Question about Home
The red button on the exposed bathroom thermostatic bar shower mixer is stuck in , how to fix the button
Tried rotating the knob with the button, but the button remains in the stuck in position
brainyass
  • 242 Answers
SOURCE: Triton Electric Shower Temperature too hot
You could have mineral deposits on the temperature probe inside of the unit. If you remove the heater and purchase a bottle of lime and scale remover (lime away) to put inside of it. Let the unit sit full of water and chemicals for 24 hours. Flush out the unit to remove any residue. You may see the water is brown if you have a lot of buildup. Reconnect unit and test your settings. If this doesn't work, install a anti-scalding device, available at a plumbing supply store.
Posted on Oct 23, 2008
  • 374 Answers
SOURCE: leaky shower knob
Absolutely the same as the shower excluding the obvious difference in supply cut offs.Thanks for using Fix Ya.
Posted on Mar 11, 2009
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
  • 82 Answers
SOURCE: need to clean single knob shower cartridge from
The water heater should not have a "discharge valve" at all on it, and if it does (not code) you would not need to shut it off. All you need to do is shut the house main off and you will be fine. Once you shut it off, open up all other faucets to drain the house. Be sure to shut all faucets once you repair. PS I do not recommend trying to "clean" the cartridge and it is sure not to work. Simply replace it.
Posted on Nov 27, 2009
  • 20 Answers
SOURCE: I have an Aquariss shower mixer that runs cold when fully on
a washer or o-ring inside the cartridge may have dislodged and caused this ---turn off water to valve or whole house if necessary, and remove shower valve cartridge and inspect---all o-rings/washers should be in place and somewhat greasy(lubricated)....note which way it was when you removed it, as its replacing must be done the same way
Posted on Mar 14, 2010
Heater control knob not working
If you can pull the knob off the heat and look inside to see if the knob is broken out. if not you may have a broken switch.
Jun 23, 2017 | Volvo 940 Cars & Trucks
If i am getting e68 error can just the button be replaced
Welcome to FixYa.
The E68 is indicating a push button is stuck,
To investigate further the console would need to be serviced/torn-down. I'd try the suggested test program first though. To answer your question "can just the button be replaced"...
No unfortunately, The buttons are a part of the entire control behind the console/panel. The test I'm going to post is quite long so I'll post it in two parts.
PART 1
FUNCTION TEST SEQUENCE
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and "rES" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counterclockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds.
The control will enter test mode, the buzzer will sound 3 times and all LED's will rapidly flash. After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggle back and forth in the display.
SEE Below for remaining test program instructions...
Mar 29, 2011 | Frigidaire Electric Dryer
I have a frigidaire affinity dryer that will dry for a few minutes then turn off and say e68 wich means one of the buttons are stuck i took the panel of the front and checked the buttons and they all seem...
Run the service diagnostic mode to determine which button is stuck. Start by pressing and holding the Select and Cancel buttons simultaneously for 6 seconds to reset the control.
Rotate the cycle selector knob 5 turns counterclockwise to the second position from the bottom immediately after the buzzer sounds.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control enters the test mode and the buzzer will sound 3 times with all of the LEDs flashing.
Rotate the cycle selector knob 4 turns clockwise to the second position from the top and the dryer motor runs with the heating element off. The buttons can now be tested to determine which is stuck.
Press each button and all corresponding LEDs should light. If the LEDs corresponding to a certain button lights up without pressing the button or if the LEDs do not light up when the button is pressed, that button must be stuck or not making any contact when pressed.
Replace the control board if the stuck button cannot be unstuck or if there's no button that's apparently stuck but the fault code persists. Let us know if you need further advice.
Feb 01, 2011 | Frigidaire Dryers
How do you remove selector knob on bosch 11255vsr
Rotate the selector to the 4 to 5 oclock position, or the 7-8 oclock postion, push the red button in all the way with a screw driver and pull the knob out. Certain model hammers you have to rotate to a slightly different position to remove the selector, you will have to try one, if it doesn't work try the other.
Dec 02, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Had the battery changed, but now the (heat) vents in the top of the van and the floor vent (heat) does not work - only cold air comes out. Also, the heating/cooling dial lets it get hot midway on cold...
Try this calibration procedure and let us know if you have more questions:
  1. Start the vehicle.
  2. Wait 40 seconds for the HVAC control module to self-calibrate.
  3. Verify that no DTCs have set as current DTCs.
  4. Clear all DTCs.
  5. Place the ignition switch to the OFF position.
  6. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
  7. Rotate the Mode knob fully counterclockwise.
  8. Rotate the Mode knob fully clockwise.
  9. Rotate the Mode knob fully counterclockwise.
  10. Release the AC button.
  11. Wait 40 seconds for the HVAC control module to self-calibrate.
  12. Start the vehicle.
  13. Verify that no DTCs have set as current DTCs.
Nov 14, 2010 | 2005 Pontiac Montana SV6
What does error code e68 mean
One of the buttons is stuck closed or shorted. Enter the function test mode and perform the button test to determine which button is stuck or shorted. When determined which button, try to free or unstuck the button then perform the test again. Replace the user interface board when the button is freed but the code still exists.
Press and hold the SELECT and CANCEL buttons simultaneously for 6 seconds to reset the control. When resetting is successful, the buzzer will sound and "rES" will be shown briefly in the display, and then immediately rotate the cycle selector knob 5 turns in the counterclockwise direction to the second position from the bottom.
Press and hold the OPTIONS and CANCEL buttons simultaneously for 2 seconds to enter test mode; the buzzer will sound 3 times and all of the LEDs will flash rapidly.
Rotate the cycle selector knob 4 times in the clockwise direction to enter button test. Press the buttons one at a time and observe the LEDs corresponding to that button light up. The LEDs should light up; otherwise the button is stuck.
Press and hold the SELECT and CANCEL buttons simultaneously for 6 seconds to exit test mode.
Apr 04, 2010 | Frigidaire Electric Dryer
Bathroom doorknob stuck in locked position.
I will tell you how to fix 'em. Open the Door Knob with a screw driver, gently pull aart the two knobs once open, then look for a long sliding rod, pull one knob away, twist the Knob untlil it is in unlock position, put them back together to test if it slips properly. If it does not, there is something preventing the rod from rotating freely. Try to ensure it rotates freely. Then screw back together :)
Nov 18, 2009 | Hardware & Accessories
I cant find the way on how to light uo the friar.
If you have a pitco 35 fryer, all you need to do is have gas connected and turned on, rotate the know on the gas valve to the pilot position, depress the knob, while holding the knob down light the pilot, normally located in between the burner tubes in the middle of the front of the fryer, hold the knob for 60 seconds, when you release the pilot should remain on. If it does rotate the pilot know to the "on" position, from this point the thermostat should control the fryer. If your pilot does not stat lit, press the red button on the hi-limit to reset it, it could be tripped and this would cause the pilot to not hold. Hope this is helpful.
Mar 18, 2009 | Pitco Frialator 35CD Deep Fryer
How do I run a diagnostic on a Fridgidaire
Diagnostic Test: The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360°, turn the Program Knob to start position, Drain/Spin. • Press Pause Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED’s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs. To clear latest stored error code: Place the control into Diagnostic test Mode. • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code. • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared. • Exit Diagnostic Mode to return th e w a s h e r t o n o r m a l o p e r a t i o n .
Dec 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Film speed selector stuck
Try to rotate the lock body anti-clockwise. Do not use muscle power, just try to rotate softly the locking body.
Oct 10, 2008 | Nikon FE 35mm SLR Camera
Home Logo
252 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
