Question about Home
I have a 1999 Laser Select hot tub. It gets ups to temp but when we get in the temp goes down pretty quickly
    Scholar:
  • 111 Answers
Does this happen when you're running Jets and/or Air Blower?
Using an air blower w/o an air heater or opening all the air controls for bubbles will cool the water rapidly.
The solutions are to get an air blower with a ceramic heater on the intake. Avoid using the venturi style air controls.
As heating and filtration are done on the pumps low speed you could change the control box to a high current setup where the heater will stay on when the jets are high. This is not possible on all controls & should only be done by a technician.
Hope that helps
Posted on Dec 02, 2012
Air lock cooling system
Not sure I follow your wording on the different temps. If the system is full of coolant and working correctly, the thermostat should open at 195 degrees which would be several miles down the road. Once the thermostat opens both radiator hoses should be warm. If the water pump is not working the engine will get hot very quickly.
Have you tried running without the thermostat to see what happens ?
Mar 05, 2014 | Hyundai Elantra Cars & Trucks
Balboa hot tub.. how to turn up the HEAT / TEMP , no owners manual, and does anyone know where I can get one?
You do not have a Balboa Hot Tub. That is the company that made the control panel for it. Id venture to guess it's either a Hawkeye, Barefoot or Master spa if it came with no owners manual. To turn up the heat simply press the Red "up" arrow on the digital control pad. Check out the link below. It's a quick reference guide to what I'm guessing is your top side control.
http://www.hawkeyespas.com/pdf/balboa-504-topside.pdf
Apr 22, 2013 | Garden
Hot tub pump noisy, heats to set temp, fl error code
This sounds like your motor is going out. When they get noisy and run really hot is when they go out
Rod
US Parts Center
Jan 08, 2013 | Qca Spas Jewel Series Topaz Plus Hot Tub
My 1999 Chevy Malibu runs hot? It started when it overheated. We changed the thermostat, then water pump, then temp sensor gauge and the temp gauge goes high but only when the heater stops blowing hot...
Air pockets will make the guage do that, and also cause your heat to come and go. Also, a poor radiator, as in rotting, or plugged up, will cause high temperature issues.
Sep 20, 2011 | 1999 Chevrolet Malibu
Front wheel makes a terrible grinding noise. Disk gets real hot after only a few blocks driving.
sounds like a brake problem, jack it up, pull off the tire and inspect the pads, if the rotors are getting that hot that quick it has the be a problem in the pads, the caliper, or you have a warped rotor....a quick inspection of the area will narrow things down pretty quick for you....best of luck!!
Mar 21, 2010 | 1999 Ford Mustang Cobra
Temp gauge goes up to hot then back down, up and down...
That is very possible.Your radiator could also be plugged,You water pump could be could be giving out or the head gaskets are bad..Those are all worse case scenario's But yes the thermostat could be the problem..I'd start with that then make sure your clutch is working properly..Hope this helps you and have a great day
Apr 02, 2009 | 1999 Ford Explorer
Temperature gauge
could be signs that you need to replace the radiator. neons have a rpoblem with the radiator cores rotting out pretty quickly.
Jun 15, 2008 | 1999 Dodge Neon
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
