Simpson encore 806 washing machine beeping and screen showing DF
Our washing machine is beeping through the whole cycle and the screen is flashing up DF, can anyone help us fix this problem?
DF means the temperature sensor is faulty. Replace it. Get a new one from your Simpson agent. Turn power off. Open panel by removing the 3 screws at the rear of panel & swing it up. If you are standing behind the machine look on the left hand side at the top of the circuit board. You will see a small white plug with 3 wires (red-white-black) Very carefully pull this plug toward you off the 3 pin base. The other end is the sensor pushed into the water inlet chamber. Pull it out. Push new sensor into water chamber (make sure black rubber o-ring is on it) Push wiring plug back onto 3 pin base. It can only go on one way. Do not force it or twist it as the 3 pins can be easily broken or damaged. Then close panel & power up.
Posted on Aug 12, 2009
I have the same problem with the same washing machine: Simpson Encore 806. I followed the instructions suggested above. I bought the part suggested (temperature sensor) replaced it, screws back, turned machine on and error message still shows. There must another meaning for dF message.
Posted on Feb 18, 2010
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
Why is there an 'SF' code showing and continuous beeping from our Simpson encore 756
there are different sf codes for different faults. try googling the sf number fault to find problem.
May 25, 2014 | Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
My Simpson 806 Heavy duty washer fills then stops, flashes SF on screen and beeps. Anyone got a solution?
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
on certain models the "sf" stands for service filter.
Jan 12, 2012 | Washing Machines
SIMPSON 816 ENCORE WASHING MACHINE ERROR MESSAGE
Hello
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
This should clear the machine out.
Apr 01, 2011 | Electrolux Washing Machines
I have a Simpson encore 807 & screen displays DF what does that mean? It Still washes ok Beeps a lot though? can anyone help
The clue is in the water temp. light flashing. DF means that the temperature sensor is faulty. Replace it with a new one. Turn power off at wall. Remove the 3 screws & open panel. Sensor is plugged onto control board near the middle top of board & goes down into the base of the control panel at the middle where the water enters the machine. Unplug from the board taking care not to damage the pins on the board. Replace the new one making sure the o-ring is on it. Close up panel & turn power back on. All fixed!
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Washing Machines
Says sf on screen Simpson encore 807
i have a Simpson encore 807 & its displays DF what does that mean... as it keeps beeping...
Jun 30, 2009 | Washing Machines
Simpson washing machine encore 756 displays error df and will not complete cycle
our simpson encore 756 flashes SP can anyone tell us what it means and how do we fix it thanks mark
Aug 03, 2008 | Washing Machines
Washing Machines Logo
1,379 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
