Question about Crown XLS 602 2-Channel Amplifier
Crown XLS 602 power amp: Where inside is the fuse so I can replace it?
Not getting power, bought fuse, but do not see inside unit
  • 5,807 Answers
Hi Tom,
The fuse you may be referring from the power supply is not
used(none) instead a CB1 or circuit breaker is installed.
These breaker is in series with the power transformer ( trace it).
Disconnect the AC outputs of the power transformer when trying to
reset.( of course with the unit unplugged ).
Measure the output AC voltages, if it is OK
Be happy partially!
Next would be.....
Check for possible shorts on the Positive and Negative Supply
rails to ground or speaker out, for what might have caused the
breaker to tripped.
And these wont be easy troubleshooting , Good luck!!
thanks for choosing Fixya for assistance.
Posted on Dec 03, 2012
  • 308 Answers
SOURCE: There is a red light shinig inside my CROWN XLS
Lots of electronics have lights (LEDs) that turn on when they are plugged it. Most people just don't notice them. If it is working properly, then the light is normal.
Posted on Mar 04, 2010
Ganx
  • 113 Answers
SOURCE: The fault light immediately comes on my Crown XLS
Hi try disconnecting the speaker outs and turn off bridge (if its on) If it doesnt work still, then suggest direct to a crown agent. The amp has a 3 year no fault warranty. Hopefully its still in!
All the best
Posted on Aug 04, 2009
petraman7
  • 1175 Answers
SOURCE: No power to Crown XLS 602 Amplifier
Hi...
There may be some internal fuses on that unit.
You can open it by taking the cover off and looking for fuses and discolored parts.
It may have a thermal fuse on the power transformer which then will require service
Check the web for service people in the UK
Posted on Apr 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: my crown 602 xls tripped a breaker, I reset
They use a breaker instead of a fuse.
http://www.retrevo.com/support/Crown-XLS-602-Amps-manual/id/19050ci763/t/2/
CONDITION: No
power to the amplifier.
POSSIBLE REASON:
• The amplifier's Power switch is off.
• The amplifier is not plugged into the power receptacle.
• The amplifier's high-voltage power supply circuit breaker has tripped. Verify that the AC mains
voltage is correct, then press the Circuit Breaker button on the back panel.
Take it to the ER.
Posted on Jan 12, 2011
  • 8 Answers
SOURCE: Got a crown amplifier XLS 602 its powering up the relays are clicking, all voltages seems ok the signal led's are on but there's no sound output on both channels. I manage to trace the signal
Check your input or output cables might be dirty I had the same problem
and 1 of my output wire was dirty so i sprayed tha electric cleaner and its all good now
Aloha
Posted on May 21, 2012
Can't locate the fuses.
There are no fuses inside a car stereo unit. The fuse protection is outside on the power circuit. Does it do anything when you power it on?
Nov 24, 2013 | Kenwood Car Audio & Video
Aloha
May 21, 2012 | Crown XLS 602 2-Channel Amplifier
Yamaha dsp a1000 won't power up
Your power suply is defective and needs repair.
Or the power amp is shorted will blow inside fuse power line
distribution.
May 15, 2012 | Yamaha DSP-A1000 5-Channel Amplifier
Crown XLS 602 Amplifier - Channels sound different
you are riight there exist several amps like that they having different frequency on each side i supose its not properly made like that or better they wanted a pasty sound on one side and a thin on the other many times it happened to me - in older days specially lots of european amps the solution is a equalizer on the front and equilze it smoth how u want it
Apr 15, 2012 | Crown XLS 602 2-Channel Amplifier
I have a Crown XLS 802 amp that works fine but the fans do not work. They, however, are not frozen. Any help is appreciated. Jim
It is capable of detecting cooling fan failure so I would presume it hasn't decided to engage the fans yet.
Jul 21, 2011 | Crown XLS 602 2-Channel Amplifier
My crown 602 xls tripped a breaker, I reset breaker regained power to receptacle , I lost power to the amp no led's come on front when i pushed the small reset button on the back I still did not regain...
CONDITION: No
POSSIBLE REASON:
Take it to the ER.
Jan 12, 2011 | Crown XLS 602 2-Channel Amplifier
I recently bought a 2000 jetta and the cd changer isnt getting power when plugged in, the radio inside says "no changer". does this cd changer ground to the body or is the ground in the plug?
cd changer is grounded through the plug, And it should have it's own fuse -- so if you are not getting power to the unit, look for a in-line fuse to the changer itself.
c...
Jan 02, 2011 | Volkswagen Jetta Cars & Trucks
I need to replace the fuse for a used Marshall MG100HDFX that I bought. Where is the fuse located inside the head?
If the fuse is blown make sure the reason it blew is repaired before replacing the fuse. Start the amp up after replacing it with a 100 Watt light bulb in series with the hot side of the power into the unit. This will act as a current limiter to verify it is repaired and will not blow the fuse. When you open the unit the fuse will be obvious... Follow the hot side of the power cord, through the switch to the fuse.
Dec 08, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Hi...
Mar 31, 2010 | Crown XLS 602 2-Channel Amplifier
Crown XLS 602 2-Channel Amplifier Logo
540 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
