Question about HTC Cell Phones
Where do I out the tire jack to lift the van for a tire change?
  • HTC Master
  • 32,281 Answers
If there isn't a jacking point near the wheel then place the jack under the axle close to the wheel you want to remove. Do not forget to chock the wheel on the other side of the van so that the van cannot move or roll.
Posted on Dec 02, 2012
Change tire
You need a jack to lift the vehicle high enough to get the tire off and the new one on, you need a lug wrench to loosen and tighten the lug nuts and depending on the rims you might have hub caps that are part of the rim or seperate and if they are seperate, you need something to pry them off with. So the proper way to do this is:
Before you raise it with the jack, take the lug wrench and loosen the lug nuts a little. This is easier when the tire is on the ground because depending on the tire location, it will turn if you lift it. So when the weight is on it, it wont turn. Then you put the jach under the car and near the tire you are lifting and you use the jack to raise the tire. Then finish taking the lug nuts off. Remove the tire and put the new tire on. You may have to raise the jack some more to make it high enough. Put the lug nuts back on tight as you can and lower the car. Then tighten the lug nuts again to be sure. You should tighten lug nuts by skipping them. In other words start with one and tighten it, skip the next one and tighten the third one. When you go all the way around, go to the ones you skipped and tighten those.
Dec 03, 2013 | 1998 Lincoln Navigator
How do I change a tire on a 2001 town and country
Open the hatch back. On the left-hand side is a panel that you can open in which the jack resides. Take that out.
(If you want to use the spare tire, located under the trunk space...)
You will see a plastic disc on the floor of the trunk space (where you store your luggage/groceries/etc). With a flat head screw driver pop the flat disc up & off. This will reveal a nut that you can turn to lower/release the spare tire that is directly underneath it.
If your T&C is like mine, you have a plastic cover in the middle of each alloy wheel that covers the lug nuts. This plastic cover can be popped off with the flat/nubby end of the crow bar that comes with the jack. It fits perfectly into a slot on the plastic cover.
Once you get the plastic cover off, the 5 lug nuts are revealed to you. Before you jack up the van, even a little, I would try to loosen all 5 lug nuts, just a bit...to get them going. Once the van is jacked up, it will be difficult to begin to loosen the lug nuts.
With the nuts loosened, set up the jack so that once you begin to turn it, the slot in the jack fits right into the frame of the van. You will see the frame that fits the slot in the jack between the front tires and back tires, on either side of the van.
Once the tire you want to change is fully lifted off of the ground, loosen the rest of the lug nuts and remove the tire. Replace it and reverse the order of what you just did. Get the 5 lug nuts onto the new tire, but only snug them up by hand. Once the tire touches the ground as the jack is lowered, then you can fully tighten the lug nuts with the crowbar.
Hope that helps!
Jun 08, 2011 | 2001 Chrysler Town & Country
How do you take off the spare tire underneath?
lift the carpet and you should see a nut by the rear of the van turning it will lower the tire
Dec 29, 2010 | 1999 Dodge Caravan
Where would the jack and other tire changing equiptment be found in the van?
Lift rear hatch and locate and remove cover on driver side rear corner, jack etc should be behind there. Your spare should be hanging under back of van, ahead of rear bumper. Unfortunately, 9 chances out of 10, the cable and mechanism holding it up there will be rusted and won't work, so don't get too frustrated if it won't come down. A lot of people cut the cable, and lay tire in back. Who knows, you may be lucky, and it will work. Good luck ! Be careful, it's heavy, so if you cut cable, have something up against it like a floor jack or something so it doesn't come down on your head.
Oct 24, 2010 | 1993 Dodge Caravan
This is a simple question. I'm trying to fix a friend's tire problem, but I can't determine where the jack should go in order not to damage the body of the car? Thanks
Near the tire where you are going to jack it up, you shoud see a long rail running the length of the van. This is the frame of the van. Along this frame near the tire where yo are going to jack up you will see a jack point. Use a flashlight to locate this. The jack point will be reinfroced and is designed to keep the jack from slipping. Thanks for using Fixya.
Aug 27, 2010 | 1995 Ford Econoline
Where do I put the jack to change the tire? When I put it under the car it only lifts the frame and not the tire.
Put the jack as close to the tire on the frame as you can. If the jack is too close to the center of the car it wont get the car tire up to the height it needs to be to lift off the ground. Hope that helps!
Jul 30, 2010 | Ford Expedition Cars & Trucks
Change spark plugs for 2000 dodge caravan
lift car on jack put on jack stands remove wheel shoul be little easeir to change lift body of car more than tire
Dec 07, 2009 | 2000 Dodge Caravan
2002 Honda Accord - changing tire
ex: front tire= right behind tire there is a lip of metal that sticks down and there is about a 3 to 4 inch part right behind the wheel that has been reinforced. Put your jack right there so the grove on the jack sits in it nicely. Before you jack up the car loosen the lug nuts a bit then lift the car and finish the job.
Aug 28, 2009 | 2002 Honda Accord
1996 Ford Windstar brake drum removal
use hammer hit drum to lossen rust if its loose and feels like somthing holding inside on backing plate is a rubber plug remove and back off adjuster
Oct 19, 2008 | 1996 Ford Windstar
Jack Location for Tire Change
under the back seats, jack is under the driver's side backseat, tire iron & rods are under passenger's side backseat.
Aug 18, 2008 | 2004 Jeep Grand Cherokee
Cell Phones Logo
27 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
