Question about Tappan TGF320 Gas Kitchen Range
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
Oven pilot light burns, but main oven burner won't come on. Four burners on top of range work fine...We have replaced the oven gas valve, but still have the problem with oven burner not working.
    Top Expert:
  • Tappan Master
  • 9,472 Answers
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Posted on Dec 02, 2012
SOURCE: Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Posted on Feb 13, 2009
  • 183 Answers
SOURCE: Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Posted on Jul 28, 2007
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
jsrock516
  • 5911 Answers
SOURCE: Tappan - Model 36-3052-23
I suspect you may have a bad igniter. They will still glow nice and hot, but if they are weak the gas valve will not open. This is actually a safety feature. Depending on which type you have, the glow bar igniter is supposed to draw a certain current potential before the gas valve will open. Here's the current readings for both types: Round Glow Bar: 2.7 to 3.2 amps Square Glow Bar: 3.2 to 3.7 amps I would try to to determine if the igniter is good or bad before proceeding with a gas valve replacement. Generally, the igniter is a common fail item. Let me know if this helps.
Posted on Sep 07, 2007
Amigaman
  • 248 Answers
SOURCE: Tappan gas kitchen oven will not heat
Almost always a weak oven igniter. Remove oven floor by removing 2 screws at rear of floor. Remove flame spreader from burner, if it has one. Turn on oven and see if igniter gets red. It's the caged thing on burner tube. If it does but doesn't light gas, replace igniter. UNPLUG UNIT FIRST!!
Put dishwashing soap on threads of 2 screws holding igniter in place. This will allow it to come out easier. Do-not use oil. It will make your oven smell like a diesel truck.
Remove screws. You will have to remove drawer in front. Underneath you can fin wires from igniter. These will be cut at igniter and connected to igniter with enclosed wire nuts. The 2 wires to igniter go either way.
Posted on Nov 22, 2007
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
The oven/stove is from the 70's and the pilot light is on but the oven will not heat up. help
Thank you for bringing me back to the early days of my appliance repair career,now a days every thing uses a electronic ignitor and its been a while since i have seen a free standing pilot :)
As far as your oven,when you turn on the oven does the small pilot light increase in size,if not the oven thermostat is the most likely problem and for the most part the thermostats are no longer avaliable. If the pilot size increases the pilot burner could be not properly heating a small bulb in the pilot burner,the pilot burner could be cleaned by a senior tech that knows how to do it correctly OR the small bulb is heating and what that the bulb attaches to (the gas safety vavle) is not opening to allow gas flow to the main bake burner
Depending on your exact model (what parts were used when it was built) the pilot burner and gas safety valve are still avaliable
Gene
Jul 30, 2011 | Tappan Kitchen Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Oven does not light
If no gas at all is coming from the oven burner, then it sounds like you need a new gas valve. If the pilot lights but the main burner does not then its the thermocouple.
Nov 03, 2009 | Tappan TGF320 Gas Kitchen Range
Where is the pilot light for the oven?
Look inside the oven where the burners come into the oven. Right at that point you should find the pilot light. Here is where you light the pilot.If you smell a lot of gas when you open the door, turn off the gas altogether and let it dissipate. Then turn ot on and then you can light it.
Jan 30, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan Stove 5 burner with Oven
does the pilot seem low?you can remove the pilot then clean it out,let me know.
Nov 10, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan Gas stove
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
548 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
