Question about Whirlpool Washing Machines
WTW4800xq0 shake bad during spin cycle - Whirlpool Washing Machines
  • jose beltran
    jose beltran Aug 02, 2016
    My washer was just doing the same thing shaking like crazy on spinning cycle whirlpool model WTW4800xq0 I just change the 4 suspension spring balancer rods part #W10820048 and it work like new againg search amazon cheaper than sears easy to change I hope this help some body and save money this parts cost $50 dollars on amazon
Posted on Aug 02, 2016
fanny
  • 146 Answers
SOURCE: Bad shacking during the spin cycle
Remove top of machine and check the centralising springs are still attatched. If springs ok tilt machine against the wall after unplugging from the wall socket and check the shock absorbers. One of them could have jumped out of the guides. If shockies are ok, check the spider for cracks/breaks. The spider is the cast part that holds the outside drum in place. To check this you will have to remove the back plate.
Posted on Nov 05, 2007
SOURCE: kenmore washer shakes violently during spin cycle
I have a Kenmore 22990 top loading washer. it shakes violently and walks across the floor during the spin cycle. it started doing it about two weeks ago. moving clothes around inside the tub does not help much.
Posted on Dec 01, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
SOURCE: GE Front load GCVH6600 Shakes all over the place on spin cycle
Wow...does it sound like it's about to take. You can hear it all over the house even with the door to the room closed? We have the same reason. THis started after a bout of lice in the house and we were doing many loads a day for a while. Help!
Posted on Jun 29, 2009
SOURCE: I bought a scratch and dent Whirlpool Cabrio
I just bought the exact same model this weekend that I found used in the classifieds. The person who sold it to me said it worked, but when I got it home and hooked it up, it did exactly what yours did, even with no laundry in it. It would get to the spin cycle and start banging around violently like it had a brick in it. I even used an electronic level to make sure it wasn't uneven on the floor. From doing a little research on the web, i read that the suspension could have gone faulty. I took it out and set it up in my garage and hooked a hose up to the cold to see it run a small cold water load with the back panel off so I could observe what was going on inside. From what I observed, the suspension springs were sprung and some worse than the others. I am going to order a replacement set from Sears tomorrow and replace them to see if the unbalanced problem goes away. Removing them is a cinch and should take about a half hour to do all four and put everything back together. I will let you know if my unbalance problem goes away.
Posted on Aug 17, 2009
When the machine is on spin the machine shake so bad that it jumps
If the drum has an unbalanced load any machine will shake like crazy during high speed spin cycle - some even have a buzzer and shut down! Rearrange the clothing in the drum.
Oct 28, 2015 | Washing Machines
GE WBHV5200J3WW shakes during spin cycle with load in the machine
you might need a new Motor Asm Kit part number WH20X10028
the pic below is Motor Asm Kit that you might need okay
Jan 29, 2013 | Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
Excessive shaking during spin final cycle
check to see if the floor is solid and not soft, thin or flexible. are the leveling legs tight? make sure the locking nut is tight and that the leg does not wobble.
Dec 23, 2009 | Maytag Washing Machines
Shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
Mar 29, 2009 | Washing Machines
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Dec 06, 2008 | Maytag Neptune Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
147 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
