Question about Microwave Ovens
Microwave plate will not go round when it is working
It has only ways worked well but the plate inside the microwave will not go round when it is working I tried to use defrost setting but did not no how as i have not got the manual
    Top Expert:
  • Microwave Ovens Master
  • 34,153 Answers
There is a drive motor mounted underneath the plate.This probably has failed
Posted on Dec 01, 2012
  • Elaine Chamberlain Dec 02, 2012
    Thank you so much. just worried if it's safe to use as i ave been doing Only for 3mins once a day Think i beter get anew just to be safe
  • Tom Chichester Dec 03, 2012
    I just went through that with a Sears Kenmore. You just don't get even cooking without the rotation
4 Suggested Answers
  • 86 Answers
SOURCE: Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Posted on Dec 28, 2008
SOURCE: GE Spacemaker - microwave works but the inside plate doesn't spin
you have a bad turntable motor or a bad control board.. start with the motor 9 time out of 10 this is your problem.. you can pick up this part at your local parts house or order online.. look for universal part. this will be alot cheaper then the oem.. just take the screws out of bottom panel under microwave. panel will drop down. you will see little round motor about 2in' make sure unit is unplugged.
Posted on May 09, 2008
SOURCE: Metal plate on inside of microwave has hole & is arcing.
The Arcing is a real bad sign, and you see the "Brain" has detected a fault condition, most likely the Power Supply and or magnetron, or High Power Diode, has "Faulted" and it shuts down for Safety reasons. Due to the danger existing inside MW, I recommend that you have it serviced by a qualified person. Always get a firm "Quote" before proceeding with any work. Be careful, as often a repair may cost as much as a new one.
Posted on Mar 13, 2010
Testimonial: "Thanks for the insight. We will definitely look into the items listed and have it looked at by a qualified repair tech."
Our base inside the machine won't go round
Sounds like the motor has blown, I did have this once before and I found by taking the glass plate out and turning motor top where plate rests on by hand a few times it started to work again but it might be gone anyway, you might be able to get a second hand one but a new one is about 30 pounds so might be advisable to renew machine.
May 10, 2014 | Sharp R-1405 / R-140 Microwave Oven
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Hi, we have a Bosch HMT8656GB integrated microwave (fitted in 2007) and in the last 2 weeks or so, the glass tray on the bottom of the microwave has stopped going round when the machine is in use, however,...
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
I am assuming the plastic coupler is not split or broken and causing the problem.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Feb 04, 2011 | Bosch HMT8656GB Microwave Oven
The glass plate inside will not rotate
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 01, 2011 | Thermador MBES Microwave Oven
Tray rotation motor does not work
Hope this helps.
Dec 19, 2010 | Microwave Ovens
I have a CMW-100 microwave. The turntable has intermittently stopped spinning. Now, it has stopped spinning entirely. Is there a part I need to replace to fix this problem? Judie Snivley
Sounds like the turntable motor has stopped working.
Hope this helps.
Dec 15, 2010 | Cuisinart CMW-100 Microwave Oven
GE Spacesaver 1800 XL - rattling sound
Hi jnflanders,
You've probably solved this by now, but I'll answer just in case. That part is called the stirrer motor. You can replace it yourself, as long as you have an offset phillip's head screwdriver handy.
Before you order the replacement part, figure out if your stirrer is driven by a d-shaped or a square shaft. You can tell by taking off the round plate on the inside top wall of the microwave. GE makes stirrer motors for both d-shaped and square shafts, so you'll have to get the right one. Here's the d-shaped motor that fixed this problem with my microwave: http://www.appliancepartspros.com/part_details.aspx?part_id=2024961.
Apr 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable won't spin so microwave won't heat
Is it possible to take the glass plate out, if so, please remove the glass plate, switch on the microwave for 10 secs and watch through the door to see if you can see the centre spindle turning round? Try this and get back to me please
Mar 12, 2009 | Goldstar MV-1615 Microwave Oven
May 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
