 06, 2011 | GE Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Machine will not automatically advance thru cycles
The timer has a motor used to advance it through the cycles. If the machine fills with water and the timer stays in one position no matter where you put it......even in the spin cycle, then replace your timer.
May 03, 2009 | Washing Machines
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint First Edition WMA20 Front Load Washer Logo
174 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
